[mesh manipulation] createpatch not working when using layer addition in snappyHexMesh
Old   February 3, 2020, 09:46
Question createpatch not working when using layer addition in snappyHexMesh
Max
Dikkeunit is on a distinguished road
I am running a CFD simulation of a fan that is located inside a box. To do this I use snappyHexMesh to generate a baffle that is edited in createpatch to make it cyclic. Before this, I used cyclicAMI which worked fine. Now I would like to use cyclic as that will enable me to use the fan BC. When I only have the fan patch in a domain with the fan BC it works fine. When I then load another part in the simulation, without running layer addition in snappyHexMesh, it works fine as well. However, when I turn on the layer addition for the other part, even if it is not near the fan patch, createPatch does not work anymore giving the following error:
|  \\    /   O peration     | Version:  v1812                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.com                      |
Build  : v1812 OPENFOAM=1812
Arch   : "LSB;label=32;scalar=64"
Exec   : createPatch -parallel -decomposeParDict system/decomposeParDict.6 -overwrite
Date   : Feb 03 2020
Time   : 15:01:40
Host   : urepower8
PID    : 59302
I/O    : uncollated
Case   : /home/URE14/OpenFOAM/URE14-v1812/run/Max/Experiment_Fancurve
nProcs : 50
Hosts  :
    (urepower8 50)
Pstream initialized with:
    floatTransfer      : 0
    nProcsSimpleSum    : 0
    commsType          : nonBlocking
    polling iterations : 0
trapFpe: Floating point exception trapping enabled (FOAM_SIGFPE).
fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 10)
allowSystemOperations : Allowing user-supplied system call operations
Create time
Create polyMesh for time = 0
Reading "system/createPatchDict"
Adding new patch fan_in as patch 8 from
    type            cyclic;
    neighbourPatch  fan_out;
Adding new patch fan_out as patch 9 from
    type            cyclic;
    neighbourPatch  fan_in;
Moving faces from patch fan to patch 8
Moving faces from patch fan_slave to patch 9
Doing topology modification to order faces.
[19] Cannot find point in pts1 matching point 6 coord:(-0.26609 0.000615407 0.193233) in pts0 when using tolerance 7.7534e-08
[19] Searching started from:0 in pts1
[19] Cannot find point in pts1 matching point 20 coord:(-0.266101 0.00184115 0.193226) in pts0 when using tolerance 7.7501e-08
[19] Cannot find point in pts1 matching point 18 coord:(-0.266099 0.00308022 0.193227) in pts0 when using tolerance 7.69666e-08
[19] Cannot find point in pts1 matching point 4 coord:(-0.266091 0.00431021 0.193232) in pts0 when using tolerance 7.67744e-08
[19] Cannot find point in pts1 matching point 0 coord:(-0.266108 0.00554009 0.193221) in pts0 when using tolerance 7.81904e-08
etc......
This is the code for snappyHexMesh:
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      snappyHexMeshDict;
// Which of the steps to run
castellatedMesh true;
snap            true;
addLayers       true;
// Geometry. Definition of all surfaces. All surfaces are of class
// searchableSurface.
// Surfaces are used
// - to specify refinement for any mesh cell intersecting it
// - to specify refinement for any mesh cell inside/outside/near
// - to 'snap' the mesh boundary to the surface
geometry
    fan.stl
		type triSurfaceMesh;
		name fan;
    fanbox.stl
	name fanbox;
// Settings for the castellatedMesh generation.
castellatedMeshControls
    // Refinement parameters
    maxLocalCells 		1000000;
    maxGlobalCells 		80000000;
    minRefinementCells 		3000;
    maxLoadUnbalance		0.10;
    nCellsBetweenLevels		4;
    allowFreeStandingZoneFaces	true;
    resolveFeatureAngle		30;
    planarAngle			30;
    features
    {   file "fan.eMesh"; level 4; }
    {   file "fanbox.eMesh"; level 4; }
    // Surface based refinement
    refinementSurfaces
        fanbox
            // Surface-wise min and max refinement level
            level (6 6);
            // Optional specification of patch type (default is wall). No
            // constraint types (cyclic, symmetry) etc. are allowed.
            patchInfo
                type wall;
                inGroups (URE14Group);
        fan
			level (7 7);
			faceZone fanFaces;
			faceType baffle;
    refinementRegions
    locationInMesh (3.0001 3.0001 0.43);
// Settings for the snapping.
snapControls
    nSmoothPatch 5;
    tolerance 2.0;
    nSolveIter 150;
    nRelaxIter 5;
    nFeatureSnapIter 15;
    implicitFeatureSnap false;
    explicitFeatureSnap true;
    multiRegionFeatureSnap false;
// Settings for the layer addition.
addLayersControls
    // Are the thickness parameters below relative to the undistorted
    // size of the refined cell outside layer (true) or absolute sizes (false).
    relativeSizes true;
    // Per final patch (so not geometry!) the layer information
    layers
        "(fanbox).*"
            nSurfaceLayers 6;
    // Expansion factor for layer mesh
    expansionRatio 1.2;
    // Wanted thickness of final added cell layer. If multiple layers
    // is the thickness of the layer furthest away from the wall.
    // Relative to undistorted size of cell outside layer.
    // See relativeSizes parameter.
    finalLayerThickness 0.5;
    // Minimum thickness of cell layer. If for any reason layer
    // cannot be above minThickness do not add layer.
    minThickness 0.001;
    // If points get not extruded do nGrow layers of connected faces that are
    // also not grown. This helps convergence of the layer addition process
    // close to features.
    // Note: changed(corrected) w.r.t 1.7.x! (didn't do anything in 1.7.x)
    nGrow 0;
    // Advanced settings
    // When not to extrude surface. 0 is flat surface, 90 is when two faces
    // are perpendicular
    featureAngle 180;
    // At non-patched sides allow mesh to slip if extrusion direction makes
    // angle larger than slipFeatureAngle.
    slipFeatureAngle 75;
    // Maximum number of snapping relaxation iterations. Should stop
    // before upon reaching a correct mesh.
    nRelaxIter 5;
    // Number of smoothing iterations of surface normals
    nSmoothSurfaceNormals 3;
    // Number of smoothing iterations of interior mesh movement direction
    nSmoothNormals 4;
    // Smooth layer thickness over surface patches
    nSmoothThickness 10;
    // Stop layer growth on highly warped cells
    maxFaceThicknessRatio 0.5;
    // Reduce layer growth where ratio thickness to medial
    // distance is large
    maxThicknessToMedialRatio 0.3;
    // Angle used to pick up medial axis points
    // Note: changed(corrected) w.r.t 1.7.x! 90 degrees corresponds to 130
    // in 1.7.x.
    minMedialAxisAngle 90;
    // Create buffer region for new layer terminations
    nBufferCellsNoExtrude 0;
    // Overall max number of layer addition iterations. The mesher will exit
    // if it reaches this number of iterations; possibly with an illegal
    // mesh.
    nLayerIter 300;
// Generic mesh quality settings. At any undoable phase these determine
// where to undo.
meshQualityControls
    #include "meshQualityDict"
    // Advanced
    //- Number of error distribution iterations
    nSmoothScale 4;
    //- Amount to scale back displacement at error points
    errorReduction 0.75;
// Advanced
// Write flags
writeFlags
    scalarLevels
    layerSets
    layerFields     // write volScalarField for layer coverage
// Merge tolerance. Is fraction of overall bounding box of initial mesh.
// Note: the write tolerance needs to be higher than this.
mergeTolerance 1e-6;
And this is the code for createPatch:
|  \\    /   O peration     | Version:  4.1.0                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      createPatchDict;
// This application/dictionary controls:
// - optional: create new patches from boundary faces (either given as
//   a set of patches or as a faceSet)
// - always: order faces on coupled patches such that they are opposite. This
//   is done for all coupled faces, not just for any patches created.
// - optional: synchronise points on coupled patches.
// 1. Create cyclic:
// - specify where the faces should come from
// - specify the type of cyclic. If a rotational specify the rotationAxis
//   and centre to make matching easier
// - always create both halves in one invocation with correct 'neighbourPatch'
//   setting.
// - optionally pointSync true to guarantee points to line up.
// 2. Correct incorrect cyclic:
// This will usually fail upon loading:
//  "face 0 area does not match neighbour 2 by 0.0100005%"
//  " -- possible face ordering problem."
// - in polyMesh/boundary file:
//      - loosen matchTolerance of all cyclics to get case to load
//      - or change patch type from 'cyclic' to 'patch'
//        and regenerate cyclic as above
// Do a synchronisation of coupled points after creation of any patches.
// Note: this does not work with points that are on multiple coupled patches
//       with transformations (i.e. cyclics).
pointSync true;
// Patches to create.
patches
        	// Name of new patch
       		name fan_in;
        	// Dictionary to construct new patch from
        	patchInfo
                type        cyclic;
                // Optional: explicitly set transformation tensor.
                // Used when matching and synchronising points.
                //transform rotational;
            	//rotationAxis (1 0 0);
            	//rotationCentre (0 0 0);
            	// transform translational;
           	// separationVector (1 0 0);
            	// Optional non-default tolerance to be able to define cyclics
            	// on bad meshes
            	//matchTolerance 0.000000000001;
        	// How to construct: either from 'patches' or 'set'
        	constructFrom patches;
        	// If constructFrom = patches : names of patches. Wildcards allowed.
        	patches (fan);
        	// If constructFrom = set : name of faceSet
	      	//set fan;
        	name fan_out;
        	patchInfo
                 type        cyclic;
            		//rotationAxis    ( 0 0 1 );
            		//rotationCentre  ( 0.3 0 0 );
        	patches (fan_slave);
        	//set fan_slave;
Would anyone know what the problem is? I can supply more information if needed.
Many thanks,
Max
Dikkeunit is offline   Reply With Quote
baffle-snappyhexmesh, createpatch, cyclic, fan bc, snappyhexmesh
[snappyHexMesh] Help with Snappy: no layers growing GianF OpenFOAM Meshing & Mesh Conversion 2 September 23, 2020 08:26
[snappyHexMesh] Triangular elements in boundary layers generated by snappyHexMesh mike.franky OpenFOAM Meshing & Mesh Conversion 0 June 3, 2018 09:46
[snappyHexMesh] snappyHexMesh problem shengqiming OpenFOAM Meshing & Mesh Conversion 0 December 15, 2016 08:35
[snappyHexMesh] SnappyHexMesh segmentation Fault nithishgupta OpenFOAM Meshing & Mesh Conversion 1 December 18, 2014 04:03
[snappyHexMesh] Boundary layer generation problems ivan_cozza OpenFOAM Meshing & Mesh Conversion 0 October 6, 2010 13:47
