March 21, 2013, 04:46 |
fluent3DMeshToFoam
Sasan Ghomi
Rep Power: 14 |
Hi foamers ,
We know that for importing 2D mesh to openfoam (from GAMBIT) we can use fluentMeshToFoam -writeSets This command creates a Sets folder in the polymesh directory and you can see faces of all boundaries... How can I do this action for importing 3D mesh??? I want to importing a 3D mesh from GAMBIT to openfoam and I want to have a Sets file including faces of all boundaries.. any utilities? any commands??? Thanks and best regards, Sasan. |
March 21, 2013, 06:41 |
Olivier
Rep Power: 17 |
hello,
In fact fluentMeshToFoam work with 3D mesh too, so the same with "-writeSets" will work. You can also use fluent3DMeshToFoam, which does almost the same as "fluentMeshToFoam -writeSets -writeZones". Regards, olivier |
March 21, 2013, 10:27 |
Sasan Ghomi
Rep Power: 14 |
Dear Olivier ,
fluent3DMeshToFoam -writeSets doesn't work...(I am using 1.6-ext) I appreciate any help.... Thanks, Sasan. |
March 21, 2013, 10:37 |
Olivier
Rep Power: 17 |
hello,
This is because with fluent3DMeshToFoam, you don't need the "-writeSets" options, just "fluent3DMeshToFaom mesh.msh" will be fine. regards, olivier |
March 21, 2013, 12:22 |
Sasan Ghomi
Rep Power: 14 |
I want to have a Sets file including faces of all boundaries....for 3D mesh...
How can I do this action?? thanks, Sasan. |
March 22, 2013, 01:26 |
Sasan Ghomi
Rep Power: 14 |
I got it....
patchToFace can do this action... Sasan. |
March 26, 2013, 11:42 |
Dogan
Rep Power: 13 |
Hi Sasan,
i am also dealing with fluent3DMeshToFoam, and i also need the sets file in polyMesh directory. As you also had the same problem, fluent3DMeshToFoam command doesn't create a sets directory inside of the polyMesh directory. You mentioned that patchToFace can do this actioin, but i am using openFoam 2.1.x, and i don't know how to create the sets file in 2.1.x. thanks Dogan |
March 26, 2013, 14:00 |
Sasan Ghomi
Rep Power: 14 |
Hi Dear dogan ,
You can use faceSetDict : Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM Extend Project: Open Source CFD | | \\ / O peration | Version: 1.6-ext | | \\ / A nd | Web: www.extend-project.de | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object faceSetDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // name faceSet; action new; topoSetSources ( patchToFace { name presin; // name of boundary faces } ); // ************************************************************************* // Code:
faceSet I think this utility exists in all versions of OpenFoam. best regards, Sasan. |
April 2, 2013, 05:21 |
#9 |
Dogan
Rep Power: 13 |
Hi Sasan,
thank youz very much for your answer. I don't know why, but unfortunately i couldn't mabage to do it with faceSetDict. it may not be the right way but i tried something else, and it worked. i copied the points file in constant, to the rotor file in constant>sets. i know it souds so wrong, but it worked. thanks and regards Dogan |
[Commercial meshers] Mesh conversion problem (fluent3DMeshToFoam) | Aadhavan | OpenFOAM Meshing & Mesh Conversion | 2 | March 8, 2018 01:47 |
periodic (cyclic) boundary - fluent3DMeshToFoam | cyln | OpenFOAM | 1 | October 17, 2017 02:59 |
[Commercial meshers] fluent3DMeshToFoam conversion problem | CFDnewbie147 | OpenFOAM Meshing & Mesh Conversion | 14 | March 12, 2014 05:16 |
Possible Bug in pimpleFoam (or createPatch) (or fluent3DMeshToFoam) | cfdonline2mohsen | OpenFOAM | 3 | October 21, 2013 09:28 |
OpenFOAM command from inside MATLAB | sega | OpenFOAM Post-Processing | 18 | September 25, 2012 07:35 |
