[Other] How to get mesh total volume quickly? |
August 1, 2012, 15:24 |
Rep Power: 14 |
What's the fastest way to get the total volume of a mesh precisely (sum of volume of each cell)? I know checkMesh is giving Mesh total volume but i'm not sure if it's really mesh total volume or volume of bounding box .. Thank you! |
August 1, 2012, 17:24 |
Travis Carrigan
Rep Power: 15 |
What software are you using to generate the mesh? It may provide the appropriate utilities for doing a volume calculation.
August 1, 2012, 19:20 |
Rep Power: 14 |
checkMesh gives the volume of the mesh not the bounding box
you can easily calculate the volume of the bounding box yourself.. compare with checkMesh volume given |
January 21, 2016, 12:34 |
Peter
Rep Power: 10 |
Dear Foamers,
I would like to get the total volume of a solution domain. I tried Code:
scalar totalVolume(0.0); forAll(mesh_.cells(),i) //cellI) { totalVolume += mesh_.V()[i]; //cellI]; } Then I found this last answer and hence I tried to get it with 'checkMesh'. Unfortunately, I can't find the code snippet in the folder /OpenFOAM-3.0.1/applications/utilities/mesh/manipulation/checkMesh/ using e.g.: grep -nr "volume" Can you please show me, where they hid it? Regards, Peter |
January 21, 2016, 15:14 |
Why have you decided to iterate over strange cells() list? This does the job: Code:
scalar vol = 0.0; forAll(mesh.V(), idx) { vol += mesh.V()[idx]; } reduce(vol, sumOp<scalar>()); Info<< vol << endl; Code:
scalar vol = gSum(mesh.V()); Info<< vol << endl; Code:
scalar vol = sum(mesh.V()); reduce(vol, sumOp<scalar>()); Also it is up to you to check if you run 2D axisymmetric case and multiply result to get real mesh volume. Answering you last question: it is in primitiveMeshCheck.C (http://foam.sourceforge.net/docs/cpp...ce.html#l00318). Last edited by alexeym; January 22, 2016 at 17:27. |
January 22, 2016, 03:57 |
Peter
Rep Power: 10 |
Thanks Alexey,
it works (I use Code:
scalar vol = gSum( mesh_.V() ); |
[ICEM] Negative volume error in hybrid mesh | siw | ANSYS Meshing & Geometry | 4 | September 3, 2014 05:25 |
Moving mesh | Niklas Wikstrom (Wikstrom) | OpenFOAM Running, Solving & CFD | 122 | June 15, 2014 06:20 |
[ICEM] Generating Mesh for STL Car in Windtunnel Simulation | tommymoose | ANSYS Meshing & Geometry | 48 | April 15, 2013 04:24 |
channelFoam for a 3D pipe | AlmostSurelyRob | OpenFOAM | 3 | June 24, 2011 13:06 |
Icemcfd 11: Loss of mesh from surface mesh option? | Joe | CFX | 2 | March 26, 2007 18:10 |
