Problem with changed MixerVesselAMI2D tutorial
1 Attachment(s)
I imorted another mesh in the MixerVesselAMI2D tutorial.
The mesh has a cube as rotor. I only changed the mesh and created the files in the set dirctory and also the cellZones file. when I run the case it only creates a 0.1 time folder and then crashes. In the log.pimpleDyMFoma it looks like the calculation went through. What could be the reason? On the attached picture you can see the mesh before it crashes. Why is the pressure so wrong? Regards, Alex |
