AMI rotating domain meshing errors
I've generated my mesh of an axial fan in ICEM CFD. It has three domains, connected by interfaces. I've saved the them separately, then converted with fluent3DMeshToFoam. Then I've merged them with mergeMeshes. Then, after checkMesh, I'm getting the following errors. Could you please make it clearer what are the problems here? Code:
Checking topology... |
And also during the mesh conversion, I'm getting this error using fluentMeshToFoam:
Building patch-less mesh...--> FOAM Warning : From function polyMesh::polyMesh(... construct from shapes...) in file meshes/polyMesh/polyMeshFromShapeMesh.C at line 619 Found 266575 undefined faces in mesh; adding to default patch. done. |
