[mesh manipulation] ScalePoints tool
Old   September 18, 2008, 10:42
Default ScalePoints tool
Cedric DUPRAT
cedric_duprat is on a distinguished road
I'm looking for the "scalePoints" tool. In the user guide for OF 1.3, there is this tool which is suppose to "scale the mesh points in a polyMesh directory by a factor supplied as an argument".
I can't find it on OF 1.4.1 in the manipulation mesh directory.
This tool is not in OF 1.5.
So, is there a similar tool in OF 1.4.1 ? or maybe someone know how to do such thing whithout doing it by hand.
Thanks in advance,
Cedric
PS: I found a tool called "deformedGeom" but, it's using a displacement field U and after a few try, it doesn't seem to be effective for what I want to do.
cedric_duprat is offline   Reply With Quote
Old   September 18, 2008, 12:11
Default Hi Cedric, Try transformPoi
Håkan Nilsson
hani is on a distinguished road
Hi Cedric,
Try transformPoints
Håkan
hani is offline   Reply With Quote
Old   September 18, 2008, 12:27
Default Hi Hakan, Thank you, It's w
Cedric DUPRAT
Hi Hakan,
Thank you, It's woking fine
... I had an old user-guide ....
maybe it's time to print a new one :-)
Cedric
Old   September 18, 2008, 12:43
Default Hi Cedric, I'm afraid that
Håkan Nilsson
Hi Cedric,
I'm afraid that you should not rely too much on the UserGuide. It is not updated as fast as the code. For transformPoints, I think that it was mentioned in the release notes. At least I'm sure that you can find the answer already in the Forum.
Håkan
Old   September 18, 2008, 12:53
Default Thank you again, You're rig
Cedric DUPRAT
Thank you again,
You're right about the UserGuide but ... as I used to say, it's better than nothing :-)
And in the forum, I just found the same question from a 2005 thread by .... you that's why you are so sure :o)
http://www.cfd-online.com/OpenFOAM_D....html#POST4137
Thanks again,
Cedric
Old   September 18, 2008, 13:15
Default Cedric, I hope that you und
Håkan Nilsson
Cedric,
I hope that you understand that this means that you must help someone else with this question in three years :-)
This is what the Forum is all about.
Håkan.
Old   September 19, 2008, 03:15
Default :-) ok, I'll try not to for
Cedric DUPRAT
ok, I'll try not to forget ...
let's check in 3 years
Cedric
Tool to convert OpenFoam mesh to SU2 mesh (2D and 3D) Combas SU2 44 March 12, 2024 00:35
Literature search tool and database jola Main CFD Forum 0 December 4, 2016 13:56
[ICEM] align vertices tool jumpmonkey ANSYS Meshing & Geometry 2 September 12, 2016 09:37
Tool to download: SU2 post-processing Combas SU2 2 June 5, 2014 14:55
Modeling of a Forging Tool. hydro CFX 1 May 19, 2010 18:35
