[Commercial meshers] foamMeshToFluent not working with snappyhexmesh |
December 4, 2011, 18:54 |
mauricio
Rep Power: 17 |
Hello every1!
it's been a while now but it's beginning to bother me. The meshes built with snappyhexmesh. I wanna check the element in a 3d view but i cant. Paraview doent allow that since we get projections. Then i went for a different viewer which recognizes fluent, ansys, starcd formats. When i use the utilities, foamMeshToFluent or the other one to starCD, they finish w/o errors but my viewer keeps telling me the files are "corrupted" somehow. then i ask: can u recommend a different viewer? or could the utilities be somewhat broken? i rly need to take a better look at my meshes build with snappy tyty |
January 9, 2012, 07:08 |
Mads Reck
Rep Power: 17 |
Hello!
Any progress on this? I see the same problem at my end. A snappyHexMesh generated OpenFOAM mesh converted with foamMeshToFluent without issues does not read into either CFX-Pre or ICEM. /Mads
Online free airfoil-mesher for OpenFOAM here |
January 9, 2012, 07:42 |
mauricio
Rep Power: 17 |
hihi..
i havent worked on this issue since this post but i have given some thoughts into the issue..im not sure but this gotta be an element/numbering issue. i dont think tolerances should be the problem... as soon as i get back to my pc i should "debug" my viewer and the files.. -first i should try to convert a simple blockMesh into *.msh/*.cas -then i should create a cube inside my bm domain and use snappy first w/o layers.. -then i convert another cube domain with snappy mesh but with layers if i succeed then the conversion issue i have should be sth to do with numbering/ordering cuz u shouldnt go wrong with hexaedrons only... else, if i dont, then it's a mesh type issue, the elements or some polyhedrons created by snappy are not recognizable by the current pre-post.. hence i wanted to see the mesh in 3d again ill need some time to make those checks... i currently tried hm software to see the mesh and im getting those erros, but if ur using ansys' pre-post utilities and ur getting the same errors then the conversion from snappy really should the problem and therefore i'll exclude trying other pre-post to check the mesh atm if u find anything, pls let me know... thx |
January 9, 2012, 09:10 |
Mads Reck
Rep Power: 17 |
Okay I see
I tried the foamToStarMesh tool also but I can't read the output from that tool into ICEM either...so currently I have no way of transferring FOAM data/meshes to CFX. Mads
[snappyHexMesh] snappyHexMesh runs endless - I need general advise | TeresaT | OpenFOAM Meshing & Mesh Conversion | 5 | November 17, 2015 02:50 |
centOS 5.6 : paraFoam not working | yossi | OpenFOAM Installation | 2 | October 9, 2013 01:41 |
snappyHexMesh - memory corruption (OF-v. 2.2.x) | pct | OpenFOAM Bugs | 9 | July 21, 2013 13:57 |
DPM parallel is not working but serial is working | johnwinter | FLUENT | 1 | March 27, 2012 02:01 |
[snappyHexMesh] SnappyHexMesh not generate mesh first time | mavimo | OpenFOAM Meshing & Mesh Conversion | 4 | August 26, 2008 07:08 |
