[mesh manipulation] Problem with simpleFoam
Like Tree1Likes
  • 1 Post By lovecraft22
Old   March 22, 2012, 13:19
Default Problem with simpleFoam
Aroua
appa is on a distinguished road
I am learning how to use OpenFoam and I am really lost right now.
I created a 3D mesh file using gmesh (based on a scilab script to generate a geo file with NACA dat file).
I created a case directory under the simpleFoam airFoil2D directory, but after the simpleFoam command on a terminal I get this error .
PHP Code:
--> FOAM FATAL IO ERROR
keyword FrontAndBack is undefined in dictionary "/home/appa/Bureau/essaiOF/0/p::boundaryField"
file: /home/appa/Bureau/essaiOF/0/p::boundaryField from line 25 to line 40.
    From
function dictionary::subDict(const wordkeyword) const
in file db/dictionary/dictionary.C at line 461.
FOAM exiting
So I guess that the airFoil2D tutorial can not run my 3D example and I don't know how to it.
PHP Code:
/*--------------------------------*- C++ -*----------------------------------*\
| \\      /  F ield         | OpenFOAM: The Open Source CFD Toolbox           |
|  \\    /   O peration     | Version:  2.1.0                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
|    \\/     M anipulation  |                                                 |
FoamFile
version     2.0;
format      ascii;
    class
volScalarField;
object      p;
dimensions      [0 2 -2 0 0 0 0];
internalField   uniform 0;
boundaryField
inlet
type            freestreamPressure;
outlet
wall
type            zeroGradient;
frontAndBack
type            empty;
I am not very good with C++ language so any hint would be helpful
thanks in advance
appa is offline   Reply With Quote
Old   March 22, 2012, 16:32
lore
lovecraft22 is on a distinguished road
Send a message via Skype™ to lovecraft22
Hi;
the solver is looking for FrontAndBack and is not finding it in your pressure boundary condition because it states frontAndBack instead.
Always remember that openFoam is case sensitive so you need to change that to a capital initial word: FrontAndBack.
appa likes this.
lovecraft22 is offline   Reply With Quote
Old   March 23, 2012, 02:45
Aroua
You're right !!thank you for this quick answer. In fact, I had to do some changes in the boundary file under the polyMesh directory to make the keywords match. I guess I have to learn how to make programs with C++ to be more efficient with OF.
Old   May 3, 2012, 03:45
anonymous
libia87 is on a distinguished road
I have the same error!!!
--> FOAM FATAL IO ERROR:
keyword s1 is undefined in dictionary "/home/xr12/Anna/buoyantBoussinesqSimpleFoam/hotRoom_20/0/p_rgh::boundaryField"
and my problem is not the capital leters, what could it be??
libia87 is offline   Reply With Quote
Old   May 3, 2012, 05:59
Aroua
you have to make sure that the keyword s1 is defined in all the files, here it seems that you didn't define it in the file "/home/xr12/Anna/buoyantBoussinesqSimpleFoam/hotRoom_20/0/p_rgh"
problem w/ running simpleFoam in parallel mazdak OpenFOAM Running, Solving & CFD 27 December 8, 2023 03:10
Problem With using snappyhexmesh and getting simplefoam to work. Ivanj56 OpenFOAM Running, Solving & CFD 0 March 22, 2016 06:20
Problem to run simpleFoam using qsub? be_inspired OpenFOAM 1 December 22, 2015 12:53
Convergence Problem simpleFoam with reaction unicat OpenFOAM Running, Solving & CFD 1 September 29, 2015 10:03
Problem in running simpleFoam tutorial Lana OpenFOAM Running, Solving & CFD 1 April 10, 2013 11:08
