Home > Forums > OpenFOAM Mesh Utilities
Error with reconstructPar
Old   May 26, 2008, 00:12
Default Hi All, Can anyone tell me
Senthil Kabilan
skabilan is on a distinguished road
Hi All,
Can anyone tell me why I get a segmentation fault when trying to use reconstructPar after a successful parallel run?
Thanks in advance!
Senthil
altix1 openfoam/1D_3D_coupling> reconstructPar . weibel_icofoam_vardt_tay
| \ / F ield | OpenFOAM: The Open Source CFD Toolbox |
| \ / O peration | Version: 1.4.1 |
| \ / A nd | Web: http://www.openfoam.org |
| \/ M anipulation | |
Exec : reconstructPar . weibel_icofoam_vardt_tay
Date : May 25 2008
Time : 18:56:00
Host : altix1
PID : 23205
Root : /home/skabilan/workdir/openfoam/1D_3D_coupling
Case : weibel_icofoam_vardt_tay
Nprocs : 1
Create time
Create mesh
Time = 1.69999
Reconstructing FV fields
Reconstructing volScalarFields
p
Reconstructing volVectorFields
U
#0 _ZN4Foam5error10printStackERNS_7OstreamE-0x1045010
in "/home/skabilan/OpenFOAM/OpenFOAM-1.4.1/lib/linuxIA64GccDPOpt/libOpenFOAM.so"
#1 _ZN4Foam7sigSegv14sigSegvHandlerEi-0x1012500
#2 Uninterpreted: [0xa0000000000107e0]
#3 _ZN4Foam45pressureInletOutletVelocityFvPatchVector Field4rmapERKNS_12fvPatchField INS_6VectorIdEEEERKNS_4ListIiEE-0x22800f0
in "/home/skabilan/OpenFOAM/OpenFOAM-1.4.1/lib/linuxIA64GccDPOpt/libfiniteVolume.so "
#4 Foam::tmp<foam::geometricfield<foam::vector<double >, Foam::fvPatchField, Foam::volMesh> > Foam::fvFieldReconstructor::reconstructFvVolumeFie ld<foam::vector<double> >(Foam::IOobject const&) in "/home/skabilan/OpenFOAM/OpenFOAM-1.4.1/applications/bin/linuxIA64GccDPOpt/recon structPar"
#5 void Foam::fvFieldReconstructor::reconstructFvVolumeFie lds<foam::vector<double> >(Foam::IOobjectList const&) in "/home/skabilan/OpenFOAM/OpenFOAM-1.4.1/applications/bin/linuxIA64GccDPOpt/recon structPar"
#6 main in "/home/skabilan/OpenFOAM/OpenFOAM-1.4.1/applications/bin/linuxIA64GccDPOpt/recon structPar"
#7 __libc_start_main-0x74c7d0
in "/lib/libc.so.6.1"
#8 _start in "/home/skabilan/OpenFOAM/OpenFOAM-1.4.1/applications/bin/linuxIA64GccDPOpt/recon structPar"
Segmentation fault
skabilan is offline   Reply With Quote
Old   May 26, 2008, 07:35
Default I got this ERROR when I use so
Mark Michael
mark_michael is on a distinguished road
I got this ERROR when I use some utility -functions and one of the points or nodes where well-defined in the point of origin '(0 0 0)'! for example, some days ago i use the sample-function for sampling deliverables on a line from the point of origin to a point in my field (with midpoint-sampleset)!
Mark
mark_michael is offline   Reply With Quote
Old   May 27, 2008, 14:15
Default http://www.cfd-online.com/cgi-
Mattijs Janssens
mattijs is on a distinguished road
http://www.cfd-online.com/cgi-bin/Op...2851#POST22851
mattijs is offline   Reply With Quote
Old   June 10, 2008, 18:34
Default Downloading the new pressureIn
Senthil Kabilan
Downloading the new pressureInletOutletVelocityFvPatchVectorField.C file fixed the segmentation fault.
Senthil
Thread Tools
Trackbacks are On
Bug in reconstructPar david OpenFOAM Bugs 10 May 26, 2009 12:11
ReconstructPar kupiainen OpenFOAM Post-Processing 12 April 21, 2009 01:47
ReconstructPar maka OpenFOAM Bugs 6 August 22, 2007 04:23
ReconstructPar channelOodles error maka OpenFOAM Post-Processing 6 September 13, 2006 16:16
ReconstructPar error r2d2 OpenFOAM Pre-Processing 7 September 12, 2006 09:37
