[Salome] ideasUnvToFoam gives no result
Like Tree1Likes
  • 1 Post By Dazzler
Old   November 27, 2012, 09:54
Default ideasUnvToFoam gives no result
Romain
nakor is on a distinguished road
I usually use snappyHexMesh so I am not used to converting mesh, but I wanted to try.
I used Salomé for my mesh. Once it was done, I exported it in unv format.
After that, I tried 'ideasUnvToFoam Mesh3DSalome.unv' and the output was :
Create time
Sorting boundary faces according to group (patch)
Constructing mesh with non-default patches of size:
End
It did not created any mesh in 'openfoam'
My mesh seems correct as I can import it back into Salomé and it gives me the following informations :
Do you have any ideas on what I am doing wrong ?
Thanks,
Romain
nakor is offline   Reply With Quote
Old   November 27, 2012, 10:47
Darren
Dazzler is on a distinguished road
You will find many references to this problem if you do a a search - the header in the UNV file exported by Salome is incorrect. The 2nd line which says 164 should have 3 spaces before the number - not 2
nakor likes this.
Dazzler is offline   Reply With Quote
Old   November 27, 2012, 11:02
Romain
Thanks, it worked perfectly.
On another point, with multi region meshes, when I use splitMesh it does not create automatically patches between two differents regions (like domain1_to_domain2).
Is there any way to create them automatically or should I specify all of them inside Salomé ?
Thanks,
Romain
edit : ok, solve it, I just had to use 'partition' and not compound for my assemblies of the different objects.
[Salome] ideasUnvToFoam Error: Assertion `nouveau > -1' failed GerhardHolzinger OpenFOAM Meshing & Mesh Conversion 0 January 29, 2019 10:23
how use the result data as initial data n4a0505 OpenFOAM Post-Processing 1 March 4, 2015 02:01
how to make analysis from the result in fluid flow (CFX) ansys workbench 14 wan11 CFX 3 December 18, 2014 19:25
Result output chart YaX CFX 4 July 10, 2014 18:47
Comparison the airfoil 0012 experimental result and simulation result harrislcy FLUENT 30 August 29, 2013 10:27
