Home > Forums > OpenFOAM Mesh Utilities
Converting a 2Dmesh to axisymmetric
Like Tree10Likes
Old   April 12, 2010, 08:40
sega's Avatar
Sebastian Gatzka
sega is on a distinguished road
Originally Posted by Javed View Post
Thanks, but after correcting it i m getting following error
You can't use a wedge type on a non-wedge mesh.
Alter your points so they will form the wedge and than you can use the wedge type.
Schr÷dingers wife: "What did you do to the cat? It's half dead!"
sega is offline   Reply With Quote
Old   April 12, 2010, 08:57
Javed
Javed is on a distinguished road
Sir, I wil be grateful if u explain in details, how to form wedge from the given points?
Thanks
Javed is offline   Reply With Quote
Old   April 12, 2010, 08:59
sega's Avatar
Sebastian Gatzka
Thanks
Have a look at the user guide.
http://www.openfoam.com/docs/user/bo...hp#x24-1370014
Old   April 12, 2010, 13:17
Assistant Moderator
Bernhard Gschaider
Hi Bernhard,
I am trying to generate axisymmetric geom with the following blockMeshDict file:
convertToMeters 0.1;
<snip>
ill defined primitiveEntry starting at keyword 'patches' on line 41 and ending at line 70
file: /home/javed/OpenFOAM/javed-1.6/run/wedge/constant/polyMesh/blockMeshDict at line 70.
From function primitiveEntry::readEntry(const dictionary&, Istream&)
in file db/dictionary/primitiveEntry/primitiveEntryIO.C at line 210.
FOAM exiting
PLEASE HELP.
This is NOT a problem with the utility this thread is about. I won't answer further unrelated questions.
There is a '(' missing at "empty center". Use a text editor that displays matching Parenthesis (Emacs for instance) that helps to spot such problems
lth likes this.
Old   April 13, 2010, 03:59
Javed
Sir,,
I am sorry for disturbing u in another thread.
I didn't get anyother thread where i can put my query regarding axisymmetric geometry.
It will be great if u plz let help me for the following pbm..
I have developed the axisymmetric pbm with follwoing blockMesh file..
blocks
hex (0 1 2 3 0 1 6 7) (20 20 1) simpleGrading (1 1 1)
edges
patches
wall fixed
(3 7 6 2)
patch inlet
(0 0 7 3)
patch outlet
(2 6 1 1)
empty center
(1 1 0 0)
wedge front
(0 3 2 1)
wedge back
(0 1 6 7)
but getting follwoing error..
Creating block mesh from
"/home/javed/OpenFOAM/javed-1.6/run/wedge-new/constant/polyMesh/blockMeshDict"
Creating blockCorners
Creating curved edges
Creating blocks
Creating patches
Creating block mesh topology
Default patch type set to empty
#0 Foam::error:rintStack(Foam::Ostream&) in "/home/javed/OpenFOAM/OpenFOAM-1.6/lib/linuxGccDPOpt/libOpenFOAM.so"
#1 Foam::sigFpe::sigFpeHandler(int) in "/home/javed/OpenFOAM/OpenFOAM-1.6/lib/linuxGccDPOpt/libOpenFOAM.so"
#2 Uninterpreted:
#3 Foam::wedgePolyPatch::initTransforms() in "/home/javed/OpenFOAM/OpenFOAM-1.6/lib/linuxGccDPOpt/libOpenFOAM.so"
#4 Foam::wedgePolyPatch::wedgePolyPatch(Foam::word const&, int, int, int, Foam:olyBoundaryMesh const&) in "/home/javed/OpenFOAM/OpenFOAM-1.6/lib/linuxGccDPOpt/libOpenFOAM.so"
#5 Foam:olyPatch::addwordConstructorToTable<Foam::w edgePolyPatch>::New(Foam::word const&, int, int, int, Foam:olyBoundaryMesh const&) in "/home/javed/OpenFOAM/OpenFOAM-1.6/lib/linuxGccDPOpt/libOpenFOAM.so"
#6 Foam:olyPatch::New(Foam::word const&, Foam::word const&, int, int, int, Foam:olyBoundaryMesh const&) in "/home/javed/OpenFOAM/OpenFOAM-1.6/lib/linuxGccDPOpt/libOpenFOAM.so"
#7 Foam:olyMesh:olyMesh(Foam::IOobject const&, Foam::Xfer<Foam::Field<Foam::Vector<double> > > const&, Foam::List<Foam::cellShape> const&, Foam::List<Foam::List<Foam::face> > const&, Foam::List<Foam::word> const&, Foam::List<Foam::word> const&, Foam::word const&, Foam::word const&, Foam::List<Foam::word> const&, bool) in "/home/javed/OpenFOAM/OpenFOAM-1.6/lib/linuxGccDPOpt/libOpenFOAM.so"
#8 Foam::blockMesh::createTopology(Foam::IOdictionary &) in "/home/javed/OpenFOAM/OpenFOAM-1.6/applications/bin/linuxGccDPOpt/blockMesh"
#9 Foam::blockMesh::blockMesh(Foam::IOdictionary&) in "/home/javed/OpenFOAM/OpenFOAM-1.6/applications/bin/linuxGccDPOpt/blockMesh"
#10 main in "/home/javed/OpenFOAM/OpenFOAM-1.6/applications/bin/linuxGccDPOpt/blockMesh"
#11 __libc_start_main in "/lib/tls/i686/cmov/libc.so.6"
#12 _start at /usr/src/packages/BUILD/glibc-2.9/csu/../sysdeps/i386/elf/start.S:122
Floating point exception
Thanks for the help...
Old   April 13, 2010, 05:21
sega's Avatar
Sebastian Gatzka
Open you own.
We have misused this thread.
Sorry
Old   April 29, 2010, 02:21
Question checkMesh Error when using "axis offset"
  #87
bengt is on a distinguished road
Dear Foamers,
I'd like to resume this thread and come back to the checkMesh error "Failed 1 mesh checks" which had been previously reported with cases where the axis is not aligned with the patch (axis offset feature). For example:
***Number of edges not aligned with or perpendicular to non-empty directions: 96154
<<Writing 74460 points on non-aligned edges to set nonAlignedEdges
I've got the same problem with a concentric cylinder set-up where the inner cylinder rotates and the outer is fixed (Taylor-Couette system with fluid-filled ring gap).
Do we have to use the collapseEdges utility with such cases (in my case collapseEdges doesn't seem to do anything and the checkMesh issue persists), or can the mesh be used "as is" after using makeAxialMesh??
I'd greatly appreciate any help!
Have a nice day
Bengt
bengt is offline   Reply With Quote
Old   July 14, 2010, 11:55
Angry
  #88
Abdel
bruxellois4 is on a distinguished road
I don't think that MakeAxialMesh works with openFOam 1.7.
I have to simulate a barrel of a gun, as you can see in screen shots (attachments), i have one cell thick in y i direction, but in my boundary file i don't see how to define a wedge, SO has an idea, help plzz
13
tube5
type wall;
nFaces 30;
startFace 60334;
tube4
type wall;
nFaces 3;
startFace 60364;
FREIN3
type wall;
nFaces 70;
startFace 60367;
FREIN2
type wall;
nFaces 15;
startFace 60437;
FREIN1
type wall;
nFaces 30;
startFace 60452;
Frein
type wall;
nFaces 20;
startFace 60482;
Pressure_inlet
type patch;
nFaces 30;
startFace 60502;
Tube3
type wall;
nFaces 21;
startFace 60532;
Tube2
type wall;
nFaces 10;
startFace 60553;
Tube1
type wall;
nFaces 139;
startFace 60563;
Axe
type symmetryPlane;
nFaces 215;
startFace 60702;
Pressure_outlet
type patch;
nFaces 209;
startFace 60917;
frontAndBackPlanes
type empty;
nFaces 60730;
startFace 61126;
bruxellois4 is offline   Reply With Quote
Old   July 14, 2010, 17:25
Abdel
Greetings,
Help please, you can see my problem here (7th post)
*.msh conversion + axissymetric problem
Abdel.
Old   July 29, 2010, 09:00
Default Simulation results
  #90
Bernard Esterhuyse
bernarde is on a distinguished road
Hi all
First of all thanks to Bernhard for the great utility.
Have have been using it a bit in order to get a 2D axisymmetrc simulation running. I started off with the example included in the utility, and modified it a bit. I added an outlet, and added a slight inflow into the domain. The model is based on this concept:
Flow enters the domain tangentially and exits axially. The flow is thus axisymmetric, and I'm just modelling a section of it.
I'm using the IcoFoam solver, and the solution converges well. However, the results don't look right. See below:
It seems the flow is exiting the domain with almost no swirl. It also seems the inlet swirl is quickly dissipated. I'm quite sure this is not correct, since there is quite a lot of angular momentum introduced at the inlet, and this momentum must be conserved. I would expect the outlet flow to still have a lot of swirl.
Can anybody suggest any ideas?
bernarde is offline   Reply With Quote
Old   August 3, 2010, 09:53
Assistant Moderator
Bernhard Gschaider
Originally Posted by bernarde View Post
Hi all
Have you checked whether what paraFoam shows you is consistent with what is on the disk. At least for older versions (havn't done wedges since) for glyphs the component "out of the wedge" was removed. What you had to do was use the "Cell Centers"-filter (then you saw nothing) and for that result use "Glyphs" (due to the small picture I'm not 100% sure whether there is a flow "out of the wedge" outside of the Inlet, so this might be not too helpful)
Bernhard
Old   December 5, 2010, 23:58
Sunny Karnani
skarnani is on a distinguished road
Hi Bengt,
I've run in to this same issue as well. I'm beginning to think that this is an accepted issue. If you look at the tutorial ~/OpenFOAM/sunny-1.6.x/run/tutorials/multiphase/interFoam/les/nozzleFlow2D which also uses an axisymmetric mesh, the same error shows up when you run checkMesh. Whether or not that makes it OK, I'm not sure, but at least it is clear that the provided tutorials have the same issue.
Sunny
skarnani is offline   Reply With Quote
Old   December 10, 2010, 10:22
Post
  #93
Matthias Vo▀
mvoss is on a distinguished road
hi,
is there a solution for the problem by which makeAxialMesh isn┤t running if there are any libs or functions in the controlDict?
Regarding the groovyBC and the simpleFunctionObjects...
neewbie
mvoss is offline   Reply With Quote
Old   December 14, 2010, 05:44
Assistant Moderator
Bernhard Gschaider
Originally Posted by neewbie View Post
hi,
neewbie
The problem is that makeAxialMesh only loads the mesh as a polyMesh (it doesn't need more for what it has been doing) while most functionObjects need a fvMesh. The quickest solution is to go to the controlDict, comment out the functions and the libs entry, run MAM and then restore the controlDict to its old glory. Or if you have pyFoam installed run it like this
pyFoamRunner.py --remove-libs --remove-functions makeAxialMesh
which does the editing/restoring for you.
OR there is the possibility to turn of the functionObjects in the source code of the utility (but I'll have to look that up, maybe will do it, but you'll probably need a solution right now)
Bernhard
Old   December 14, 2010, 05:47
Matthias Vo▀
thanks,
this is exactly as i did.
Some mv and cp in a startscript did the job.
neewbie
Old   January 4, 2011, 12:37
Matthias Vo▀
btw...
can makeAxialMesh be used for multipleRegion meshes?
neewbie
Old   January 5, 2011, 04:02
Matthias Vo▀
sorry...
i┤ve started a new thread on this...
Old   February 11, 2011, 17:32
Default does this work for foam 1.7
  #98
William
billynoe is on a distinguished road
I have been trying to make axisymmetric geometry the documentation says this utility is for V1.4 and 1.5. I am using V1.7. has anyone tried this in 1.7 before I put too much effort into altering my geometry.
billynoe is offline   Reply With Quote
Old   June 30, 2011, 19:16
Default conversion 2Dmesh to axisymmetric
  #99
hameurlaine
louiza is on a distinguished road
Hi everyone,
I imported my mesh (generate in fluent) file to a FOAM mesh successfully using fluentMeshToFoam command.
and I would Converting a 2Dmesh to axisymmetric, I downlowd the makeAxialMesh and it's compiling successfuly.
my question:What are the other commands to perform the conversion?
I found the answer in a forum on the link, but it's removed"Contrib MakeAxialMesh - OpenFOAMWiki"
I work OpenFoam 1.7.1 under UBUNTO
thank you for your help
louiza is offline   Reply With Quote
Old   July 1, 2011, 00:32
Assistant Moderator
Bernhard Gschaider
Originally Posted by louiza View Post
Hi everyone,
What do you mean with "it's removed". Don't know the posing you're referring to, but checking with
http://lmgtfy.com/?q=openfoamwiki+makeaxialmesh&l=1
gives the right page
Bernhard
Thread Tools
Trackbacks are On
Converting RANS solver into LES Chiara Main CFD Forum 5 February 19, 2009 10:36
converting user-coding in V4 Karl Mehler CD-adapco 0 September 28, 2008 15:48
Converting objects shuo OpenFOAM 1 November 6, 2006 17:51
Converting 2D mesh to 3D Farooq FLUENT 1 August 7, 2003 05:03
Converting from tecplot to gmv format Charles Crosby Main CFD Forum 0 May 7, 2003 15:02
