Home > Forums > OpenFOAM Mesh Utilities
SnappyHexMesh in parallel openmpi
Old   October 14, 2008, 07:18
Default Lately I have several times be
Niklas Wikstrom
wikstrom is on a distinguished road
Lately I have several times been running into the followin problem. It is repeatable with the same case on two different hardware archs and with icc and gcc compilers:
During Shell refinement iteration (>1) an MPI-error occur:
[dagobah:01576] *** An error occurred in MPI_Bsend
[dagobah:01576] *** on communicator MPI_COMM_WORLD
[dagobah:01576] *** MPI_ERR_BUFFER: invalid buffer pointer
[dagobah:01576] *** MPI_ERRORS_ARE_FATAL (goodbye)
Here is the complete case
snappyHexMesh-coarse.tgz
To run:
blockMesh
decomposePar
foamJob -p -s snappyHexMesh
I do not know if this is to be regarded a bug, or if it's only me...
Cheers
Niklas
wikstrom is offline   Reply With Quote
Old   October 14, 2008, 07:24
Default its just you http://www.cfd-on
niklas's Avatar
Niklas Nordin
niklas will become famous soon enoughniklas will become famous soon enough
its just you
OK I also get that error.
Niklas
(maybe its a username issue)
niklas is offline   Reply With Quote
Old   October 16, 2008, 03:05
Default Have you tried 1.5.x? If it do
Mattijs Janssens
mattijs is on a distinguished road
Have you tried 1.5.x? If it does not work in that one please report as a bug.
mattijs is offline   Reply With Quote
Old   October 17, 2008, 04:35
Default I am running recent pull of 1.
Niklas Wikstrom
I am running recent pull of 1.5.x. Reporting bug!
Thanks for testing and great suggestions Niklas! Actually changed my irl name to Bob The Builder and now everything works fine! :-)
Thanks Niklas and Mattijs
Old   October 21, 2008, 17:38
Default Hi I also face this error
mohd mojab
mou_mi is on a distinguished road
Hi
I also face this error in snappyhexmesh parallel run?
Would you tell me how and where I can change my name according to what Niklas said?
Thank you
mou
mou_mi is offline   Reply With Quote
Old   November 18, 2008, 12:31
Default Hi, I have the same problem
Attila Schwarczkopf
schwarczi is on a distinguished road
I have the same problem that you described above in connetion with parallel meshing (blockMesh ->
decomposePar -> snappyHexMesh in package version 1.5)
My geometry was built up from several STL files, let's say 20. If I use only 19 parts, everything works fine, I have no problem. But when I used all the 20, I used to get that [MPI_ERRORS_ARE_FATAL...] message and SnappyHexMesh crashed again and again.
I tried to divide the task between the processors many different ways, different memory settings, etc. I checked the user names - as you suggested -, and made the meshing process ran with different users/root. Sorry, nothing has helped. I dublechecked the STL files, too, and used different combinations, the case is the same, when all of them are included the meshing crashes.
Do you have any good idea? Is it a bug? Or the problem is by MPI itself?
Thanks in advance,
Schwarczi
schwarczi is offline   Reply With Quote
Old   November 18, 2008, 15:39
Default Make sure your MPI_BUFFER_SIZE
Mattijs Janssens
Make sure your MPI_BUFFER_SIZE is plenty big, 200000000 or larger. Also check on your nodes that you are not running out of memory altogether.
Old   November 24, 2008, 10:52
Default Mattijs, Thank you very muc
Attila Schwarczkopf
Mattijs,
Thank you very much, your advice has been absolutely useful. Extending [MPI_BUFFER_SIZE] has helped me solve the [MPI_ERRORS_ARE_FATAL...] problem described in my last post.
Thanks,
Sch.
Thread Tools
Trackbacks are On
SnappyHexMesh in Parallel bastil OpenFOAM Mesh Utilities 22 April 7, 2010 11:48
Parallel case setup boundry conditions snappyhexmesh oskar OpenFOAM Pre-Processing 5 September 11, 2009 01:12
SnappyHexMesh in parallel openmpi wikstrom OpenFOAM Bugs 18 November 26, 2008 06:55
OpenMPI performance vega OpenFOAM Running, Solving & CFD 13 November 27, 2007 02:28
Cant run in parallel on two nodes using OpenMPI CHristofer Main CFD Forum 0 October 26, 2007 09:54
