Home > Forums > OpenFOAM Mesh Utilities
Converting a 2Dmesh to axisymmetric
Like Tree10Likes
Old   December 16, 2009, 22:19
Default checkmesh problem
  #61
Eelco Gehring
feijooos is on a distinguished road
Dear Bernhard,
First, let me say that this is a great utility.
Second, I am having a slight problem with the mesh I created using makeAxialMesh and I'm hoping you can help me out.
I made my own 2D mesh which I refined in some places and then converted it to an axisymetric mesh using your utility. It works well, no problem up to this point. However, when I check the Mesh with checkMesh I get a floating point exception error:
Checking patch topology for multiply connected surfaces ...
Patch Faces Points Surface topology
top 360 722 ok (non-closed singly connected)
left 1280 2562 ok (non-closed singly connected)
right 122 246 ok (non-closed singly connected)
bottom 6400 12802 ok (non-closed singly connected)
frontAndBack 0 0 ok (empty)
frontAndBack_pos 847724 855405 ok (non-closed singly connected)
frontAndBack_neg 847724 855405 ok (non-closed singly connected)
Checking geometry...
Overall domain bounding box (0 0 -5.23265e-05) (0.012 0.0024 0.000157047)
#0 Foam::error:rintStack(Foam::Ostream&) in "/usr/local/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libOpenFOAM.so"
#1 Foam::sigFpe::sigFpeHandler(int) in "/usr/local/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libOpenFOAM.so"
#2 __restore_rt at sigaction.c:0
#3 Foam:olyMesh::calcDirections() const in "/usr/local/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libOpenFOAM.so"
#4 Foam:olyMesh::directions() const in "/usr/local/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libOpenFOAM.so"
#5 Foam::checkGeometry(Foam:olyMesh const&, bool) in "/usr/local/OpenFOAM/OpenFOAM-1.5/applications/bin/linux64GccDPOpt/checkMesh"
#6 main in "/usr/local/OpenFOAM/OpenFOAM-1.5/applications/bin/linux64GccDPOpt/checkMesh"
#7 __libc_start_main in "/lib64/libc.so.6"
#8 Foam::regIOobject::readIfModified() in "/usr/local/OpenFOAM/OpenFOAM-1.5/applications/bin/linux64GccDPOpt/checkMesh"
Floating point exception
I was wondering if you have encountered this problem before and if there is a way to fix this?
Thanks,
Eelco
feijooos is offline   Reply With Quote
Old   January 15, 2010, 06:46
Ivan Flaminio Cozza
ivan_cozza is on a distinguished road
Send a message via MSN to ivan_cozza
Hi Foamers!
Is there any issue in compiling makeAxialMesh in OF 1.6.x?
I tried yesterday, everything seemed ok, but when I try to convert my 2D jet mesh, the utility did not collapse the axis faces on a line, but just transformed them in a very tiny face near the x = 0 axis. So when I did collapseEdges, it did not find any edges to collapse. The rest of the mesh seems ok.
Could this axi mesh work correctly (the lateral boundaries are wedge)?
Any comments on it?
Thanks!
Ivan
ivan_cozza is offline   Reply With Quote
Old   March 5, 2010, 18:38
Default checkMesh problem
  #63
Alqayam Meghji
AlMeghji is on a distinguished road
Hi Bernhard,
Thanks a lot for making the makeAxialMesh utility, it has been really helpful for my work.
I have one question, I am getting the same FOAMerror that feijooos is getting. Is there a way to solve this?
I have specified my axis patch to be empty in the files in the 0 directory, could this be a source of the problem? should they be symmetryPlanes?
thanks
al
AlMeghji is offline   Reply With Quote
Old   March 6, 2010, 22:23
Eelco Gehring
Alqayam,
the only way I was able to fix it, was by using the original example provided with the utility and modifying it to my needs. See if that works for you.
Good luck
Old   March 7, 2010, 12:17
Alqayam Meghji
Hi Eelco,
What I have done is that I have run the blockMesh, makeAxialMesh and collapseEdges without a problem.
I then take the new polymesh directory and replace the initial one in the constant directory. I then specify the bottom BCs in the 0dir to be empty.
Is there a problem with this method? or could it be the solver, I am using an altered version of icoFoam that includes temperature effects.
thanks
Al
Old   March 7, 2010, 12:54
Eelco Gehring
Hi Al,
It does not seems like a solver issue when you get the same error. Just to check: you get the error when changing the bottom BC and after you run "checkMesh". And I assume that your bottom boundary is your axis?
Not sure what the problem could be. Are you positive that you apply the collapseEdges to the right directory? Is the collapseEdges utility actually collapsing edges, or doesn't it do anything? Is your axis of symmetry parallel to the XY-plan? I remember that I had some issues with that. Take a look at your mesh in paraview (or any other post-processing tool) and see if you BC are where they are supposed to be.
Eelco
Old   March 8, 2010, 06:10
Assistant Moderator
Bernhard Gschaider
Originally Posted by AlMeghji View Post
Hi Bernhard,
thanks
al
No. No symmetryPlanes. It's hard to tell what might be the problem without a proper stack-trace from a debug-version (with line numbers). But one thing I noticed about feijoos checkMesh-output is:
That means that the mesh is NOT symmetric around the xy-plane (and probably the original mesh wasn't too) which according to the UserGuide chapter 5.2.2 is necessary for wedge-BCs to work
Bernhard
Old   March 8, 2010, 18:45
Alqayam Meghji
Hi Guys, thanks for the quick replies. I had a look at your suggestions and i found something strange.
When i ran makeAxialMesh, it produced a new file, with a polymesh directory in. This is fine as I understand, however when I looked at the boundary file, it still showed the bottom patch (my axis patch) as having a number of faces. I realise that there should be 0 faces there, but how do I fix that? Once that is done then im sure that the mesh will be fine.
Another thing that could be leading to this problem is that when i tried to install makeAxialMesh again, once i had removed it, It said that it could not find repatch.H to add to the makeAxialMesh.dep file. Im guessing that this has a lot to do with redefining the patches.
Is there any way or anywhere i can get this file to put into the OpenFOAM-1.5/src/lnInlcude directory?
when i run collapseEdges I get this:
Collapsing 0 small edges
Collapsing 0 in line edges
Max face area:0.001
Collapse area factor:1e-09
Collapse area:1e-12
Collapsing 0 small high aspect ratio faces
End
When i run the solver i get this:
This mesh contains patches of type empty but is not 1D or 2D
by virtue of the fact that the number of faces of this
empty patch is not divisible by the number of cells.
From function emptyFvPatchField<Type>::updateCoeffs()
in file fields/fvPatchFields/constraint/empty/emptyFvPatchField.C at line 148.
Any ideas??
thanks again for all the help, i really do appreciate it!
Al
Old   March 9, 2010, 06:27
Assistant Moderator
Bernhard Gschaider
MAM doesn't remove any faces it only moves points around. Removing faces is what collapseEdges takes care of
You don't have to. If you look at the sources you'll see that this is a file/class whose name differs between 1.5(6) and 1.5-dev. The stage that makes the dependencies complains about it because it doesn't know about #ifdefs, but compilation will work without problems
Max face area:0.001
Collapse area:1e-12
End
Any ideas??
Al
Make sure
- whether the axis patch really is on the rotation axis (if it isn't the faces won't get an area of 0 and therefor can't be removed - THIS IS A FEATURE)
- try laxer tolerances for collapseEdges
- set the axis patch to something that is NOT empty
Bernhard
Old   March 9, 2010, 17:17
Alqayam Meghji
Hi Bernhard and Eelco,
problem solved, it was a problem with new polyMesh files created and then running collapseEdges in the new folder created by makeAxialMesh.
One more question, I had a graded mesh before but upon running makeAxialMesh and then collapse edges, it seems that the grading has been replaced by a normal grading, is there a way to retain the graded mesh?
many thanks
al
Old   March 15, 2010, 07:10
Assistant Moderator
Bernhard Gschaider
many thanks
The grading shouldn't be touched by makeAxialMesh (it only manipulates one component of the point-coordinates). And I don't think that collapseEdges touches anything except the collapsed points. Could you check again (and have a look after which util the grading went away)?
Bernhard
Old   March 15, 2010, 12:44
Alqayam Meghji
Hi Bernhard,
All is fixed with the mesh now, thanks for helping on all the problems.
speak soon
Al
Old   March 30, 2010, 16:00
Proulx
daniproulx is on a distinguished road
Dear Foamers,
Thanks for the nice makeAxialMesh Utility.
After the use of makeAxialMesh and collapseEdges I check the mesh and I found:
Mesh stats
internal points: 0
faces: 147816
internal faces: 73357
cells: 36880
boundary patches: 8
point zones: 0
face zones: 0
cell zones: 0
Overall number of cells of each type:
hexahedra: 36773
prisms: 107
wedges: 0
pyramids: 0
tet wedges: 0
tetrahedra: 0
polyhedra: 0
Checking topology...
Boundary definition OK.
Point usage OK.
Upper triangular ordering OK.
Face vertices OK.
Number of regions: 1 (OK).
Body 352 705 ok (non-closed singly connected)
OUT 107 216 ok (non-closed singly connected)
inlet 30 61 ok (non-closed singly connected)
upwall 210 422 ok (non-closed singly connected)
axis 0 0 ok (empty)
frontAndBackPlanes 0 0 ok (empty)
frontAndBackPlanes_pos36880 37284 ok (non-closed singly connected)
frontAndBackPlanes_neg36880 37284 ok (non-closed singly connected)
Overall domain bounding box (-6e-09 -7.97787e-17 -0.00609363) (0.4675 0.139567 0.00609363)
Mesh (non-empty, non-wedge) directions (1 1 0)
Mesh (non-empty) directions (1 1 1)
***Number of edges not aligned with or perpendicular to non-empty directions: 96154
<<Writing 74460 points on non-aligned edges to set nonAlignedEdges
Boundary openness (1.60644e-18 1.25692e-15 -4.27586e-14) OK.
Max cell openness = 2.69266e-16 OK.
Max aspect ratio = 67.2073 OK.
Minumum face area = 4.29801e-10. Maximum face area = 8.25687e-05. Face area magnitudes OK.
Min volume = 2.16883e-14. Max volume = 2.61285e-07. Total volume = 0.000395393. Cell volumes OK.
Mesh non-orthogonality Max: 74.9294 average: 20.5823
*Number of severely non-orthogonal faces: 706.
Non-orthogonality check OK.
<<Writing 706 non-orthogonal faces to set nonOrthoFaces
Face pyramids OK.
Max skewness = 0.79991 OK.
Failed 1 mesh checks.
End
What's the problem with the mesh ?
In my new boundary file I found the last frontAndBackPlanes with 0 face. Can I remove it from the file ?
The result with icoFoam are strange!!
Any help ?
daniproulx is offline   Reply With Quote
Old   March 30, 2010, 18:20
sega's Avatar
Sebastian Gatzka
sega is on a distinguished road
The frontAndBackPlanes become the "new" wedge face.
Schrödingers wife: "What did you do to the cat? It's half dead!"
sega is offline   Reply With Quote
Old   March 31, 2010, 06:18
Assistant Moderator
Bernhard Gschaider
Which means: "Yes. You can remove the empty patches from the boundary-file" (but don't forget to adapt the number that indicates the length of the list)
Old   March 31, 2010, 18:45
Proulx
Thanks ! But what about the Failed 1 mesh checks ??
Old   April 1, 2010, 10:20
Unhappy
  #77
maddalena's Avatar
maddalena
maddalena is on a distinguished road
Hello FOAMers,
I am having the same troubles as someone else on this thread. After importing a 3D axisymmetric mesh from Pointwise (5° angle, 1 cell thick), I have this error:
    Overall domain bounding box (0 -81.5683 0) (2700 81.5683 1868.22)
    Mesh (non-empty, non-wedge) directions (1 0 1)
 ***Number of edges not aligned with or perpendicular to non-empty directions: 10914
  <<Writing 11207 points on non-aligned edges to set nonAlignedEdges
What is going wrong? Any suggestions?
mad
maddalena is offline   Reply With Quote
Old   April 12, 2010, 08:00
Javed
Javed is on a distinguished road
Hi Bernhard,
I am trying to generate axisymmetric geom with the following blockMeshDict file:
convertToMeters 0.1;
vertices
(0 0 0)
(1 0 0)
(1 1 0)
(0 1 0)
(0 0 0.1)
(1 0 0.1)
(1 1 0.1)
(0 1 0.1)
blocks
hex (0 1 2 3 0 1 6 7) (20 20 1) simpleGrading (1 1 1)
edges
patches
wall fixed
(3 7 6 2)
patch inlet
(0 0 7 3)
patch outlet
(2 6 1 1)
empty center
(1 1 0 0)
wedge frontAndBack
(0 3 2 1)
(0 1 6 7)
mergePatchPairs
but not able to run blockMesh..getting following error..Please help
Create time
Creating block mesh from
"/home/javed/OpenFOAM/javed-1.6/run/wedge/constant/polyMesh/blockMeshDict"
ill defined primitiveEntry starting at keyword 'patches' on line 41 and ending at line 70
file: /home/javed/OpenFOAM/javed-1.6/run/wedge/constant/polyMesh/blockMeshDict at line 70.
From function primitiveEntry::readEntry(const dictionary&, Istream&)
in file db/dictionary/primitiveEntry/primitiveEntryIO.C at line 210.
FOAM exiting
PLEASE HELP.
Javed is offline   Reply With Quote
Old   April 12, 2010, 08:09
sega's Avatar
Sebastian Gatzka
Originally Posted by Javed View Post
empty center
(1 1 0 0)
Try this.
empty center
    (1 1 0 0)
Old   April 12, 2010, 08:35
Javed
Thanks, but after correcting it i m getting following error
Create time
Creating blockCorners
Creating curved edges
Creating blocks
Creating patches
Creating block mesh topology
Default patch type set to empty
#0 Foam::error:rintStack(Foam::Ostream&) in "/home/javed/OpenFOAM/OpenFOAM-1.6/lib/linuxGccDPOpt/libOpenFOAM.so"
#1 Foam::sigFpe::sigFpeHandler(int) in "/home/javed/OpenFOAM/OpenFOAM-1.6/lib/linuxGccDPOpt/libOpenFOAM.so"
#2 Uninterpreted:
#3 Foam::wedgePolyPatch::initTransforms() in "/home/javed/OpenFOAM/OpenFOAM-1.6/lib/linuxGccDPOpt/libOpenFOAM.so"
#4 Foam::wedgePolyPatch::wedgePolyPatch(Foam::word const&, int, int, int, Foam:olyBoundaryMesh const&) in "/home/javed/OpenFOAM/OpenFOAM-1.6/lib/linuxGccDPOpt/libOpenFOAM.so"
#5 Foam:olyPatch::addwordConstructorToTable<Foam::w edgePolyPatch>::New(Foam::word const&, int, int, int, Foam:olyBoundaryMesh const&) in "/home/javed/OpenFOAM/OpenFOAM-1.6/lib/linuxGccDPOpt/libOpenFOAM.so"
#6 Foam:olyPatch::New(Foam::word const&, Foam::word const&, int, int, int, Foam:olyBoundaryMesh const&) in "/home/javed/OpenFOAM/OpenFOAM-1.6/lib/linuxGccDPOpt/libOpenFOAM.so"
#7 Foam:olyMesh:olyMesh(Foam::IOobject const&, Foam::Xfer<Foam::Field<Foam::Vector<double> > > const&, Foam::List<Foam::cellShape> const&, Foam::List<Foam::List<Foam::face> > const&, Foam::List<Foam::word> const&, Foam::List<Foam::word> const&, Foam::word const&, Foam::word const&, Foam::List<Foam::word> const&, bool) in "/home/javed/OpenFOAM/OpenFOAM-1.6/lib/linuxGccDPOpt/libOpenFOAM.so"
#8 Foam::blockMesh::createTopology(Foam::IOdictionary &) in "/home/javed/OpenFOAM/OpenFOAM-1.6/applications/bin/linuxGccDPOpt/blockMesh"
#9 Foam::blockMesh::blockMesh(Foam::IOdictionary&) in "/home/javed/OpenFOAM/OpenFOAM-1.6/applications/bin/linuxGccDPOpt/blockMesh"
#10 main in "/home/javed/OpenFOAM/OpenFOAM-1.6/applications/bin/linuxGccDPOpt/blockMesh"
#11 __libc_start_main in "/lib/tls/i686/cmov/libc.so.6"
#12 _start at /usr/src/packages/BUILD/glibc-2.9/csu/../sysdeps/i386/elf/start.S:122
Thread Tools
Trackbacks are On
Converting RANS solver into LES Chiara Main CFD Forum 5 February 19, 2009 10:36
converting user-coding in V4 Karl Mehler CD-adapco 0 September 28, 2008 15:48
Converting objects shuo OpenFOAM 1 November 6, 2006 17:51
Converting 2D mesh to 3D Farooq FLUENT 1 August 7, 2003 05:03
Converting from tecplot to gmv format Charles Crosby Main CFD Forum 0 May 7, 2003 15:02
