-   OpenFOAM Meshing & Mesh Conversion (http://www.cfd-online.com/Forums/openfoam-meshing/)
-   -   ideasUnvToFoam error (http://www.cfd-online.com/Forums/openfoam-meshing/106637-ideasunvtofoam-error.html)
Luchini September 4, 2012 08:58
I am trying to convert a .unv mesh with groups.
Does anyone knows wha are these errors?
a)
For group 2 named outflow trying to read 1669 patch face indices.
--> FOAM Warning :
From function readSets(..)
in file ideasUnvToFoam.C at line 552
Reading "/XXX/YYY/CCC/Mesh_1.unv" at line 496102
When reading patches expect entity type code 8
Skipping group code 7
b)
Constructing mesh with non-default patches of size:
--> FOAM Warning :
From function polyMesh::polyMesh(... construct from shapes...)
in file meshes/polyMesh/polyMeshFromShapeMesh.C at line 619
Found 13406 undefined faces in mesh; adding to default patch.
End
Thank you for your help
Luchini September 4, 2012 10:11
problem solved.
In Salome for a 3D case, i was creating the mesh group of points (the default option) instead of faces.
