Home > Forums > OpenFOAM Meshing & Mesh Conversion
Salome & snappy
Old   September 22, 2012, 12:21
Default Salome & snappy
Simone
batta31 is on a distinguished road
Hi to everyone,
I'm trying to generate a mesh with Salome (a 2D airfoil), exporting it as a .stl file and snapping it with a background mesh in order to reproduce a condition of external aerodynamics.
However, I'm failing in the use of snappyHexMesh utility; has anyone any suggestion about how to proceede, any guide to follow...?
Thanks in advance
Simone
batta31 is offline   Reply With Quote
Old   September 24, 2012, 03:54
colinB is on a distinguished road
Dear Simone,
using salome and snappy for such a comparatively simple task is in my opinion
useless, unless you follow a specific plan where you want to use these two
tools.
A better suggestion is to use blockMesh which is sufficient for such a task
and it has been done by many before you.
For references see here:
mesh airfoil NACA0012
If you use a different airfoil you can obtain offset data from various
source from the internet and then include them in the blockMesh
I hope the above is of assistance
regards
Colin
colinB is offline   Reply With Quote
Old   September 24, 2012, 05:09
Simone
Dear ColinB
I thank you very much for your answer; moreover I've seen that you have already helped people with my similar problem so I think I could find out which is my problem with your help. I'll follow your advices as soon as I can, what I would want to know is now the syntax of the polyLine command, (and the other similar ones) which are not suitably described in the UserGuide. I would also want to tell you (since I've seen that you have already discussed about it) if, according to you, it's better to have a rectangular domain or a semicircular domain in front of the airfoil. I can tell you that my simulation will involve a flow over an aifoil in positive/negative incidence.
Thank you very much again for your answer.
Old   September 25, 2012, 02:44
Dear Simone,
regarding the syntax of the various commands mentioned in that thread
I suggest you to read the various blockMeshDict files which are attached
to that thread.
regarding the domain shape, it is better to use a semi-circular shape
in order to meet all the mesh quality requirements.
However be aware that the files I uploaded are probably square shaped
(as far as I remember), for I was calculating 2-phase cases and therefore I
used an other mesh arrangement.
regards
Colin
Thread Tools
Trackbacks are On
Sailplane Modelling in Salome Platform davidod88 Main CFD Forum 0 March 11, 2012 21:06
Mesh conversion exits prematurely (Salome to OF) DMcP OpenFOAM 0 July 14, 2011 02:07
checkMesh and decomposePar crashes with salome IDEAS mesh pajofego OpenFOAM 0 June 23, 2011 08:43
Salome and Code Saturne simulation of simple room and objects cristian.ocnarescu Main CFD Forum 0 June 21, 2010 10:19
salome, openfoam and moving mesh prhlava OpenFOAM Running, Solving & CFD 8 November 9, 2009 09:59
