February 29, 2012, 11:26 |
mergeMeshes problem
#1 | |
Attesz
I created two meshes in ICEM and exported to fluent .msh format. After that I ran the fluent3DMeshToFoam app to create the OpenFOAM mesh. Until this everything is fine, but if I want to merge the meshes using the mergeMeshes utility, the program fails. I have 3M cells in inlet region as Master and 9M cells in rotor region. Do you have any idea for the reason? Thanks in advance! Here is the output of the process: Quote:
February 29, 2012, 12:35 |
Attesz
I "solved" the problem by using the most recent release of OF2.1.x.
December 14, 2013, 08:19 |
Ye Zhang
Hi attesz
I have exactly the same problem as you. Unfortunately I have been using OF2.1.0. So do you have some other ideas? Ye |
July 29, 2015, 04:15 |
Vineet Bhola
Rep Power: 10 |
I am using currently Openfoam version 2.0.x. I have got the same error. Did you find a solution for the merging error?
BuoyantBoussinesqSimpleFoam_Facing problem | Mondal131211 | OpenFOAM Running, Solving & CFD | 1 | April 10, 2019 19:41 |
UDF compiling problem | Wouter | Fluent UDF and Scheme Programming | 6 | June 6, 2012 04:43 |
natural convection problem for a CHT problem | Se-Hee | CFX | 2 | June 10, 2007 06:29 |
Adiabatic and Rotating wall (Convection problem) | ParodDav | CFX | 5 | April 29, 2007 19:13 |
Is this problem well posed? | Thomas P. Abraham | Main CFD Forum | 5 | September 8, 1999 14:52 |
