makeAxialMesh - installation issues
i want to install MakeAxialMesh, but the result when calling the program with "makeAxialMesh" is always "command not found". I tried a lot and read forums without success. I am relatively new to Linux, so there may be a easy solution i do not know. Here is my setup: The given computer has OF2.01 installed at ThinkPad-Edge:/opt/openfoam201$ I changed to the folder ThinkPad-Edge:/opt/openfoam201/applications/utilities/mesh/manipulation/ and executed sudo svn checkout https://openfoam-extend.svn.sourcefo.../MakeAxialMesh Then it was installed at: ThinkPad-Edge:/opt/openfoam201/applications/utilities/mesh/manipulation/MakeAxialMesh$ Within this folder, there is another folder named "makeAxialMesh". :confused: But i can't call the programm with "makeAxialMesh". Do i need to add something to the $HOME/.bashrc or the other bashrc located somewhere in the openfoam folder? What did I do wrong? Thanks a lot for helping!! :) |
I executed the line given in the download section:
sudo svn checkout https://openfoam-extend.svn.sourcefo.../MakeAxialMesh That's all - is it right? Is ist "compiled"? I found no Path FOAM_USER_APPBIN. Is it installed with OF or do i need to create it somewhere? Should i execute the above mentioned line in this directory? Thanks a lot! |
FOAM_USER_APPBIN is an environment variable and the contents of that directory can be accessed with echo $FOAM_USER_APPBIN (but that is non-OF-specific) Bernhard |
