[Commercial meshers] Mesh conversion from Tecplot format - help |
October 6, 2012, 19:37 |
ATM
All,
I have been wanting to do a LES simulation of the NASA 2D periodic hill test case given here http://turbmodels.larc.nasa.gov/Other_LES_Data/2dhill_periodic.html using OpenFOAM. The 2D mesh provided for the case is in Tecplot 360 format the file is http://turbmodels.larc.nasa.gov/Othe...ll_grid.dat.gz given in a .dat format. I can open the mesh in Tecplot, but if I write it as a data file , ICEM CFD is not able to import it, and the error msg "cannot open file" appears. I searched online and found that this is an existing issue with reading tecplot files in ICEM. I am wondering how to import this mesh into OpenFOAM now, after defining all the boundary conditions. I could not find any way to convert this .dat file from tecplot to any format accepted by common mesh generating softwares like icem/hypermesh etc. or even solvers like Fluent. I have tried converting the dat file into a foam mesh using datToFOAM utility, but the points file somehow shows points in 3D, though the mesh is 2D. I'm quite sure that the points.tmp file is incorrect. IS there any way to get the mesh into a software so that I can define boundary conditions in it and export it into a common mesh format readable by FOAM??? Thank you in advance!!! |
October 7, 2012, 03:07 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Greetings atmcfd,
In OpenFOAM, there is no 2D. It's always 3D, but if one of the directions has empty patches on both sides, then it will simulate as if it was 2D. Study the tutorial "compressible/rhoCentralFoam/biconic25-55Run35", which provides a good example on how to use datToFoam! Best regards, Bruno
October 7, 2012, 03:16 |
#3 | |
ATM
I did tun the biconic dat file through the converter before posting in the forum... though I understood how datToFOAM works, I cannot understand how the points.tmp file had coordinates in the format (x,y,z), whereas the grid file only has x and y. I know that OF recognizes everything as 3D be default, but I do not understand where the "z" data comes from in the points.tmp file... is it something that OF "assumes", since the data is 2D? Coz, the values look very random, having both positive and negative values - and this makes the resulting mesh useless. Is there any way I can make it read this data file as is, and maybe give it some default "z" value for all the points so that its considered as 3D? Thank you for your time!! |
October 7, 2012, 03:57 |
Bruno Santos
Rep Power: 128 |
Hi again atmcfd,
So gave it a shot and it worked fine for me. Here are the steps I took:
Best regards, Bruno PS: Mmm... looks like at the bottom the mesh still has a wedge-like aspect to it... I hope you can figure out how to fix that
October 8, 2012, 03:16 |
ATM
Thank you very much Bruno!
I could do the steps and obtain the mesh - it looks good. I have some questions on this method: 1) is the blockMeshDict file containing the default points vertices ( (0 0 0) (1 0 0) (1 1 0) (0 1 0) (0 0 0.1) (1 0 0.1) (1 1 0.1) (0 1 0.1) ); supposed to be edited before I import my mesh using datToFOAM ? because we have edited the blocks "hex" part , but the don't the vertices and the boundary types specifed in the blockMeshDict refer to an entirely different geometry altogether? I did not know how to edit them according to this mesh since I obviously don't know the points. why cant I just import the mesh from dat format without using blockMesh for a different geometry? 2) Since I need to visually see the mesh to define the boundary conditions, I converted the resulting OF mesh into a Fluent mesh using foamMeshToFluent. I tried importing this in Gambit, it shows an error...something like the header file was wrong etc. The mesh opens perfectly in Fluent , though it shows all the boundary conditions for the mesh as mentioned in the blockMeshDict. Any ideas as to what is happening here? 3) My idea is to open the mesh in a mesh gen software (preferebly in Ansys WB) so that I can define proper boundary conditions and export it as a Fluent .msh , and again import it into OpenFOAM after which I can use it. But then, I have to make sure this mesh opens correctly in a mesh gen software, else I'll be in trouble Once again, I appreciate the time and help you have given here. forgive me if any of my questions looked very trivial here ..I am very new to OpenFOAM and I wish to learn it a lot more in the near future. Thanks! P.S.: this is how the header for the Fluent mesh (which OpenFOAM created ) starts: (0 "FOAM to Fluent Mesh File") (0 "Dimension:") (2 3) (0 "Grid dimensions:") (10 (0 1 c400 0 3)) (12 (0 1 60bd 0 0)) (13 (0 1 18436 0 0)) (10 (1 1 c400 1 3) ( 3.2143503000e-02 1.0033890000e+00 -1.7512432837e-03 6.4291403000e-02 1.0033660000e+00 -1.7512031412e-03 .......... .................................................. .............................. ........................................ ........................................ |
October 8, 2012, 16:56 |
#6 | |||
Bruno Santos
Rep Power: 128 |
Hi atmcfd,
datToFoam converts the list of points from ".dat" to OpenFOAM's point list format. Therefore, the points are replaced, but the mesh preserves the topology... at least in theory! But there is a strange problem here, which I mentioned and left for you to diagnose and try to fix: the original tutorial on which we're basing ourselves, needs the mesh to be in a wedge shape, because it simulates only a thin slice of the original geometry. And it seems to me that datToFoam assumes that this is the standard shape to always be used when converting... which is not what you want on your case. Quote:
As for the names of the boundary conditions: you can define them properly in "blockMeshDict", at least for the most part. If you need to have more than one patch on one of the sides, you can use createPatch. Quote:
Good luck! Bruno
October 12, 2012, 01:55 |
ATM
Bruno,
Thanks for the heads up. Just an update here: I made some changes to the datToFoam source code, in the places where the comments say that the the lines of code are meant for biconic meshes. I commented out those lines of code Code:
// We ignore the first layer of points in i and j the biconic meshes // label nPointsij = (iPoints - 1)*(jPoints - 1); ....... // if statement ignores the first layer in i and j // if (i>0 && j>0) // { // points[p++][comp] = coord; // } // } // } // } // correct error in biconic meshes // forAll(points, i) // { // if (points[i][1] < 1e-07) // { // points[i][1] = 0.0; I can open this mesh in Ansys Workbench, Fluent and Ansys CFX-Pre., whereas I cannot do so in Gambit or ICEM-CFD. Thanks !! |
October 12, 2012, 16:19 |
Bruno Santos
Rep Power: 128 |
Hi atmcfd,
I'm glad you figured it out and shared the solution! Hopefully this will be useful for or people looking for the same solution! As for the problem with importing the mesh: did you run checkMesh to confirm if the mesh is OK? There might be some weird glitch that some mesh importers don't mind, but others complain about due to the weird imperfections... By the way, this line might be affecting the resulting mesh: Code:
collapseEdges "2e-07" 5 Best regards, Bruno
October 14, 2012, 16:10 |
ATM
Hi Bruno,
I ran checkMesh and this is the output I get Code:
// * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create polyMesh for time = 0 Time = 0 Mesh stats points: 50176 internal points: 0 faces: 99382 internal faces: 49208 cells: 24765 boundary patches: 6 point zones: 0 face zones: 0 cell zones: 0 Overall number of cells of each type: hexahedra: 24765 prisms: 0 wedges: 0 pyramids: 0 tet wedges: 0 tetrahedra: 0 polyhedra: 0 Checking topology... Boundary definition OK. Cell to face addressing OK. Point usage OK. Upper triangular ordering OK. Face vertices OK. Number of regions: 1 (OK). Checking patch topology for multiply connected surfaces ... Patch Faces Points Surface topology cone 195 392 ok (non-closed singly connected) outlet 127 256 ok (non-closed singly connected) freestream 195 392 ok (non-closed singly connected) centreLeft 127 256 ok (non-closed singly connected) wedge1 24765 25088 ok (non-closed singly connected) wedge2 24765 25088 ok (non-closed singly connected) Checking geometry... Overall domain bounding box (0.032143503 0.0032018241 -0.00529831775495462) (9.000004 3.035714 0.00529831775495462) Mesh (non-empty, non-wedge) directions (1 1 1) Mesh (non-empty) directions (1 1 1) Boundary openness (-1.52238576634444e-19 3.07654883655731e-18 -6.06932897918858e-16) OK. ***High aspect ratio cells found, Max aspect ratio: 4085.63956462773, number of cells 348 <<Writing 348 cells with high aspect ratio to set highAspectRatioCells Minumum face area = 5.58437171834072e-08. Maximum face area = 0.00523889579076825. Face area magnitudes OK. Min volume = 2.56474769257852e-09. Max volume = 5.4806642013295e-05. Total volume = 0.141533400036473. Cell volumes OK. Mesh non-orthogonality Max: 12.946271206595 average: 4.83060081614222 Non-orthogonality check OK. Face pyramids OK. Max skewness = 0.136404763277092 OK. Coupled point location match (average 0) OK. Failed 1 mesh checks. End The checkMesh demands there be a "0" folder, without which the utility exits. I had to rename it to make it to "0" to make it work. And as you suggested, I created the mesh without collapsing the edges this time., and I still get the same "Failed 1 mesh checks" with the same numbers. Also, something I noticed here: 1) When I open the mesh through paraFoam, I get this Code:
created temporary 'hill_grid.OpenFOAM' --> FOAM Serious Error : From function IOobject::readHeader(Istream&) in file db/IOobject/IOobjectReadHeader.C at line 89 Reading "/home/arvind/OpenFOAM/arvind-2.1.1/run/hill_grid/constant/points.tmp" at line 2 First token could not be read or is not the keyword 'FoamFile' Check header is of the form: /*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.1.1 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class IOobject; location "constant"; object points.tmp; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // 2) I just wanted to know why you rename the "0" folder to "0.org" ... I saw that paraview doesnt show the mesh unless its renamed to 0.org, whereas The checkMesh demands there be a "0" folder, without which the utility exits. I had to rename it to make it to "0" to make it work. I then convert the mesh to Fluent format using foamMeshToFluent: Code:
// * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0 Writing Header End Thank you again!! |
October 15, 2012, 06:38 |
Bruno Santos
Rep Power: 128 |
I renamed "0" to "0.org" simply because the boundary conditions would no longer be valid, given the very different settings. It was the quickest temporary fix, so we could focus on the mesh.
To check the mesh without "0": Code:
checkMesh -constant As for the message given by checkMesh: that's is a very high value of aspect ratio. You can inspect the cellSet "highAspectRatioCells" in ParaView, either using the "see sets" option on the object inspector, our by using the "-cellSet" option in foamToVTK.
November 1, 2012, 20:51 |
#11 | |
ATM
Sorry for getting back late. I just wanted to thank you for your help and post my solution here.... I had finally managed to get the mesh into OF. As you said, the high aspect ratio was the problem. So, I wrote a C++ code to extrude the given mesh into 3D, with the desired mesh spacing and distance, and output the resulting 3D mesh in plot3d format.the mesh spacing I chose took care of the aspect ratio issue, and the checkMesh report was fine. After that, I just used plot3dtoFoam utility and the mesh was saved in OF. Then I used setSet to specify the boundary faces. Turned out to be simple after all! |
February 22, 2014, 06:34 |
Tecplot mesh to OpenFOAM format
#12 |
anonymous
Rep Power: 12 |
Dear Sir,
How have you converted the tecplot mesh to OpenFOAM format.In your last message you have mentioned that you have written a code to extrude mesh to 3d and then converted that 3D mesh to plot3Dformat.Can you please elaborate on this ? I also have the same problem.I have a tecplot .plt file and I want to open the file in OpenFoam to do some further analysis Thanks and Regards |
[snappyHexMesh] Creating multiple multiple cell zones with snappyHexMesh - a newbie in deep water! | divergence | OpenFOAM Meshing & Mesh Conversion | 0 | January 23, 2019 04:17 |
Mesh Boundary Assignment Question | Wandadars | Mesh Generation & Pre-Processing | 1 | June 13, 2016 17:19 |
Mesh motion with Translation & Rotation | Doginal | CFX | 2 | January 12, 2014 06:21 |
[snappyHexMesh] Layers:problem with curvature | giulio.topazio | OpenFOAM Meshing & Mesh Conversion | 10 | August 22, 2012 09:03 |
