[Commercial meshers] fluentMeshToFoam 2D mesh auto z direction extrusion |
March 18, 2010, 05:57 |
Pavan
Hey guys,
Does anyone know how to control the amount fluentMeshToFoam extrudes the 2D mesh in the z-direction? I'm trying to use GGI and it's extruded my two parts by differing amounts... |
March 22, 2010, 08:54 |
Pavan
Anyone out there....
March 31, 2010, 11:53 |
I'm interested in this too and I still haven't find an answer.
I suppose we should look at the code ... but I'm working on a network and I can't modify such files so is there an other way to do this than modifying the code? Thanks for the help |
March 31, 2010, 11:54 |
I think one way is to modify the file "Points" located in your case/constant/polyMesh directory and changing the third coodinates of the points to be the depth you want.
March 31, 2010, 19:42 |
Pavan
Yeah that's an option but one must know how deep each part of the mesh is before scaling it. Is there an easy way to find this out?
I import my meshes from Gambit so from the time being I am extruding in Gambit and then importing... |
April 1, 2010, 03:48 |
For me that's not a problem since my geometry is simple
Just a question : you're talking about 'extruding' in gambit... Is there a way to really extrude a 2D geometry into a 3D automatically in gambit? This would save me much time... Thanks for the help! |
April 1, 2010, 08:26 |
Pavan
Yea just go to the geometry menu and under the faces submenu the option should be there to extrude...
April 1, 2010, 08:38 |
I just looked at gambit and under faces submenu I just have the option : MOVE/COPY/ALIGN but this is not really an extrusion. Is this this option you are referring to?
Thanks Last edited by Gearb0x; April 1, 2010 at 09:27. |
April 1, 2010, 19:13 |
Pavan
Sorry I just checked and it's actually the 'sweep faces' option in the volume submenu. I can't figure out how to define how many cells I prefer in the third direction though...
December 28, 2022, 10:18 |
Uttam
Rep Power: 5 |
This was helpful for me thanks a lot.
Best Regards Uttam ----------------------------------------------------------------- “When everything seem to be going against you, remember that the airplane takes off against the wind, not with it.” – Henry Ford. |
[snappyHexMesh] Creating multiple multiple cell zones with snappyHexMesh - a newbie in deep water! | divergence | OpenFOAM Meshing & Mesh Conversion | 0 | January 23, 2019 04:17 |
Star CCM Overset Mesh Error (Rotating Turbine) | thezack | Siemens | 7 | October 12, 2016 11:14 |
3D Hybrid Mesh Errors | DarrenC | ANSYS Meshing & Geometry | 11 | August 5, 2013 06:42 |
gambit: mesh edges, change direction | Ralf Schmidt | FLUENT | 2 | August 29, 2006 10:55 |
