[surface handling] SurfaceFeatureExtract Foam::error::printStack |
August 14, 2013, 22:33 |
When launching SurfaceFeatureExtract OF2.2.x on redhat6.4 sometimes I get the following error. If I launch the same files and SurfaceFeatureExtract on OF2.2.x installed on Ubuntu no error at all. Code:
// * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Reading surfaceFeatureExtractDict Surface : "EVAP.stl" Feature line extraction is only valid on closed manifold surfaces. Statistics: Triangles : 24 Vertices : 16 Bounding Box : (0.0739288 -0.14355 0.313129) (0.164224 0.14345 0.51628) Constructing feature set from included angle 170 Removing all non-manifold edges (edges with > 2 connected faces) unless they cross multiple regions Initial feature set: feature points : 10 feature edges : 26 of which region edges : 12 external edges : 9 internal edges : 5 Final feature set: points : 16 of which convex : 0 concave : 0 mixed : 10 non-feature : 6 edges : 26 of which external edges : 9 internal edges : 5 flat edges : 0 open edges : 12 multiply connected : 0 Writing extendedFeatureEdgeMesh to "/net/lnx6/home/al/plane/constant/extendedFeatureEdgeMesh/EVAP.extendedFeatureEdgeMesh" Writing extendedFeatureEdgeMesh components to "/net/lnx6/home/al/plane/constant/extendedFeatureEdgeMesh/EVAP" Writing convex feature points to "/net/lnx6/home/al/plane/constant/extendedFeatureEdgeMesh/EVAP_convexFeaturePts.obj" Writing concave feature points to "/net/lnx6/home/al/plane/constant/extendedFeatureEdgeMesh/EVAP_concaveFeaturePts.obj" Writing mixed feature points to "/net/lnx6/home/al/plane/constant/extendedFeatureEdgeMesh/EVAP_mixedFeaturePts.obj" Writing mixed feature point structure to "/net/lnx6/home/al/plane/constant/extendedFeatureEdgeMesh/EVAP_mixedFeaturePtsStructure.obj" Writing external edges to "/net/lnx6/home/al/plane/constant/extendedFeatureEdgeMesh/EVAP_externalEdges.obj" Writing internal edges to "/net/lnx6/home/al/plane/constant/extendedFeatureEdgeMesh/EVAP_internalEdges.obj" Writing flat edges to "/net/lnx6/home/al/plane/constant/extendedFeatureEdgeMesh/EVAP_flatEdges.obj" Writing open edges to "/net/lnx6/home/al/plane/constant/extendedFeatureEdgeMesh/EVAP_openEdges.obj" Writing multiple edges to "/net/lnx6/home/al/plane/constant/extendedFeatureEdgeMesh/EVAP_multipleEdges.obj" Writing region edges to "/net/lnx6/home/al/plane/constant/extendedFeatureEdgeMesh/EVAP_regionEdges.obj" Writing featureEdgeMesh to "/net/lnx6/home/al/plane/constant/triSurface/EVAP.eMesh" Surface : "H-CORE-FRONT.stl" Feature line extraction is only valid on closed manifold surfaces. Statistics: Triangles : 71521 Vertices : 35766 Bounding Box : (0.1068 -0.14355 0.252663) (0.279262 0.14345 0.540279) Constructing feature set from included angle 170 Removing all non-manifold edges (edges with > 2 connected faces) unless they cross multiple regions Initial feature set: feature points : 728 feature edges : 4462 of which region edges : 127 external edges : 2692 internal edges : 1643 #0 Foam::error::printStack(Foam::Ostream&) in "/net/lnx6/home/al/centFOAM//OpenFOAM/OpenFOAM-2.2.x/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" #1 Foam::sigFpe::sigHandler(int) in "/net/lnx6/home/al/centFOAM//OpenFOAM/OpenFOAM-2.2.x/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" #2 at sigaction.c:0 #3 Foam::tmp<Foam::Field<Foam::Vector<double> > > Foam::operator/<Foam::Vector<double> >(Foam::UList<Foam::Vector<double> > const&, Foam::tmp<Foam::Field<double> > const&) in "/net/lnx6/home/al/centFOAM//OpenFOAM/OpenFOAM-2.2.x/platforms/linux64GccDPOpt/lib/libedgeMesh.so" #4 void Foam::extendedFeatureEdgeMesh::sortPointsAndEdges<Foam::triSurface>(Foam::triSurface const&, Foam::List<int> const&, Foam::List<int> const&, Foam::List<int> const&) in "/net/lnx6/home/al/centFOAM//OpenFOAM/OpenFOAM-2.2.x/platforms/linux64GccDPOpt/lib/libedgeMesh.so" #5 Foam::extendedFeatureEdgeMesh::extendedFeatureEdgeMesh(Foam::surfaceFeatures const&, Foam::objectRegistry const&, Foam::fileName const&) in "/net/lnx6/home/al/centFOAM//OpenFOAM/OpenFOAM-2.2.x/platforms/linux64GccDPOpt/lib/libedgeMesh.so" #6 in "/net/lnx6/home/al/centFOAM/OpenFOAM/OpenFOAM-2.2.x/platforms/linux64GccDPOpt/bin/surfaceFeatureExtract" #7 __libc_start_main in "/lib64/libc.so.6" #8 in "/net/lnx6/home/al/centFOAM/OpenFOAM/OpenFOAM-2.2.x/platforms/linux64GccDPOpt/bin/surfaceFeatureExtract" Floating point exception (core dumped) Thank you Al Last edited by donQi; August 15, 2013 at 01:35. |
August 15, 2013, 01:43 |
OK problem solved.
Cause of the error: the STL file used were seen as non closed manifold (even if graphically no evident holes were present) Solution: recreate the STL with a better quality mesh. relaunch surfaceFeatureExtract with the new STL and the problem disappears. Why then in Ubuntu everything works since the beginning, I have no idea. Last edited by donQi; August 15, 2013 at 02:51. |
Display Modes | |
New Solver error Foam::error::printStack | upuli | OpenFOAM Running, Solving & CFD | 4 | May 11, 2018 02:43 |
Foam::error::PrintStack in GAMGSolver | davidicl | OpenFOAM Running, Solving & CFD | 1 | October 22, 2015 08:57 |
Foam::error::printStack in interDyMFoam when changing the floatingObject case | chun | OpenFOAM Running, Solving & CFD | 2 | August 7, 2014 03:53 |
New solver problems (Foam::error::printStack) | Elix1D | OpenFOAM Running, Solving & CFD | 9 | July 17, 2014 16:18 |
#0 Foam::error::printStack (MotorBike tutorial) | GPan1 | OpenFOAM Running, Solving & CFD | 0 | November 4, 2012 05:48 |
