[mesh manipulation] difference in 'make axial mesh' for OF 2.1 & OF 1.6 EXT
Old   November 17, 2012, 16:48
Default difference in 'make axial mesh' for OF 2.1 & OF 1.6 EXT
Mandeep
Rocky4 is on a distinguished road
Dear Foamers,
i am using make axial mesh utility for generating axisymmetric mesh.I have used this on OF 2.1 & OF 1.6 dev. I have observed slight difference in the output of MAM interms of the patch type of axis. In OF-1.6 Ext axis patch type is set to 'empty' with zero no of faces whereas in OF 2.1 it is set to 'symmetry plane 'with non zero no of faces at axis.What is the reason for this difference ? which i should use? since there is no offset in my case so i was expecting zero no faces and empty patch type at axis (the one i get from MAM version for OF 1.6 EXT).
also when i run block Mesh utility to generate 2d mesh to use input for MAM i get the message
Exec : blockMesh
Date : Nov 17 2012
Time : 13:11:24
Host : rocky-laptop
PID : 1846
Case : /home/rocky/of16ext/cases/personal/lpd/diffaxis/melt
nProcs : 1
SigFpe : Enabling floating point exception trapping (FOAM_SIGFPE)
why i get this last mesage?
any kind of help is greatly appreciated .
Regards
mandeep
Rocky4 is offline   Reply With Quote
[snappyHexMesh] SnappyHexMesh no layers and no decent mesh for complex geometry pizzaspinate OpenFOAM Meshing & Mesh Conversion 1 February 25, 2015 07:05
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 06:20
mesh difference Song CFX 2 October 5, 2008 17:39
OpenFOAM with IBM AIX matthias OpenFOAM Installation 20 March 25, 2008 02:36
Convergence moving mesh lr103476 OpenFOAM Running, Solving & CFD 30 November 19, 2007 14:09
