[blockMesh] Conical Mesh with blockMesh?
Old   July 6, 2012, 10:57
Default Conical Mesh with blockMesh?
ic3wall is on a distinguished road
Is there a way to create a conical volume with blockMesh ?
Then, would it be possible to impose only a couple a value (U for example) on the outer boundary (circle) ?
Thank you
ic3wall is offline   Reply With Quote
Old   July 8, 2012, 10:06
Ok I found an example of meshing here :
http://openfoamwiki.net/index.php/Si...nical_diffuser
However, I would like to prescribe radial velocities on the sides of the cone (not the "inlet" and "outlet").
Is there an existing boundary condition that I can use to impose radial velocities in spherical coordinates ?
Old   July 9, 2012, 04:35
notyet
karkar is on a distinguished road
Maybe groovyBC can help you there, which offers parametrized boundary conditions.
karkar is offline   Reply With Quote
how to set periodic boundary conditions Ganesh FLUENT 15 November 18, 2020 06:09
[snappyHexMesh] Snappyhex mesh: poor inlet mesh Swagga5aur OpenFOAM Meshing & Mesh Conversion 1 December 3, 2016 16:59
Star CCM Overset Mesh Error (Rotating Turbine) thezack Siemens 7 October 12, 2016 11:14
[snappyHexMesh] SnappyHexMesh for internal Flow vishwa OpenFOAM Meshing & Mesh Conversion 24 June 27, 2016 08:54
[snappyHexMesh] SnappyHexMesh no layers and no decent mesh for complex geometry pizzaspinate OpenFOAM Meshing & Mesh Conversion 1 February 25, 2015 07:05
