[snappyHexMesh] Geometry Generation In SnappyHexMeshDict
Old   January 20, 2009, 12:31
Default Geometry Generation In SnappyHexMeshDict
Henrik Rusche
henrik is on a distinguished road
Hi Christian,
in the OF-spirit, the searchable objects are runtime-selectable. Therefore you can create your own, e.g. truckGroup, and link it to the mesh generator at runtime. truckGroup would then read a list of position out of the dictionary.
Alternative, if this stretches your C++ knowledge, I would suggest to use the m4 macro-preprocessor.
Henrik
henrik is offline   Reply With Quote
Old   January 21, 2009, 05:39
Default Hello Henrik, you are right
Christian Trapp
chtrapp is on a distinguished road
Hello Henrik,
you are right, this would be a very good starting point to get into coding my own extensions, since I'm sure that this is a rather simple problem. The m4 option looks to me like the least comfortable solution because as far as I understand m4, getting it to support loops takes some effort.
Anyway, I've heard a rumor that tools for grouping/ replicating geometries in the snappyHexMeshDict have been implemented but not yet documented.
Thanks for your advice, Christian
chtrapp is offline   Reply With Quote
Running CFD parallel. There is no geometry file! CrashLaker SU2 6 April 10, 2014 03:08
Geometry and mesh generation in OpenFoam pokeng OpenFOAM Pre-Processing 1 October 28, 2011 21:40
3d geometry mesh generation mach13 ANSYS Meshing & Geometry 10 September 10, 2009 11:03
Simulation of Flow through Complex 3D Geometry EmersonKB CFX 5 July 2, 2009 08:17
Latest new in mesh generation Robert Schneiders Main CFD Forum 0 February 16, 2000 07:12
