[mesh manipulation] Launching patchTool
Old   May 22, 2007, 07:09
Default Launching patchTool
James Tibbatts
tibbstine is on a distinguished road
I am having trouble launching patchTool. I am a new user of OpenFOAM, and am not particularly competant with linux so it is likley that the problem is quite simple.
On trying to launch patchTool I get the following infomration in the shell window:
james-1.4/run> patchTool . device-steady/
runPatchToolServer : pid:8263
Using running runPatchToolServer (pid 8263) ...
Using jar /home/james/OpenFOAM/OpenFOAM-1.4/applications/utilities/mesh/manipulation/patch Tool/lib/j3d-org.jar
Using jar /home/james/OpenFOAM/OpenFOAM-1.4/applications/utilities/mesh/manipulation/patch Tool/lib/PatchTool.jar
+ /usr/bin/java -cp .:/home/james/OpenFOAM/OpenFOAM-1.4/applications/utilities/mesh/manipulation/pat chTool/lib/j3d-org.jar:/home/james/OpenFOAM/OpenFOAM-1.4/applications/utilities/ mesh/manipulation/patchTool/lib/PatchTool.jar -DFoamX.SystemPath=/home/james/OpenFOAM/OpenFOAM-1.4 -DFoamX.SystemConfigPath=/home/james/OpenFOAM/OpenFOAM-1.4/.OpenFOAM-1.4/apps/Fo amX -DFoamX.UserConfigPath=/home/james/OpenFOAM/OpenFOAM-1.4/.OpenFOAM-1.4/apps/Foam X -DFoamX.PatchToolPath=/home/james/OpenFOAM/OpenFOAM-1.4/applications/utilities/m esh/manipulation/patchTool PatchTool/PatchTool -ORBDefaultInitRef corbaloc:iiop:1.0:linux:1235
Exception in thread "main" java.lang.NoClassDefFoundError: javax/media/j3d/Node
+ cleanup
+ trap 0 2 3 15
james-1.4/run>
Any ideas on what I have done wrong?
Thanks
James
tibbstine is offline   Reply With Quote
Old   May 22, 2007, 07:36
Default Probably this is because you h
dmoroian's Avatar
Dragos
dmoroian is on a distinguished road
Probably this is because you have an extra "/" in the case name. You should type:
patchTool ./ device-steady
dmoroian is offline   Reply With Quote
Old   May 22, 2007, 08:29
Default Hi Dragos, Same problem. I
James Tibbatts
Hi Dragos,
Same problem. I have tried quite a few different variations on the cmd line, all give the same error which I think comes down to this line:
Do you know what that means?
Old   May 22, 2007, 11:09
Default Hm, no idea! But is seems ther
dmoroian's Avatar
Dragos
Hm, no idea! But is seems there is something wrong with the java installation. Is FoamX running correctly?
Dragos
Old   May 22, 2007, 11:25
Default Yeah it sounds possible, howev
James Tibbatts
Yeah it sounds possible, however both FoamX and paraFoam work perfectly.
Pehaps there is another way to achieve what I am trying to do. I have a single patch (a pressure inlet) which is in reality 3 separte inlets, each oriented in a different direction and not touching.
I would like to change this to a velocity inlet, however since the definition of the inlet velocity is cartesian and not magnitude normal to the boundary, I need to split this single patch into three separate patches.
Without patchTool is there another way to do this?
Old   May 22, 2007, 20:08
Default Hi, Just a guess but maybe it
Takuya OSHIMA
7islands is on a distinguished road
Just a guess but maybe it's because the Java3D library (https://java3d.dev.java.net/binary-builds.html) is missing from your Java installation. Try installing the library following the installation instructions in the README on the page.
Takuya
7islands is offline   Reply With Quote
Old   May 23, 2007, 05:38
Default I think I have now fixed my ja
James Tibbatts
I think I have now fixed my java install. The pathchtool GUI launches, now I just have to work out how to use it.
Thanks for your help.
Launching of Jacket structure (ANSYS AQWA) sheonn92 ANSYS 0 January 1, 2016 05:42
Aqwa jacket launching and upending. sheonn92 ANSYS 0 September 18, 2015 06:33
patchTool, is there a newer alternative? bigphil OpenFOAM Pre-Processing 4 October 19, 2009 07:56
PatchTool for OpenFOAM 15 mou_mi OpenFOAM Running, Solving & CFD 0 July 28, 2008 15:53
[mesh manipulation] PatchTool name server problem hani OpenFOAM Meshing & Mesh Conversion 12 June 3, 2008 13:46
