[snappyHexMesh] SnappyhexMesh and Symmetryplane
Old   September 2, 2008, 02:46
Default SnappyhexMesh and Symmetryplane
BastiL
bastil is on a distinguished road
Hi Group,
I have problems with a case with symmetry in snappyHexMesh. My geometry has free edges at the symmetry (y=0). These edges are exactly at the border of the initial hex-mesh created by blockMesh. SnappyHexMesh stands at:
Surface refinement iteration 5
Marked for refinement due to surface intersection : 2816 cells.
How to overcome this?
bastil is offline   Reply With Quote
Old   September 2, 2008, 04:02
Default Make your surface extend beyon
Mattijs Janssens
mattijs is on a distinguished road
Make your surface extend beyond the symmetry plane. Does the mesher hang? If so please create a testcase and file a bug report (in OpenFOAM-bugs).
mattijs is offline   Reply With Quote
Old   September 2, 2008, 07:18
Default Yes, the mesher hangs. I can g
BastiL
Yes, the mesher hangs. I can get a mesh if I stay with refinements below level 5 everything works fine. As soon as my level gets 5 or greater the mesher hangs at Surface Refinement Iteration 5.
Old   September 2, 2008, 07:57
Default If I mirror my triSurface but
BastiL
If I mirror my triSurface but leave the initial Hex-Mesh as it is I still have the same problems. I do not think it is related to this. I saw the tutorial has the same free edge situation at tyre contact patch.
Creating testcase is difficult - how can I find out why and where the mesher is hanging?
Thanks
Old   September 3, 2008, 13:34
Default I see I can get closer to the
BastiL
I see I can get closer to the problematic areas by fitting refinement regions. Some regions of my geometry make the mesher hang up if going finer than level 4, others when going finer than level 5. Others have no problem... Process is quite slow - are there quicker ways to find problems?
Regards
Old   September 4, 2008, 04:27
Default when it's hanging: gdb -pid XX
Mattijs Janssens
when it's hanging: gdb -pid XXXX
where XXXX is the pid of snappyHexMesh (printed in the header actually)
Inside gdb type 'where' and whatever else you normally do inside a debugger. Continue a bit ('cont' command?) and ctrl-C and see where you are now. Inside same loop?
You might want to compile autoMesh and snappyHexMesh with -DFULLDEBUG -g -O0 to get some more interesting info.
Old   September 4, 2008, 06:34
Default Please be aware that the meshe
Eugene de Villiers
eugene is on a distinguished road
Please be aware that the mesher uses quite a bit of memory at the moment - somewhere around 3GB/million cells. This will go down in future, but for the time being it is very easy to run out of memory and for the machine to start swapping. You can work around this by running the meshing in parallel or installing more memory.
eugene is offline   Reply With Quote
Old   September 4, 2008, 07:15
Default Eugene, thanks for this hin
BastiL
Eugene,
thanks for this hint. I was aware of that and I am definitely not running out of memory nor swapping.
Refiner is obviously hanging at certain parts of the surface. How can I find out more about the problems? I tried debug=1 but without any success.
Old   September 4, 2008, 07:56
Default Follow Mattijs' instructions a
Eugene de Villiers
Follow Mattijs' instructions and then when it hangs, you can hook gdb into the running process to find out where it is stuck:
gdb snappHexMesh PID
where
Old   September 4, 2008, 11:21
Default Thanks Matthijs, Eugene. th
BastiL
the mesher stands at the same position after waiting for about half an hour:
(gdb) where
#0 0x00002b3e3005a130 in Foam::List<foam::pointindexhit<foam::vector<double > > >::setSize ()
from /home/brblo/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libautoMesh.so
#1 0x00002b3e3271f51d in Foam::triSurfaceMesh::findLineAll () from /home/brblo/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libmeshTools.so
#2 0x00002b3e3004f453 in Foam::refinementSurfaces::findAllHigherIntersectio ns ()
#3 0x00002b3e3004794d in Foam::meshRefinement::markSurfaceCurvatureRefineme nt ()
#4 0x00002b3e30049188 in Foam::meshRefinement::refineCandidates ()
#5 0x00002b3e2ffd6cd0 in Foam::autoRefineDriver::surfaceOnlyRefine ()
#6 0x00002b3e2ffd945f in Foam::autoRefineDriver::doRefine () from /home/brblo/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libautoMesh.so
#7 0x0000000000406036 in main ()
Old   October 7, 2008, 17:07
Default I have made some progress with
  #11
BastiL
I have made some progress with that. I am able to work patch-wise now due to better Hypermesh import (thanks) and this helps a lot. So far I found two patches that makes snappyhexmesh hanging if level is larger than 4 (but there must be some more in this geometry). These patches are direct neighboors. Additionally, they are in close proximity to the bounding box of the initial hex-mesh. Maybe this is a problem. I will go on with this problem.
[snappyHexMesh] symmetryPlane in sHM Tobi OpenFOAM Meshing & Mesh Conversion 6 April 25, 2017 09:19
[snappyHexMesh] snappyHexMesh - geometry does not appear in Mesh czhongrong OpenFOAM Meshing & Mesh Conversion 1 January 20, 2016 05:26
[snappyHexMesh] snappyHexMesh makes strange things batta31 OpenFOAM Meshing & Mesh Conversion 9 February 5, 2013 11:15
[snappyHexMesh] snappyHexMesh not refining surfaces Hydro1004 OpenFOAM Meshing & Mesh Conversion 3 August 29, 2012 11:56
[snappyHexMesh] snappyHex: halfmodel with BL and symmetryPlane Rene OpenFOAM Meshing & Mesh Conversion 1 April 30, 2009 05:57
