Is there a way to get sn
Is there a way to get snappyHexMesh to follow sharp edges? I have meshed a geometry however patch boundaries become irregular, which is causing problems in the solution. The attached image hopefully makes it clearer. http://www.cfd-online.com/OpenFOAM_D...ges/1/8845.jpg I would like to get this to work, otherwise I'll have to go back to another mesher. Cheers, Andrew |
Just a little question: are th
Just a little question: are there advantages to snap hex to mesh instead of creating polygons which would better fit the immersed object ?
Actually, I should explain my
Actually, I should explain my diagram a bit better. The red and blue patches actually do line up (I moved one so that the join can be seen) the problem are the non flat faces in the red patch.
To answer your question - I use snappyHexMesh as it generally gives a very well behaved mesh, and is (very) easy to set up for complex geometries (stl surfaces). Prior to this I have generally used netget/gmsh. I have tried to use polyDualMesh to convert these to polyhedral meshes, but without much success. I have downloaded engrid and am going to give it a try instead. Cheers, Andrew |
As far as I know, snappyHexMes
As far as I know, snappyHexMesh has no automatic feature line capturing, unfortunately. You can somehow explicitly provide some feature edge through a file separated from the STL, but I haven't tried it and don't know how well it works.
Cheers, Francesco |
Thanks Francesco.
I managed
Thanks Francesco.
I managed to find this thread after another search http://www.cfd-online.com/cgi-bin/Op...c=1&post=24651 - It appears that edge matching won't be a part of snappyHex Mesh for quite a while. It's a pity as apart from this I am impressed with the meshes snappyHexMesh creates. Looks like I'll have to go back to netgen for now. Cheers, Andrew |
Is there anyone have any hope that edge capturing will be a possibility with snappy. I think that a must for many peoples..
snapEdge may be what you are looking for
edges of 3D wing
1 Attachment(s)
I'm encountering the same problem as andersking. Using snappyHexMesh, don't get the edges of my NACA0012 straight. Any suggestions for improvement? Cheers, Horsty Attachment 19610 |
Hi Horsty,
Try looking at the flange example (http://www.openfoam.com/news/snappyH...ature-edge.php) While I have not tried it for an aerofoil a similar approach involving the use of: surfaceFeatureExtract (as per the flange example) should hopefully help. The flange example should be in tutorials/mesh/snappyHexMesh/flange Cheers, Paul |
1 Attachment(s)
| All times are GMT -4. The time now is 08:10. |
