[Other] Error of using MakeAxialMesh ultility
Old   April 14, 2013, 21:23
Default Error of using MakeAxialMesh ultility
Guifan Li
liguifan is on a distinguished road
Hello everyone,
I am trying to generate a very simple 2D wedge which is part of a cylinder water tank. I started from the begging by follwoing the example here
http://openfoamwiki.net/index.php/Contrib_MakeAxialMesh
However, I met the following errors
liguifan@liguifan-laptop:~/Desktop/damBreak2$ makeAxialMesh -axis axi -wedge frontAndBackPlanes
| \\ / O peration | Version: 2.1.1 |
| \\ / A nd | Web: www.OpenFOAM.org |
| \\/ M anipulation | |
Build : 2.1.1-221db2718bbb
Exec : makeAxialMesh -axis axi -wedge frontAndBackPlanes
Date : Apr 14 2013
Time : 21:14:05
Host : "liguifan-laptop"
PID : 2821
Case : /home/liguifan/Desktop/damBreak2
nProcs : 1
allowSystemOperations : Disallowing user-supplied system call operations
Create time
Create mesh for time = 0
Using old mode. Dictionary not used
Plane of the grid: (0 0 1) (0.02 0.04 0.005)
The rotation-axis: ((0 0 0.005) (0.04 0 0.005))
Creating wedge with an opening angle of 5 degrees
Projecting nodes
#0 Foam::error:rintStack(Foam::Ostream&) in "/opt/openfoam211/platforms/linuxGccDPOpt/lib/libOpenFOAM.so"
#1 Foam::sigFpe::sigHandler(int) in "/opt/openfoam211/platforms/linuxGccDPOpt/lib/libOpenFOAM.so"
#2 Uninterpreted:
in "/home/liguifan/OpenFOAM/liguifan-2.1.1/platforms/linuxGccDPOpt/bin/makeAxialMesh"
#5 __libc_start_main in "/lib/tls/i686/cmov/libc.so.6"
Floating point exception
Can anyone help me with that?
Here are my files under folder 0 and my Gmsh file
Gmsh
Point(1) = {0, 0, 0};
Point(2) = {0.04, 0, 0};
Line(1) = {1, 2};
Extrude {0, 0.08, 0} {
Line{1};Layers{10};Recombine;
Extrude {0, 0, 0.01} {
Surface{5};Layers{1};Recombine;
Transfinite Surface "*";
Recombine Surface "*";
Transfinite Volume "*";
Physical Surface("frontAndBackPlanes") = {27,5};
Physical Surface("outerWall") = {22};
Physical Surface("axi") = {14};
Physical Surface("atmosphere") = {26};
Physical Surface("lowerWall") = {18};
Physical Volume("internal") = {1};
alpha1.org
FoamFile
version 2.0;
format ascii;
class volScalarField;
object alpha;
dimensions [0 0 0 0 0 0 0];
internalField uniform 0;
boundaryField
outerWall
type zeroGradient;
lowerWall
type zeroGradient;
frontAndBackPlanes
type wedge;
atmosphere
type inletOutlet;
inletValue uniform 0;
value uniform 0;
axi
type wedge;
p_rgh
FoamFile
version 2.0;
format ascii;
object p_rgh;
dimensions [1 -1 -2 0 0 0 0];
boundaryField
outerWall
type buoyantPressure;
value uniform 0;
frontAndBackPlanes
type wedge;
//value uniform 0;
lowerWall
value uniform 0;
atmosphere
type totalPressure;
p0 uniform 0;
U U;
phi phi;
rho rho;
psi none;
gamma 1;
value uniform 0;
axi
type patch;
constant/Mesh/boundary
FoamFile
version 2.0;
format ascii;
class polyBoundaryMesh;
location "constant/polyMesh";
object boundary;
5
frontAndBackPlanes
type wedge;
nFaces 1280;
startFace 6816;
axi
type wedge;
nFaces 64;
startFace 8096;
lowerWall
type patch;
nFaces 160;
startFace 8160;
outerWall
type patch;
nFaces 64;
startFace 8320;
atmosphere
type patch;
nFaces 160;
startFace 8384;
Thanks in advance
liguifan is offline   Reply With Quote
Old   April 15, 2013, 17:14
Assistant Moderator
Bernhard Gschaider
Originally Posted by liguifan View Post
Hello everyone,
Gmsh
alpha1.org
p_rgh
Thanks in advance
Not quite sure. I'm not too familiar with gmsh, but it might be that the problem is that in order to work correctly the axis should be in the z=0-plane (and the mesh centered around z=0 ... z should go from -0.005 to 0.005). But I'm not completely sure. Haven't touched the source for MAM for quite some time
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
Old   April 15, 2013, 17:23
Guifan Li
Thanks for the reply.
There is one thing I am confused.
In tutorial of NozzelFlow2D, its BC for axis is empty. However in my case after I execuated makeAxialMesh command. The BC for my axis became symmetryPlane type. Do I have to change this into empty in the constant/polyMesh/boundary file and all the other BC's file in 0/ folder ?
Kind regards,
Guifan
Old   April 16, 2013, 05:39
Assistant Moderator
Bernhard Gschaider
Kind regards,
Guifan
See what works best for you. If I remember correctly the reason why MAM sets it to symmetry is that this works better if the area of the axis-patch is not 0 and it is therefor not "collapsed away"
[mesh manipulation] makeAxialMesh and axisymmetric flow yassepid OpenFOAM Meshing & Mesh Conversion 5 January 28, 2024 22:38
[Other] Installing makeAxialMesh - strange wmake error krzychu111 OpenFOAM Community Contributions 1 December 19, 2018 18:29
[mesh manipulation] How to make a pipe using makeAxialMesh tomloh OpenFOAM Meshing & Mesh Conversion 15 September 3, 2013 05:52
[mesh manipulation] makeAxialMesh - installation issues simulator4711 OpenFOAM Meshing & Mesh Conversion 3 March 21, 2012 07:59
makeAxialMesh > collapseEdges!! billynoe OpenFOAM 17 February 21, 2011 04:29
