Home > Forums > OpenFOAM Mesh Utilities
mergeMeshes
Old   October 30, 2010, 17:24
Default mergeMeshes
Pascal
Pascal_doran is on a distinguished road
Hi all,
I try to merge 4 identical (in size) meshes with mergeMeshes. The interfaces match perfectly. Mesh #1 and mesh #2 merge perfectly. Then I use stitchMesh and renumberMesh. Everything works perfectly. Mesh #3 and mesh #4 merge perfectly. But, mesh #1 and mesh #3 do not merge :
--> FOAM FATAL ERROR:
Illegal zoneID 1 for face 2675997
    From function resetZones(const polyMesh&, polyMesh&, labelListList&labelListList&, labelListList&)
    in file polyTopoChange/polyTopoChange/polyTopoChange.C at line 1587.
FOAM aborting
each mesh has 450 000 cells. The final mesh should have 1 800 000 cells.
Any advises?
Pascal
Pascal_doran is offline   Reply With Quote
Old   November 9, 2010, 12:07
Sebastian Saegeler
sebastian is on a distinguished road
Hi Pascal!
Could you solve this? I have got the same problem.
Sebastian
sebastian is offline   Reply With Quote
Old   November 9, 2010, 12:28
Pascal
Hi Sebastian,
No... By the way which version you have? The error message I got was with OF 1.6, but everything worked fine with OF 1.6.x.
Regards,
Pascal
Old   November 10, 2010, 03:52
Sebastian Saegeler
Hi Pascal,
well, okay. I am using 1.6. But I think I can solve that problem on a different way. Anyway, thanks
Best Regards,
Sebastian
Old   November 23, 2010, 07:30
Karl-Johan Nogenmyr
kalle is on a distinguished road
I ran into the same error... went away by removing faceZones files in polyMesh/
That sucks a bit since I need those zones.... and strange thing is that other meshes I joined to the same mesh contained both cell- and faceZones without causing trouble... could not see any reason why this particular mesh could not contain faceZones.
K
Edit:
Above comment concerned OF 17.0. Repeating exactly the same thing in OF 1.5-dev gave no such errors.
Before mergeMeshes all mesh parts were prepared in 1.7.0 using fluent3DmeshToFoam and setSet and setsToZones. Only 1.5-dev could take it from there it seems.
I did not try other versions.
In cases 1.7.0 could merge with *Zones, they got randomly mixed up.
kalle is offline   Reply With Quote
Old   February 29, 2012, 12:59
Attesz's Avatar
Attesz
Attesz is an unknown quantity at this point
Hi, I got the same problem, did you find a solution for it guys?
Thanks,
Attila
CFD= Cleverly Formatted Data
Attesz is offline   Reply With Quote
Thread Tools
Trackbacks are On
MergeMeshes with version OF14 jens_klostermann OpenFOAM Bugs 2 November 7, 2014 17:27
MergeMeshes hsieh OpenFOAM Meshing Format & General Technical 3 September 10, 2014 09:15
stitchMesh and mergeMeshes removal of interfaces flowris OpenFOAM Mesh Utilities 6 July 16, 2010 12:06
MergeMeshes and stitchMesh problem flo OpenFOAM Mesh Utilities 6 May 10, 2010 10:40
MergeMeshes and mesh format from 14x 15 pitmanm OpenFOAM Bugs 14 July 4, 2009 00:55
