[Gmsh] Thin walls (baffles) inside volume with Gmsh |
November 15, 2012, 09:41 |
Rep Power: 14 |
I'm trying to implement baffles in my geometry in gmsh. If I run gmshToFoam without baffles, it works well. But if I implement the baffles, I'll get several warnings like (face 4=baffles): --> FOAM Warning : Not using gmsh face 4(26644 3547 161 3530) since zero vertex is not on boundary of polyMesh I've also tried to define each volume between the baffles, but I didn't help. Does anybody have an idea? kind regards |
November 20, 2012, 09:32 |
Rep Power: 14 |
I've solved the problem. For instructions, see miles_davis post: http://www.cfd-online.com/Forums/ope...tml#post323464 (it works also for gmshToFoam)
how to set periodic boundary conditions | Ganesh | FLUENT | 15 | November 18, 2020 06:09 |
Distance between walls with thin wall/shell conduction | mir9283 | FLUENT | 0 | May 16, 2018 03:49 |
[blockMesh] blockMesh error - Negative Volume Block | adoledin | OpenFOAM Meshing & Mesh Conversion | 2 | June 22, 2016 10:44 |
[blockMesh] Errors during blockMesh meshing | Madeleine P. Vincent | OpenFOAM Meshing & Mesh Conversion | 51 | May 30, 2016 10:51 |
[Commercial meshers] Thin Walls Conversion from Fluent Mesh | Isaac | OpenFOAM Meshing & Mesh Conversion | 1 | March 4, 2016 12:08 |
