-   OpenFOAM Mesh Utilities (http://www.cfd-online.com/Forums/openfoam-meshing-utilities/)
-   -   Defining new faces after fluenttofoam conversion (http://www.cfd-online.com/Forums/openfoam-meshing-utilities/61568-defining-new-faces-after-fluenttofoam-conversion.html)
mayank May 29, 2007 09:48
hello all, I created a mesh
hello all,
I created a mesh in icemcfd then exported to fluent. All the boundary faces(inlet,outlet,etc) were defined in the mesh but when running fluentmeshtofoam only 'defaultFaces' was created in patch.
Now, I need to define the remaining boundary faces in openfoam. I need some help in this regard.
Thanks
Mayank.
dmoroian May 30, 2007 03:16
In the utilities section of th
In the utilities section of the documentation utilities, there are several tools you can try: autoPatch and patchTool. The second is a visual tool that allows you to pick your faces and define them as boundaries.
Dragos
mayank May 30, 2007 09:25
Hello, I tried autoPatch an
I tried autoPatch and it generated the patches fine which I checked in patchTool.
But Saving the mesh in patchTool hangs and in FoamX case manager defaultFaces is the only patch.So I cannot define the boundary conditions on the generated patches.
I tried to run paraview which shows the following error:
--> FOAM FATAL IO ERROR : keyword auto0 is undefined in dictionary "././0/nuTilda::boundaryField"
file: ././0/nuTilda::boundaryField from line 36 to line 37.
From function dictionary::lookupEntry(const word& keyword) const
in file db/dictionary/dictionary.C at line 146.
FOAM exiting
Mayank
dmoroian June 4, 2007 10:13
Hi Mayank, If you have used a
Hi Mayank,
If you have used autoPatch, why do you need patchTool?
Just edit the generated case/constant/polyMesh/boundary file with any text editor, and specify there what do you want to have for each patch.
Dragos
