[mesh manipulation] Error using patchTool
Old   June 26, 2007, 06:01
Default Error using patchTool
jackdaniels83 is on a distinguished road
Hi all,
when i want to visualize the mesh in patchTool after loading a few patches i get the following massage in the terminal:
java.lang.OutOfMemoryError
The model is about 1 GB and i have over 6 GB memory in my mashine.
Can someone tell me what is going wrong?
With best regards,
Daniel
jackdaniels83 is offline   Reply With Quote
Old   June 26, 2007, 14:49
Default Java needs prespecified the ma
Mattijs Janssens
mattijs is on a distinguished road
Java needs prespecified the maximum amount of memory it can take. Look at the patchTool script.
(and a warning: PatchTool is not very nice to use)
mattijs is offline   Reply With Quote
Old   June 27, 2007, 04:04
Default Thanks for your help. What too
Thanks for your help. What tool do you use to extract single patches?
Daniel
Old   June 27, 2007, 04:44
Default I don't know where to look, ca
I don't know where to look, can someone tell me where i can change the amount of memory used by patchTool? I am running it on a 64 bit OpenSuse 10.2 system, on the Ubuntu 32 bit system (same machine) i don't have the problem.
Daniel
Old   July 2, 2007, 08:00
Default Hi all, can someone please
Hi all,
can someone please help me? Is there an other open source tool to create patches or how can i fix the problem with PatchTool and it's memory usage?
Regards,
Daniel
Old   July 3, 2007, 02:27
Default Hi Daniel, You may try to use
dmoroian's Avatar
Dragos
dmoroian is on a distinguished road
Hi Daniel,
You may try to use the autoPatch utility, and then rename the generated patches.
I found an old discussion at memory limit, and they show 2 options for the jvm... still seems there are problems. Basically one option is -Xmx4000m, and lets you allocate as much heap as you want (in this case I chose 4000MB).
Dragos
dmoroian is offline   Reply With Quote
Old   July 3, 2007, 04:58
Default Thanks for your reply. autoPat
Thanks for your reply. autoPatch is to primitive, i'm using it together with patchTool, when i leave the patches created by autoPatch (with an angle of 60°) i have around 100. At the other hand i have to group them to calculate forces on a group of patches.
I will try the memory limit thing.
Daniel
patchTool, is there a newer alternative? bigphil OpenFOAM Pre-Processing 4 October 19, 2009 07:56
PatchTool for OpenFOAM 15 mou_mi OpenFOAM Running, Solving & CFD 0 July 28, 2008 15:53
[mesh manipulation] PatchTool name server problem hani OpenFOAM Meshing & Mesh Conversion 12 June 3, 2008 13:46
Implement changes done in patchTool to FoamX davvan OpenFOAM Pre-Processing 0 May 29, 2008 04:54
[mesh manipulation] Launching patchTool tibbstine OpenFOAM Meshing & Mesh Conversion 6 May 23, 2007 05:38
