Home > Forums > OpenFOAM Mesh Utilities
mergeMeshes problem
Old   February 29, 2012, 12:26
Default mergeMeshes problem
Attesz's Avatar
Attesz
Attesz is an unknown quantity at this point
Hi all,
I created two meshes in ICEM and exported to fluent .msh format. After that I ran the fluent3DMeshToFoam app to create the OpenFOAM mesh. Until this everything is fine, but if I want to merge the meshes using the mergeMeshes utility, the program fails. I have 3M cells in inlet region as Master and 9M cells in rotor region.
Do you have any idea for the reason? Thanks in advance!
Here is the output of the process:
| \\ / O peration | Version: 2.1.0 |
| \\ / A nd | Web: www.OpenFOAM.org |
| \\/ M anipulation | |
Build : 2.1.0-bd7367f93311
Exec : mergeMeshes OFsimulation rotor
Date : Feb 29 2012
Time : 17:01:15
Host : ""
PID : 32047
Case :
nProcs : 1
allowSystemOperations : Disallowing user-supplied system call operations
Master: "OFsimulation" region region0
mesh to add: "rotor" region region0
Create Times
Reading master mesh for time = 0
Create mesh
Reading mesh to add for time = 0
Create mesh
Writing combined mesh to 1e-05
patch names:
28
HOUSING_INLET
ROTORSHROUD_GAP_INLET
ROTORHUB
AMI_INROT1
ROTORSHROUD_INLET
BOXTOPWALL
BOXLEFTWALL
BOXRIGHTWALL
BOXREARWALL
BOXBOTTOMWALL
IN
ROTORSHROUD_EDGE
HOUSING_STEP
AMI_INROTGAP1
ROTORSHROUD_ROTOR
ROTORBLADES
ROTORBLADES_LE
ROTORBLADES_TE
ROTORHUB_BLADEROOT
AMI_ROTSTAT2
MOTOR_BACK_PLATE_INROTOR
AMI_INROT2
HOUSING_ROTOR
ROTORSHROUD_END
HOUSING_GAP_ROTOR
ROTORSHROUD_GAP_FINE
AMI_INROTGAP2
ROTORSHROUD_GAP_ROTOR
patch types:
28
wall
wall
wall
wall
wall
wall
wall
wall
wall
wall
wall
wall
wall
wall
wall
wall
wall
wall
wall
wall
wall
wall
wall
wall
wall
wall
wall
wall
point zone names:
0
face zone names:
2
int_DOMAIN_INLET
int_DOMAIN_ROTOR
cell zone names:
2
DOMAIN_INLET
DOMAIN_ROTOR
Copying old patches
Adding new patches.
--> FOAM FATAL ERROR:
Illegal zoneID 1 for face 5083336
From function resetZones(const polyMesh&, polyMesh&, labelListList&labelListList&, labelListList&)
in file polyTopoChange/polyTopoChange/polyTopoChange.C at line 1651.
FOAM aborting
#0 Foam::error:rintStack(Foam::Ostream&) in "/software/oss/OpenFOAM/OpenFOAM-2.1.0/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#1 Foam::error::abort() in "/software/oss/OpenFOAM/OpenFOAM-2.1.0/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#2 Foam:olyTopoChange::resetZones(Foam:olyMesh const&, Foam:olyMesh&, Foam::List<Foam::List<int> >&, Foam::List<Foam::List<int> >&, Foam::List<Foam::List<int> >&) const in "/software/oss/OpenFOAM/OpenFOAM-2.1.0/platforms/linux64GccDPOpt/lib/libdynamicMesh.so"
#3 Foam:olyTopoChange::changeMesh(Foam:olyMesh&, bool, bool, bool, bool) in "/software/oss/OpenFOAM/OpenFOAM-2.1.0/platforms/linux64GccDPOpt/lib/libdynamicMesh.so"
in "/software/oss/OpenFOAM/OpenFOAM-2.1.0/platforms/linux64GccDPOpt/bin/mergeMeshes"
#6 __libc_start_main in "/lib64/libc.so.6"
Aborted (core dumped)
CFD= Cleverly Formatted Data
Attesz is offline   Reply With Quote
Old   February 29, 2012, 13:35
Attesz's Avatar
Attesz
I "solved" the problem by using the most recent release of OF2.1.x.
Old   December 14, 2013, 09:19
Ye Zhang
kiddmax is on a distinguished road
Hi attesz
I have exactly the same problem as you. Unfortunately I have been using OF2.1.0. So do you have some other ideas?
Ye
kiddmax is offline   Reply With Quote
Old   July 29, 2015, 04:15
Vineet Bhola
vineet_bhola is on a distinguished road
I am using currently Openfoam version 2.0.x. I have got the same error. Did you find a solution for the merging error?
vineet_bhola is offline   Reply With Quote
Thread Tools
Trackbacks are On
UDF compiling problem Wouter Fluent UDF and Scheme Programming 6 June 6, 2012 04:43
Problem in implementing cht tilek CFX 3 May 8, 2011 08:39
natural convection problem for a CHT problem Se-Hee CFX 2 June 10, 2007 06:29
Adiabatic and Rotating wall (Convection problem) ParodDav CFX 5 April 29, 2007 19:13
Is this problem well posed? Thomas P. Abraham Main CFD Forum 5 September 8, 1999 14:52
