[snappyHexMesh] snappyHexMesh for porous - multiple regions without boundaries
Old   April 2, 2012, 04:01
Default snappyHexMesh for porous - multiple regions without boundaries
Per Jørgensen
perjorgen is on a distinguished road
Hi
I am using sHM for porousSimpleFoam
As a starting point I used snappyMultiRegionHeater with 2 stl files as input without splitting the mesh
The problem is that sHM defines a boundary between the porous zone and the non-porous zone - when I remove the (wall) boundary from constant/polyMesh/boundary I can run the the application
How can I run sHM with two regions seperated by a stl surface without getting a boundary between the regions?
(If there is a better way I would be happy to know
Thanks in advance
Per
perjorgen is offline   Reply With Quote
interDyMFoam - One rigid body, multiple boundaries mattkram OpenFOAM Running, Solving & CFD 1 March 29, 2021 08:36
how to set periodic boundary conditions Ganesh FLUENT 15 November 18, 2020 06:09
Multiple patch types for different mesh regions Dreoasteh OpenFOAM 0 October 10, 2017 05:34
[CAD formats] Clean / Repair STL file with multiple regions on command line matthiasd OpenFOAM Meshing & Mesh Conversion 6 May 24, 2016 06:51
Fluid Regions donot communicate via "Attach" Boundaries sdwijeya STAR-CD 0 August 28, 2009 13:26
