[mesh manipulation] Mesh refinemt by scalar field |
July 10, 2007, 12:46 |
i am Sergio Ferraris from Kingston University, London. I was in Zagreb and I was kindly "set" in a position to deal with mesh refinement using a given scalar.
I 've been working quiet a lot and I have good and bad news: Good news: I introduced a class to handle the mesh refinemen by any scalar field. It does the refinement and gives a good mesh and map all the variables properly. Bad news: Somehow I can not make phi to be conservative after the refinement. So, it diverges after few iterations. I tried solving pcorr to modified phi (as it is is icoDyFoam) but no results. So, anybody who can give an idea what this is happening will be welcome and rewarded with the source code when it is working and tested. Regards Sergio |
July 11, 2007, 02:18 |
Hi Sergio,
I am beginning to
Hi Sergio,
I am beginning to learn adaptive mesh refinement. I will highly appreciate if you could share your source code dealing with mesh refinement using a given scalar (my email: phuc-danh.nguyen@univ-pau.fr) ? So we can resolve the question you have posed together. You will be rewarded once I could succeed in formulating the adjoint problem for error estimation ! Best regards, Danh |
July 11, 2007, 04:19 |
Hi Sergio,
Very interesting
Frank Bos
Rep Power: 18 |
Hi Sergio,
Very interesting, indeed! Once you've got it working, i.e. when the flux remains conservative after refinement, I am willing to test this stuff. I have some nice vortex test cases of which I'd like to apply unsteady mesh refinement using, for example, the maximal of magVorticity. Regards, Frank
Frank Bos |
January 9, 2008, 05:15 |
Hi Sergio,
I am just wonder
Fabian Braennstroem
Rep Power: 19 |
Hi Sergio,
I am just wondering, if you had success so far and I am wondering, how the mesh.update() function works? Best Regards! Fabian |
decomposePar problem: Cell 0contains face labels out of range | vaina74 | OpenFOAM Pre-Processing | 37 | July 20, 2020 05:38 |
[snappyHexMesh] No layers in a small gap | bobburnquist | OpenFOAM Meshing & Mesh Conversion | 6 | August 26, 2015 09:38 |
Mesh refinement with Field Functions - error | Dan Chambers | STAR-CCM+ | 7 | January 30, 2014 08:01 |
Problem with rhoSimpleFoam | matteo_gautero | OpenFOAM Running, Solving & CFD | 0 | February 28, 2008 06:51 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 11:55 |
