[Technical] convert patch faces to internal faces?
Old   November 24, 2010, 20:57
Default convert patch faces to internal faces?
Pei-Ying Hsieh
phsieh2005 is on a distinguished road
In the boundary file, I have a patch, say called myInternal. Is there a way to convert all the faces in myInternal to internal faces? When I simply deleted this patch, I got an error.
Thanks!
Pei
phsieh2005 is offline   Reply With Quote
Old   December 15, 2010, 03:48
Marta's Avatar
Marta Lazzarin
Marta is on a distinguished road
I got the same error...I just would like to apply in OFoam the equivalent condition as 'interface' in Fluent.
Have you found a solution to this problem?
Thanks a lot!
Marta
Marta is offline   Reply With Quote
Old   December 15, 2010, 08:36
Pei-Ying Hsieh
Hi, Marta,
No, I still have not found a solution for this yet.
Pei
steadyUniversalMRFFoam Tutorial fails in MixingPlane HenrikJohansson OpenFOAM Bugs 0 February 14, 2019 04:48
GenerateVolumeMesh Error - Surface Wrapper Self Interacting (?) AndreP STAR-CCM+ 10 August 2, 2018 07:48
[snappyHexMesh] sHM layer process keeps getting killed MBttR OpenFOAM Meshing & Mesh Conversion 4 August 15, 2016 03:21
[snappyHexMesh] No layers in a small gap bobburnquist OpenFOAM Meshing & Mesh Conversion 6 August 26, 2015 09:38
[Gmsh] Import gmsh msh to Foam adorean OpenFOAM Meshing & Mesh Conversion 24 April 27, 2005 08:19
