-   OpenFOAM Meshing & Mesh Conversion (http://www.cfd-online.com/Forums/openfoam-meshing/)
-   -   Internal zero thickness walls (http://www.cfd-online.com/Forums/openfoam-meshing/108744-internal-zero-thickness-walls.html)
vbchris October 31, 2012 11:40
Hello all,
Would anyone know of a good tutorial or thread that addresses the following issue?
So far I have found these but the solution is not clear to me:
http://www.cfd-online.com/Forums/ope...tml#post332307
http://www.cfd-online.com/Forums/ope...blockmesh.html
http://www.cfd-online.com/Forums/ope...nal-faces.html
My mesh is generated by blockMesh, however when I try to define an internal face as a wall or patch in blockMeshDict I get the error:
--> FOAM FATAL ERROR:
Trying to specify a boundary face 4(151 153 15 13) on the face on cell 76 which is either an internal face or already belongs to some other patch. This is face 0 of patch 3 named internalWalls.
I would like to create a 0 thickness wall. This face is between two meshed blocks. The 4 vertices that make up the face (151 153 15 13) are used to define both blocks and are not duplicated. Is there a general method for defining 0 thickness internal walls?
I am working with OpenFoam 2.1.1
Thanks for your advice.
UPDATE:
Solved by duplicating existing points on internal face and incorporating into hex blocks.
Runs stable.
sandy13 May 16, 2013 10:00
Originally Posted by vbchris (Post 389492)
Hello all,
UPDATE:
Runs stable.
Dear vbchris,
I saw your post because I have the same error, did you find the solution? because I am desperate for any hint about this issue. Please let me know If you found it.. Sandy:confused:
