Home > Forums > OpenFOAM Meshing & Mesh Conversion
Mesh conversion Starccm+ --> Salome
Like Tree1Likes
  • 1 Post By elvis
Old   May 23, 2012, 04:10
Default Mesh conversion Starccm+ --> Salome
daxindamix is on a distinguished road
does anyone know how to load within Salome a mesh coming from Star CCM+ (.ccm, .case, .fvuns, .plt, .cel, .sbd, .ntl, .trn)?
Thanks.
daxindamix is offline   Reply With Quote
Old   May 24, 2012, 02:26
Mark Olesen
olesen will become famous soon enough
Thanks.
Paraview (and VTK?) has a vtkProStarReader that should properly handle PROSTAR cel/vrt format, which you can also export from STARCCM.
I don't know though if this reader has made its way into the particular VTK version that Salome is using.
olesen is offline   Reply With Quote
Old   May 24, 2012, 05:24
indeed I can load in Paraview a file coming from PROSTAR, but if export it (.pov, .vrml, .x3d, .x3db), then I cannot load it into Salome (only .dat, .med, .stl, .unv, .sauv) to work the mesh.
I have actually the same kind of problem with the geometry that I cannot export as iges or stp with starccm+.
Old   May 24, 2012, 09:19
Elvis
elvis is on a distinguished road
but if you can load it into Paraview you should be able to export/write as STL-file, so at least you could load a STL-file into Salome.
Or maybe Meshlab can do the converting from those mentioned (.pov, .vrml, .x3d, .x3db) into a STL-file
What about CGNS, isnīt CGNS HDF5 based and Salome "Med-file" is HDF5 as well
I checked Salome 6.4.0 the GEOMETRY modul can import ACIS (*.sat). BREP (*.brep), IGES (*.iges, *.igs), STEP (*.step, *.stp)
MESH modul can import&export DAT, UNV, MED, STL, CGNS and SAUV
kid likes this.
elvis is online now   Reply With Quote
Thread Tools
Trackbacks are On
how to set periodic boundary conditions Ganesh FLUENT 13 January 22, 2014 05:11
[ICEM] Generating Mesh for STL Car in Windtunnel Simulation tommymoose ANSYS Meshing & Geometry 48 April 15, 2013 04:24
Salome mesh with NETGEN 1D-2D-3D for OF kriz OpenFOAM 4 June 14, 2010 06:17
external flow with snappyHexMesh chelvistero OpenFOAM 11 January 15, 2010 20:43
SimpleFoam error with mesh imported from salome matteo OpenFOAM Running, Solving & CFD 9 January 2, 2008 05:04
