[cfMesh] cfMesh installation errors on supercomputer |
December 1, 2015, 17:59 |
Ripudaman Manchanda
Rep Power: 12 |
Here is the error log I get when compiling the cfMesh libraries in foam-extend-3.2 on Stampede supercomputer on TACC.
Almost everything else is compiling fine. Code:
+ wmake libso cfMesh SOURCE=utilities/meshes/polyMeshGenAddressing/polyMeshGenAddressingCellCells.C ; mpicxx -DIntel -Dlinux64 -DWM_DP -wd327,584,654,819,1125,1476,1505,1572 -ansi-alias -O3 -fno-alias -fp-model precise -fargument-noalias-global -unroll0 -DNoRepository -DUSE_OMP -fopenmp -I/work/02701/ripu/foam/foam-extend-3.2/src/edgeMesh/lnInclude -I/work/02701/ripu/foam/foam-extend-3.2/src/meshTools/lnInclude -IlnInclude -I. -I/work/02701/ripu/foam/foam-extend-3.2/src/foam/lnInclude -I/work/02701/ripu/foam/foam-extend-3.2/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64IccDPOpt/polyMeshGenAddressingCellCells.o SOURCE=utilities/meshes/polyMeshGenModifier/polyMeshGenModifierReorderBoundaryFaces.C ; mpicxx -DIntel -Dlinux64 -DWM_DP -wd327,584,654,819,1125,1476,1505,1572 -ansi-alias -O3 -fno-alias -fp-model precise -fargument-noalias-global -unroll0 -DNoRepository -DUSE_OMP -fopenmp -I/work/02701/ripu/foam/foam-extend-3.2/src/edgeMesh/lnInclude -I/work/02701/ripu/foam/foam-extend-3.2/src/meshTools/lnInclude -IlnInclude -I. -I/work/02701/ripu/foam/foam-extend-3.2/src/foam/lnInclude -I/work/02701/ripu/foam/foam-extend-3.2/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64IccDPOpt/polyMeshGenModifierReorderBoundaryFaces.o SOURCE=utilities/meshes/polyMeshGenAddressing/polyMeshGenAddressingCellEdges.C ; mpicxx -DIntel -Dlinux64 -DWM_DP -wd327,584,654,819,1125,1476,1505,1572 -ansi-alias -O3 -fno-alias -fp-model precise -fargument-noalias-global -unroll0 -DNoRepository -DUSE_OMP -fopenmp -I/work/02701/ripu/foam/foam-extend-3.2/src/edgeMesh/lnInclude -I/work/02701/ripu/foam/foam-extend-3.2/src/meshTools/lnInclude -IlnInclude -I. -I/work/02701/ripu/foam/foam-extend-3.2/src/foam/lnInclude -I/work/02701/ripu/foam/foam-extend-3.2/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64IccDPOpt/polyMeshGenAddressingCellEdges.o SOURCE=utilities/meshes/polyMeshGenAddressing/polyMeshGenAddressingCellPoints.C ; mpicxx -DIntel -Dlinux64 -DWM_DP -wd327,584,654,819,1125,1476,1505,1572 -ansi-alias -O3 -fno-alias -fp-model precise -fargument-noalias-global -unroll0 -DNoRepository -DUSE_OMP -fopenmp -I/work/02701/ripu/foam/foam-extend-3.2/src/edgeMesh/lnInclude -I/work/02701/ripu/foam/foam-extend-3.2/src/meshTools/lnInclude -IlnInclude -I. -I/work/02701/ripu/foam/foam-extend-3.2/src/foam/lnInclude -I/work/02701/ripu/foam/foam-extend-3.2/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64IccDPOpt/polyMeshGenAddressingCellPoints.o SOURCE=utilities/meshes/polyMeshGenAddressing/polyMeshGenAddressingEdgeFaces.C ; mpicxx -DIntel -Dlinux64 -DWM_DP -wd327,584,654,819,1125,1476,1505,1572 -ansi-alias -O3 -fno-alias -fp-model precise -fargument-noalias-global -unroll0 -DNoRepository -DUSE_OMP -fopenmp -I/work/02701/ripu/foam/foam-extend-3.2/src/edgeMesh/lnInclude -I/work/02701/ripu/foam/foam-extend-3.2/src/meshTools/lnInclude -IlnInclude -I. -I/work/02701/ripu/foam/foam-extend-3.2/src/foam/lnInclude -I/work/02701/ripu/foam/foam-extend-3.2/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64IccDPOpt/polyMeshGenAddressingEdgeFaces.o SOURCE=utilities/meshes/polyMeshGenAddressing/polyMeshGenAddressingFaceEdges.C ; mpicxx -DIntel -Dlinux64 -DWM_DP -wd327,584,654,819,1125,1476,1505,1572 -ansi-alias -O3 -fno-alias -fp-model precise -fargument-noalias-global -unroll0 -DNoRepository -DUSE_OMP -fopenmp -I/work/02701/ripu/foam/foam-extend-3.2/src/edgeMesh/lnInclude -I/work/02701/ripu/foam/foam-extend-3.2/src/meshTools/lnInclude -IlnInclude -I. -I/work/02701/ripu/foam/foam-extend-3.2/src/foam/lnInclude -I/work/02701/ripu/foam/foam-extend-3.2/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64IccDPOpt/polyMeshGenAddressingFaceEdges.o SOURCE=utilities/meshes/polyMeshGenAddressing/polyMeshGenAddressingPointPoints.C ; mpicxx -DIntel -Dlinux64 -DWM_DP -wd327,584,654,819,1125,1476,1505,1572 -ansi-alias -O3 -fno-alias -fp-model precise -fargument-noalias-global -unroll0 -DNoRepository -DUSE_OMP -fopenmp -I/work/02701/ripu/foam/foam-extend-3.2/src/edgeMesh/lnInclude -I/work/02701/ripu/foam/foam-extend-3.2/src/meshTools/lnInclude -IlnInclude -I. -I/work/02701/ripu/foam/foam-extend-3.2/src/foam/lnInclude -I/work/02701/ripu/foam/foam-extend-3.2/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64IccDPOpt/polyMeshGenAddressingPointPoints.o SOURCE=utilities/meshes/polyMeshGenChecks/polyMeshGenChecks.C ; mpicxx -DIntel -Dlinux64 -DWM_DP -wd327,584,654,819,1125,1476,1505,1572 -ansi-alias -O3 -fno-alias -fp-model precise -fargument-noalias-global -unroll0 -DNoRepository -DUSE_OMP -fopenmp -I/work/02701/ripu/foam/foam-extend-3.2/src/edgeMesh/lnInclude -I/work/02701/ripu/foam/foam-extend-3.2/src/meshTools/lnInclude -IlnInclude -I. -I/work/02701/ripu/foam/foam-extend-3.2/src/foam/lnInclude -I/work/02701/ripu/foam/foam-extend-3.2/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64IccDPOpt/polyMeshGenChecks.o SOURCE=utilities/meshes/polyMeshGenChecks/polyMeshGenChecksGeometry.C ; mpicxx -DIntel -Dlinux64 -DWM_DP -wd327,584,654,819,1125,1476,1505,1572 -ansi-alias -O3 -fno-alias -fp-model precise -fargument-noalias-global -unroll0 -DNoRepository -DUSE_OMP -fopenmp -I/work/02701/ripu/foam/foam-extend-3.2/src/edgeMesh/lnInclude -I/work/02701/ripu/foam/foam-extend-3.2/src/meshTools/lnInclude -IlnInclude -I. -I/work/02701/ripu/foam/foam-extend-3.2/src/foam/lnInclude -I/work/02701/ripu/foam/foam-extend-3.2/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64IccDPOpt/polyMeshGenChecksGeometry.o SOURCE=utilities/meshes/polyMeshGenChecks/polyMeshGenChecksTopology.C ; mpicxx -DIntel -Dlinux64 -DWM_DP -wd327,584,654,819,1125,1476,1505,1572 -ansi-alias -O3 -fno-alias -fp-model precise -fargument-noalias-global -unroll0 -DNoRepository -DUSE_OMP -fopenmp -I/work/02701/ripu/foam/foam-extend-3.2/src/edgeMesh/lnInclude -I/work/02701/ripu/foam/foam-extend-3.2/src/meshTools/lnInclude -IlnInclude -I. -I/work/02701/ripu/foam/foam-extend-3.2/src/foam/lnInclude -I/work/02701/ripu/foam/foam-extend-3.2/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64IccDPOpt/polyMeshGenChecksTopology.o SOURCE=utilities/meshes/partTetMesh/partTetMesh.C ; mpicxx -DIntel -Dlinux64 -DWM_DP -wd327,584,654,819,1125,1476,1505,1572 -ansi-alias -O3 -fno-alias -fp-model precise -fargument-noalias-global -unroll0 -DNoRepository -DUSE_OMP -fopenmp -I/work/02701/ripu/foam/foam-extend-3.2/src/edgeMesh/lnInclude -I/work/02701/ripu/foam/foam-extend-3.2/src/meshTools/lnInclude -IlnInclude -I. -I/work/02701/ripu/foam/foam-extend-3.2/src/foam/lnInclude -I/work/02701/ripu/foam/foam-extend-3.2/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64IccDPOpt/partTetMesh.o SOURCE=utilities/meshes/partTetMesh/partTetMeshAddressing.C ; mpicxx -DIntel -Dlinux64 -DWM_DP -wd327,584,654,819,1125,1476,1505,1572 -ansi-alias -O3 -fno-alias -fp-model precise -fargument-noalias-global -unroll0 -DNoRepository -DUSE_OMP -fopenmp -I/work/02701/ripu/foam/foam-extend-3.2/src/edgeMesh/lnInclude -I/work/02701/ripu/foam/foam-extend-3.2/src/meshTools/lnInclude -IlnInclude -I. -I/work/02701/ripu/foam/foam-extend-3.2/src/foam/lnInclude -I/work/02701/ripu/foam/foam-extend-3.2/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64IccDPOpt/partTetMeshAddressing.o SOURCE=utilities/meshes/partTetMesh/partTetMeshParallelAddressing.C ; mpicxx -DIntel -Dlinux64 -DWM_DP -wd327,584,654,819,1125,1476,1505,1572 -ansi-alias -O3 -fno-alias -fp-model precise -fargument-noalias-global -unroll0 -DNoRepository -DUSE_OMP -fopenmp -I/work/02701/ripu/foam/foam-extend-3.2/src/edgeMesh/lnInclude -I/work/02701/ripu/foam/foam-extend-3.2/src/meshTools/lnInclude -IlnInclude -I. -I/work/02701/ripu/foam/foam-extend-3.2/src/foam/lnInclude -I/work/02701/ripu/foam/foam-extend-3.2/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64IccDPOpt/partTetMeshParallelAddressing.o SOURCE=utilities/meshes/partTetMesh/partTetMeshSimplex.C ; mpicxx -DIntel -Dlinux64 -DWM_DP -wd327,584,654,819,1125,1476,1505,1572 -ansi-alias -O3 -fno-alias -fp-model precise -fargument-noalias-global -unroll0 -DNoRepository -DUSE_OMP -fopenmp -I/work/02701/ripu/foam/foam-extend-3.2/src/edgeMesh/lnInclude -I/work/02701/ripu/foam/foam-extend-3.2/src/meshTools/lnInclude -IlnInclude -I. -I/work/02701/ripu/foam/foam-extend-3.2/src/foam/lnInclude -I/work/02701/ripu/foam/foam-extend-3.2/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64IccDPOpt/partTetMeshSimplex.o SOURCE=utilities/meshes/partTriMesh/partTriMesh.C ; mpicxx -DIntel -Dlinux64 -DWM_DP -wd327,584,654,819,1125,1476,1505,1572 -ansi-alias -O3 -fno-alias -fp-model precise -fargument-noalias-global -unroll0 -DNoRepository -DUSE_OMP -fopenmp -I/work/02701/ripu/foam/foam-extend-3.2/src/edgeMesh/lnInclude -I/work/02701/ripu/foam/foam-extend-3.2/src/meshTools/lnInclude -IlnInclude -I. -I/work/02701/ripu/foam/foam-extend-3.2/src/foam/lnInclude -I/work/02701/ripu/foam/foam-extend-3.2/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64IccDPOpt/partTriMesh.o SOURCE=utilities/meshes/partTriMesh/partTriMeshAddressing.C ; mpicxx -DIntel -Dlinux64 -DWM_DP -wd327,584,654,819,1125,1476,1505,1572 -ansi-alias -O3 -fno-alias -fp-model precise -fargument-noalias-global -unroll0 -DNoRepository -DUSE_OMP -fopenmp -I/work/02701/ripu/foam/foam-extend-3.2/src/edgeMesh/lnInclude -I/work/02701/ripu/foam/foam-extend-3.2/src/meshTools/lnInclude -IlnInclude -I. -I/work/02701/ripu/foam/foam-extend-3.2/src/foam/lnInclude -I/work/02701/ripu/foam/foam-extend-3.2/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64IccDPOpt/partTriMeshAddressing.o SOURCE=utilities/meshes/partTriMesh/partTriMeshParallelAddressing.C ; mpicxx -DIntel -Dlinux64 -DWM_DP -wd327,584,654,819,1125,1476,1505,1572 -ansi-alias -O3 -fno-alias -fp-model precise -fargument-noalias-global -unroll0 -DNoRepository -DUSE_OMP -fopenmp -I/work/02701/ripu/foam/foam-extend-3.2/src/edgeMesh/lnInclude -I/work/02701/ripu/foam/foam-extend-3.2/src/meshTools/lnInclude -IlnInclude -I. -I/work/02701/ripu/foam/foam-extend-3.2/src/foam/lnInclude -I/work/02701/ripu/foam/foam-extend-3.2/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64IccDPOpt/partTriMeshParallelAddressing.o utilities/meshes/polyMeshGenModifier/polyMeshGenModifierReorderBoundaryFaces.C(224): internal error: null pointer } ^ compilation aborted for utilities/meshes/polyMeshGenModifier/polyMeshGenModifierReorderBoundaryFaces.C (code 4) make: *** [Make/linux64IccDPOpt/polyMeshGenModifierReorderBoundaryFaces.o] Error 4 make: *** Waiting for unfinished jobs.... utilities/meshes/polyMeshGenAddressing/polyMeshGenAddressingCellPoints.C(118): internal error: null pointer } ^ compilation aborted for utilities/meshes/polyMeshGenAddressing/polyMeshGenAddressingCellPoints.C (code 4) make: *** [Make/linux64IccDPOpt/polyMeshGenAddressingCellPoints.o] Error 4 utilities/meshes/polyMeshGenAddressing/polyMeshGenAddressingCellEdges.C(123): internal error: null pointer } ^ utilities/meshes/polyMeshGenAddressing/polyMeshGenAddressingFaceEdges.C(108): internal error: null pointer } ^ utilities/meshes/polyMeshGenAddressing/polyMeshGenAddressingPointPoints.C(120): internal error: null pointer } ^ utilities/meshes/polyMeshGenAddressing/polyMeshGenAddressingCellCells.C(130): internal error: null pointer } ^ compilation aborted for utilities/meshes/polyMeshGenAddressing/polyMeshGenAddressingCellEdges.C (code 4) utilities/meshes/polyMeshGenAddressing/polyMeshGenAddressingEdgeFaces.C(132): internal error: null pointer } ^ make: *** [Make/linux64IccDPOpt/polyMeshGenAddressingCellEdges.o] Error 4 compilation aborted for utilities/meshes/polyMeshGenAddressing/polyMeshGenAddressingFaceEdges.C (code 4) compilation aborted for utilities/meshes/polyMeshGenAddressing/polyMeshGenAddressingPointPoints.C (code 4) compilation aborted for utilities/meshes/polyMeshGenAddressing/polyMeshGenAddressingCellCells.C (code 4) make: *** [Make/linux64IccDPOpt/polyMeshGenAddressingFaceEdges.o] Error 4 make: *** [Make/linux64IccDPOpt/polyMeshGenAddressingPointPoints.o] Error 4 make: *** [Make/linux64IccDPOpt/polyMeshGenAddressingCellCells.o] Error 4 compilation aborted for utilities/meshes/polyMeshGenAddressing/polyMeshGenAddressingEdgeFaces.C (code 4) make: *** [Make/linux64IccDPOpt/polyMeshGenAddressingEdgeFaces.o] Error 4 Any Suggestions? Ripu |
December 2, 2015, 15:26 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Quick question: Which Intel Compiler version are you using? A few examples for finding it out:
mpicxx --version icc --version icpc --version Last edited by wyldckat; December 2, 2015 at 15:26. Reason: rephrased question |
December 2, 2015, 15:49 |
I think Intel compiler 15.0.2
Ripudaman Manchanda
Rep Power: 12 |
Here is the output I get when I check the version.
login1.stampede(1)$ mpicxx --version icpc (ICC) 15.0.2 20150121 Copyright (C) 1985-2015 Intel Corporation. All rights reserved. login1.stampede(2)$ icc --version icc (ICC) 15.0.2 20150121 Copyright (C) 1985-2015 Intel Corporation. All rights reserved. login1.stampede(3)$ icpc --version icpc (ICC) 15.0.2 20150121 Copyright (C) 1985-2015 Intel Corporation. All rights reserved. Ripu |
December 2, 2015, 15:55 |
Bruno Santos
Rep Power: 128 |
Quick answer: OK, then it's one of the recent versions of ICC. Intel provides a non-commercial license to open source contributors and I can have a look into this issue in the coming weekend: https://software.intel.com/en-us/qua...rcecontributor
If anyone wants to check this and solve this before I try to, please do feel free to do so! In the meantime, one workaround would be to use GCC to build only this library. |
December 3, 2015, 11:41 |
Ripudaman Manchanda
Rep Power: 12 |
That sounds great Bruno. Thanks for looking into this.
Ripu |
December 4, 2015, 04:28 |
Hi Ripu,
I do not use Intel compiler and I have not seen this error before. Strangely, the reported errors are at the last line of a function. Can you please try compiling cfMesh without the -fopenmp flag because it may be the cause of the problem. It is not used by the Intel compiler and I am not sure how it gets defined on your machine, because the compiler should not define the __GNUC__ macro. In the cfMesh/Make/options you can find the following: #if defined(__GNUC__) # if defined(darwin) OMP_FLAGS = # else OMP_FLAGS = -DUSE_OMP -fopenmp # endif #else OMP_FLAGS = #endif Please replace this with: #if defined(__GNUC__) # if defined(darwin) OMP_FLAGS = # else OMP_FLAGS = -DUSE_OMP -openmp // intel compiler uses -openmp # endif #else OMP_FLAGS = #endif Intel compiler uses -openmp flag for openmp. If the above does not work, then try compiling without openmp by replacing the above with OMP_FLAGS = Please let me know if any of this solve the problem. Regards, Franjo
Principal Developer of cfMesh and CF-MESH+ www.cfmesh.com Social media: LinkedIn, Twitter, YouTube, Facebook, Pinterest, Instagram |
December 4, 2015, 15:11 |
Solved
Ripudaman Manchanda
Rep Power: 12 |
Franjo,
Changing the -fopenmp to -openmp did not solve the problem but putting OMP_FLAGS = after the if else construct helps in compiling. Thanks for helping with this. I am happy with this now. Ripu |
cfmesh, fe32, foam-extend.3.2 |
courant number increases to rather large values | 6863523 | OpenFOAM Running, Solving & CFD | 22 | July 5, 2023 23:48 |
Stuck in a Rut- interDyMFoam! | xoitx | OpenFOAM Running, Solving & CFD | 14 | March 25, 2016 07:09 |
Floating point exception error | lpz_michele | OpenFOAM Running, Solving & CFD | 53 | October 19, 2015 02:50 |
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 | bookie56 | OpenFOAM Installation | 8 | August 13, 2011 04:03 |
Could anybody help me see this error and give help | liugx212 | OpenFOAM Running, Solving & CFD | 3 | January 4, 2006 18:07 |
