[blockMesh] this is a simple one but I have no idea what I did wrong |
September 25, 2007, 00:29 |
Mojtaba Shahmohammadian
Rep Power: 17 |
my blockmeshdict file is:
/*---------------------------------------------------------------------------*\ | ========= | | | \ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \ / O peration | Version: 1.3 | | \ / A nd | Web: http://www.openfoam.org | | \/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; root ""; case ""; instance ""; local ""; class dictionary; object blockMeshDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // convertToMeters 0.1; vertices ( (0 1 0) (5 1 0) (5 0 0) (35 0 0) (35 3 0) (0 3 0) (0.1 1 0) (5.1 0 0) (34.9 0 0) (34.9 3 0) (0.1 3 0) (0.1 1.1 0) (5 1.1 0) (5.1 1.1 0) (5.1 0.1 0) (13 0.1 0) (34.9 0.1 0) (34.9 1.1 0) (34.9 2.9 0) (5.1 2.9 0) (0.1 2.9 0) (13 1.1 0) (0 1 1) (5 1 1) (5 0 1) (35 0 1) (35 3 1) (0 3 1) (0.1 1 1) (5.1 0 1) (34.9 0 1) (34.9 3 1) (0.1 3 1) (0.1 1.1 1) (5 1.1 1) (5.1 1.1 1) (5.1 0.1 1) (13 0.1 1) (34.9 0.1 1) (34.9 1.1 1) (34.9 2.9 1) (5.1 2.9 1) (0.1 2.9 1) (13 1.1 1) ); blocks ( hex (0 6 10 5 22 28 32 27) (10 200 1) simpleGrading (1 1 1) hex (6 1 12 11 28 23 34 33) (490 10 1) simpleGrading (1 1 1) hex (2 7 13 12 24 29 35 34) (10 110 1) simpleGrading (1 1 1) hex (7 8 16 14 29 30 38 36) (280 10 1) simpleGrading (1 1 1) hex (8 3 4 9 30 25 26 31) (10 300 1) simpleGrading (1 1 1) hex (20 18 9 10 42 40 31 32) (330 10 1) simpleGrading (1 1 1) hex (11 13 19 20 33 35 41 42) (50 18 1) simpleGrading (1 1 1) hex (14 15 21 13 36 37 43 35) (790 100 1) simpleGrading (1 1 1) hex (15 16 17 21 37 38 39 43) (219 10 1) simpleGrading (1 1 1) hex (13 17 18 19 35 39 40 41) (28 10 1) simpleGrading (1 1 1) ); edges ( ); patches ( patch inlet ( (0 22 27 5) ) patch outlet ( (3 4 26 25) ) wall fixedWalls ( (4 9 31 26) (9 10 32 31) (10 5 27 32) (0 6 28 22) (6 1 23 28) (1 2 24 23) (2 7 29 24) (7 8 30 29) (8 3 25 30) ) ); mergePatchPairs ( ); // ************************************************** *********************** // and when I run blockMesh this error appears: Reading block mesh description dictionary Creating block mesh Creating blockCorners Creating curved edges Creating blocks Creating patches Creating block mesh topology Default patch type set to empty --> FOAM FATAL ERROR : face 5 in patch 2 does not have neighbour cell face: 4(1 2 24 23) From function polyMesh::facePatchFaceCells(const faceList& patchFaces,const labelListList& pointCells,const faceListList& cellsFaceShapes,const label patchID) in file meshes/polyMesh/polyMeshFromShapeMesh.C at line 127. FOAM aborting Foam::error::printStack(Foam:stream&) Foam::error::abort() Foam::polyMesh::facePatchFaceCells(Foam::List<foam ::face> const&, Foam::List<foam::list<int> > const&, Foam::List<foam::list<foam::face> > const&, int) const Foam::polyMesh::polyMesh(Foam::IOobject const&, Foam::Field<foam::vector<double> > const&, Foam::List<foam::cellshape> const&, Foam::List<foam::list<foam::face> > const&, Foam::List<foam::word> const&, Foam::List<foam::word> const&, Foam::word const&, Foam::List<foam::word> const&) blockMesh [0x806116f] blockMesh [0x8059228] blockMesh [0x806f2c1] __libc_start_main __gxx_personality_v0 Aborted |
September 25, 2007, 05:57 |
Hello
Please try to comment
Hello
Please try to comment the 'patches' section of your blockMeshDict file. Then run blockMesh. If it turns out ok, then add the first patch, 'inlet' in your case. Repeat the same procedure step by step until you find where the problem is. By looking at the error message, I would think that the problem resides in the patch 'fixedWalls'. Good luck! José Santos |
September 28, 2007, 03:22 |
Hi
Thank you for reply
I'l
Rep Power: 17 |
Hi
Thank you for reply I'll do so. Best regards |
Display Modes | |
Simple static mechanical analysis gave obviously wrong result | cli21 | ANSYS | 0 | March 15, 2017 21:58 |
Incompressible Euler Equations with SIMPLE method | yfjok22 | OpenFOAM Programming & Development | 1 | September 22, 2016 08:11 |
rhoSimpleFoam, simple setup, wrong BC? | tjs111 | OpenFOAM Running, Solving & CFD | 3 | September 1, 2016 08:02 |
fully developed channel flow with kOmega, wrong results | boshynova | OpenFOAM Programming & Development | 1 | April 20, 2016 10:54 |
bubbleFoam - Simple case, Large bubble, closed domain | darai | OpenFOAM Running, Solving & CFD | 9 | October 12, 2015 05:40 |
