[mesh manipulation] creating faceSet
Like Tree1Likes
  • 1 Post By ganeshv
Old   June 8, 2011, 11:55
Default creating faceSet
Ganesh Vijayakumar
ganeshv is on a distinguished road
I need to create a list of faceSets as follows
PtrList<faceSet> faceSetList(hFaceLevelsTotal) ;
forAll(faceSetList,hLevel) {
boxToFace thisLevel(mesh, treeBoundBox(point(0.0, 0.0, double(hLevel)*dz-dz/10.0),point(L,L, double(hLevel)*dz+dz/10.0))) ;
faceSetList.set(hLevel, new faceSet(mesh,"blah",0)) ;
thisLevel.applyToSet(topoSetSource::NEW, faceSetList[hLevel]) ;
I then loop over the faces to get the average in the faceSet as follows.
forAll(faceSetList, hLevel) {
bAvg[hLevel] = 0 ;
forAllConstIter(faceSet, faceSetList[hLevel], iter) {
label faceI = iter.key() ;
bAvg[hLevel] = bAvg[hLevel]+[faceI];
This seems to work on a smaller grid with 32 procs. But when I scale it up to a much larger grid with 96 procs it always fails after 3 iterations no matter what my initial condition is. The code runs fine without this averaging step. I have a feeling it has something to do with how I am using iter.key(). Can anyone throw some light on this? Also is there a way to make the boxToFace avoid boundary faces?
ganesh
ganeshv is offline   Reply With Quote
Old   June 15, 2011, 09:13
Default Wrong method
Ganesh Vijayakumar
This is the wrong way to create the faceSet. It turns out that if we try to create the faceSet after domain decomposition, additional processor boundary faces are added. The best way to do this was to use a script with setSet, use setsToZones and then use simpleFunctionObjects like before to average them. The only problem was that I had to write a script to write the functionObjects part of the controlDict.
WaterHammer1985 likes this.
boxtoface, faceset
Creating faceSet on stl-surface mjans OpenFOAM Pre-Processing 2 April 17, 2019 02:43
OpenFoam restarting simulation, stops at first Time loop syntex OpenFOAM Running, Solving & CFD 4 April 5, 2019 11:20
Possible Bug in pimpleFoam (or createPatch) (or fluent3DMeshToFoam) cfdonline2mohsen OpenFOAM 3 October 21, 2013 09:28
Creating nonOrtho faceSet alf12 OpenFOAM Pre-Processing 0 August 7, 2012 11:52
Problem in running ICEM grid in Openfoam Tarak OpenFOAM 6 September 9, 2011 17:51
