-   OpenFOAM Mesh Utilities (http://www.cfd-online.com/Forums/openfoam-meshing-utilities/)
-   -   polyDualMesh, create a tetrahedral mesh from a polyhedral mesh (http://www.cfd-online.com/Forums/openfoam-meshing-utilities/97662-polydualmesh-create-tetrahedral-mesh-polyhedral-mesh.html)
Martin80 February 22, 2012 06:04
I am using polyDualMesh and finally I get a polyhedral Mesh, but I need a tetrahedral Mesh.
Is there a posibility in OpenFoam
to create a tetrahedral Mesh by using polyDualMesh
or
is there a way to create a tetrahedral Mesh from a polyhedral Mesh?
Thanks for any hint,
M.
olivierG February 22, 2012 10:02
hello,
You can't create a tetrahedral Mesh from a polyhedral Mesh, since it does exactly the opposite. And if you run polyDualMesh twice, you get the dual of the polymesh, which is again a polyhedral mesh.
If you want a thetrahedral mesh, look at netgen (with salome) / gmsh / engrid /...
regards,
olivier
Martin80 February 22, 2012 10:28
thanks for your quick answer, but I don't agree, that it is not possible to create a tetrahedral grid from a polyhedral grid.
It is always possible to split a polyhedron into a set of tetrahedrons.
(The reason why I'm using polyDualMesh is because the cell centres should become my new grid points for some reason.)
I have found in openfoam-1.6-ext the application "tetDecomposition", but this application adds additional points.
B.r. Martin.
Hanzo January 29, 2013 00:36
Hello Martin,
did you find a way to convert your polyhedral mesh into a tetrahedral mesh? Please let me know :)
Best,
Hanzo
wyldckat January 30, 2013 17:52
Greetings to all!
@Hanzo - I think the solution he probably used was this:
Namely this one: https://github.com/ogoe/OpenFOAM-1.6...tDecomposition
The need for adding new points should be rather simple: without new points, the boundaries are not preserved, if the cell centers are used as vertexes for the tetrahedral mesh.
Best regards,
Bruno
Hanzo January 30, 2013 23:07
Originally Posted by wyldckat (Post 405163)
Greetings to all!
Thanks a lot Bruno. Works nice.
