[snappyHexMesh] Adding layers goes wrong with SnappyHexMesh
Like Tree1Likes
  • 1 Post By Elise
Old   March 16, 2012, 09:38
Default Adding layers goes wrong with SnappyHexMesh
Elise
Elise is on a distinguished road
I try to add layers around the walls inside a geometry, only in the circular part I get nice layers, the part at the right side does not get layers at all.
My dictionary file for snappyHexMesh:
|  \\    /   O peration     | Version:  2.1.0                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      snappyHexMeshDict;
// Which of the steps to run
castellatedMesh true;
snap            true;
addLayers       true;
// Geometry. Definition of all surfaces. All surfaces are of class
// searchableSurface.
// Surfaces are used
// - to specify refinement for any mesh cell intersecting it
// - to specify refinement for any mesh cell inside/outside/near
// - to 'snap' the mesh boundary to the surface
geometry
total.stl
        type triSurfaceMesh;
        name scour;
jetinlet.stl
        name jetinlet;
jetoutlet.stl
        name jetoutlet;
tube1.stl
        name tube1;
tube2.stl
        name tube2;
scour1RU.stl
        name scour1RU;
scour1RD.stl
        name scour1RD;
scour1LU.stl
        name scour1LU;
scour1LD.stl
        name scour1LD;
scour2RU.stl
        name scour2RU;
scour2RD.stl
        name scour2RD;
scour2LU.stl
        name scour2LU;
scour2LD.stl
        name scour2LD;
scour3RU.stl
        name scour3RU;
scour3RD.stl
        name scour3RD;
scour3LU.stl
        name scour3LU;
scour3LD.stl
        name scour3LD;
scour4RU.stl
        name scour4RU;
scour4RD.stl
        name scour4RD;
scour4LU.stl
        name scour4LU;
scour4LD.stl
        name scour4LD;
    refinementBox
        type searchableBox;
        min (-0.1 -1 -0.5);
        max ( 0.3  1 0.5);
  refinementBox2
 type searchableBox;
 min (-0.6 -1 -0.5);
 max (-0.1 1 0.5);
// Settings for the castellatedMesh generation.
castellatedMeshControls
    // Refinement parameters
    // If local number of cells is >= maxLocalCells on any processor
    // switches from from refinement followed by balancing
    // (current method) to (weighted) balancing before refinement.
    maxLocalCells 100000;
    // Overall cell limit (approximately). Refinement will stop immediately
    // upon reaching this number so a refinement level might not complete.
    // Note that this is the number of cells before removing the part which
    // is not 'visible' from the keepPoint. The final number of cells might
    // actually be a lot less.
    maxGlobalCells 2000000;
    // The surface refinement loop might spend lots of iterations refining just a
    // few cells. This setting will cause refinement to stop if <= minimumRefine
    // are selected for refinement. Note: it will at least do one iteration
    // (unless the number of cells to refine is 0)
    minRefinementCells 10;
    // Allow a certain level of imbalance during refining
    // (since balancing is quite expensive)
    // Expressed as fraction of perfect balance (= overall number of cells /
    // nProcs). 0=balance always.
    maxLoadUnbalance 0.10;
    // Number of buffer layers between different levels.
    // 1 means normal 2:1 refinement restriction, larger means slower
    // refinement.
    nCellsBetweenLevels 2;
    // Explicit feature edge refinement
    // Specifies a level for any cell intersected by its edges.
    // This is a featureEdgeMesh, read from constant/triSurface for now.
    features
        //    file "someLine.eMesh";
        //    level 2;
    // Surface based refinement
    // Specifies two levels for every surface. The first is the minimum level,
    // every cell intersecting a surface gets refined up to the minimum level.
    // The second level is the maximum level. Cells that 'see' multiple
    // intersections where the intersections make an
    // angle > resolveFeatureAngle get refined up to the maximum level.
    refinementSurfaces
jetinlet
            // Surface-wise min and max refinement level
            level (4 5);
jetoutlet
            level (4 4);
tube1
            level (4 4);
tube2
            level (4 4);
scour1RU
            level (4 4);
scour1RD
            level (4 4);
scour1LU
            level (4 4);
scour1LD
            level (4 4);
scour2RU
            level (4 4);
scour2RD
            level (4 4);
scour2LU
            level (4 4);
scour2LD
            level (4 4);
scour3RU
            level (4 4);
scour3RD
            level (4 4);
scour3LU
            level (4 4);
scour3LD
            level (4 4);
scour4RU
            level (4 4);
scour4RD
            level (4 4);
scour4LU
            level (4 4);
scour4LD
            level (4 4);
    // Resolve sharp angles
    resolveFeatureAngle 65;
    // Region-wise refinement
    // Specifies refinement level for cells in relation to a surface. One of
    // three modes
    // - distance. 'levels' specifies per distance to the surface the
    //   wanted refinement level. The distances need to be specified in
    //   descending order.
    // - inside. 'levels' is only one entry and only the level is used. All
    //   cells inside the surface get refined up to the level. The surface
    //   needs to be closed for this to be possible.
    // - outside. Same but cells outside.
    refinementRegions
        refinementBox
            mode inside;
            levels ((4 4));
 refinementBox2
  mode inside;
  levels ((3 4));
    // Mesh selection
    // After refinement patches get added for all refinementSurfaces and
    // all cells intersecting the surfaces get put into these patches. The
    // section reachable from the locationInMesh is kept.
    // NOTE: This point should never be on a face, always inside a cell, even
    // after refinement.
    locationInMesh (0.05 -0.02 -0.02);
    // Whether any faceZones (as specified in the refinementSurfaces)
    // are only on the boundary of corresponding cellZones or also allow
    // free-standing zone faces. Not used if there are no faceZones.
    allowFreeStandingZoneFaces true;
// Settings for the snapping.
snapControls
    //- Number of patch smoothing iterations before finding correspondence
    //  to surface
    nSmoothPatch 3;
    //- Relative distance for points to be attracted by surface feature point
    //  or edge. True distance is this factor times local
    //  maximum edge length.
    tolerance 4.0;
    //- Number of mesh displacement relaxation iterations.
    nSolveIter 0;
    //- Maximum number of snapping relaxation iterations. Should stop
    //  before upon reaching a correct mesh.
    nRelaxIter 5;
    //- Highly experimental and wip: number of feature edge snapping
    //  iterations. Leave out altogether to disable.
    //  Do not use here since mesh resolution too low and baffles present
    //nFeatureSnapIter 10;
// Settings for the layer addition.
addLayersControls
    // Are the thickness parameters below relative to the undistorted
    // size of the refined cell outside layer (true) or absolute sizes (false).
    relativeSizes true;
    // Per final patch (so not geometry!) the layer information
    layers
tube1_tube1 {nSurfaceLayers 3;}
tube2_tube2 {nSurfaceLayers 3;}
scour1RU_scour1RU
            nSurfaceLayers 3;
scour1RD_scour1RD
            nSurfaceLayers 3;
scour1LU_scour1LU
         nSurfaceLayers 3;
scour1LD_scour1LD
           nSurfaceLayers 3;
scour2RU_scour2RU
           nSurfaceLayers 3;
scour2RD_scour2RD
            nSurfaceLayers 3;
scour2LU_scour2LU
            nSurfaceLayers 3;
scour2LD_scour2LD
            nSurfaceLayers 3;
scour3RU_scour3RU
          nSurfaceLayers 3;
scour3RD_scour3RD
            nSurfaceLayers 3;
scour3LU_scour3LU
            nSurfaceLayers 3;
scour3LD_scour3LD
          nSurfaceLayers 3;
scour3RU_scour3RU
            nSurfaceLayers 3;
scour4RD_scour4RD
            nSurfaceLayers 3;
scour4LU_scour4LU
           nSurfaceLayers 3;
scour4LD_scour4LD
            nSurfaceLayers 3;
    // Expansion factor for layer mesh
    expansionRatio 1.6;
    //- Wanted thickness of final added cell layer. If multiple layers
    //  is the
    //  thickness of the layer furthest away from the wall.
    //  Relative to undistorted size of cell outside layer.
    //  is the thickness of the layer furthest away from the wall.
    //  See relativeSizes parameter.
    finalLayerThickness 0.2;
    //- Minimum thickness of cell layer. If for any reason layer
    //  cannot be above minThickness do not add layer.
    minThickness 0.1;
    //- If points get not extruded do nGrow layers of connected faces that are
    //  also not grown. This helps convergence of the layer addition process
    //  close to features.
    // Note: changed(corrected) w.r.t 17x! (didn't do anything in 17x)
    nGrow 1;
    // Advanced settings
    //- When not to extrude surface. 0 is flat surface, 90 is when two faces
    //  make straight angle.
    featureAngle 30;
    nRelaxIter 3;
    // Number of smoothing iterations of surface normals
    nSmoothSurfaceNormals 1;
    // Number of smoothing iterations of interior mesh movement direction
    nSmoothNormals 3;
    // Smooth layer thickness over surface patches
    nSmoothThickness 10;
    // Stop layer growth on highly warped cells
    maxFaceThicknessRatio 0.5;
    // Reduce layer growth where ratio thickness to medial
    // distance is large
    maxThicknessToMedialRatio 0.3;
    // Angle used to pick up medial axis points
    // Note: changed(corrected) w.r.t 17x! 90 degrees corresponds to 130 in 17x.
    minMedianAxisAngle 90;
    // Create buffer region for new layer terminations
    nBufferCellsNoExtrude 0;
    // Overall max number of layer addition iterations. The mesher will exit
    // if it reaches this number of iterations; possibly with an illegal
    // mesh.
    nLayerIter 80;
// Generic mesh quality settings. At any undoable phase these determine
// where to undo.
meshQualityControls
    //- Maximum non-orthogonality allowed. Set to 180 to disable.
    maxNonOrtho 65;
    //- Max skewness allowed. Set to <0 to disable.
    maxBoundarySkewness 20;
    maxInternalSkewness 4;
    //- Max concaveness allowed. Is angle (in degrees) below which concavity
    //  is allowed. 0 is straight face, <0 would be convex face.
    //  Set to 180 to disable.
    maxConcave 80;
    //- Minimum pyramid volume. Is absolute volume of cell pyramid.
    //  Set to a sensible fraction of the smallest cell volume expected.
    //  Set to very negative number (e.g. -1E30) to disable.
    minVol 1e-13;
    //- Minimum quality of the tet formed by the face-centre
    //  and variable base point minimum decomposition triangles and
    //  the cell centre. This has to be a positive number for tracking
    //  to work. Set to very negative number (e.g. -1E30) to
    //  disable.
    //     <0 = inside out tet,
    //      0 = flat tet
    //      1 = regular tet
    minTetQuality 1e-30;
    //- Minimum face area. Set to <0 to disable.
    minArea -1;
    //- Minimum face twist. Set to <-1 to disable. dot product of face normal
    //- and face centre triangles normal
    minTwist 0.02;
    //- minimum normalised cell determinant
    //- 1 = hex, <= 0 = folded or flattened illegal cell
    minDeterminant 0.001;
    //- minFaceWeight (0 -> 0.5)
    minFaceWeight 0.02;
    //- minVolRatio (0 -> 1)
    minVolRatio 0.01;
    //must be >0 for Fluent compatibility
    minTriangleTwist -1;
    // Advanced
    //- Number of error distribution iterations
    nSmoothScale 4;
    //- amount to scale back displacement at error points
    errorReduction 0.75;
// Advanced
// Flags for optional output
// 0 : only write final meshes
// 1 : write intermediate meshes
// 2 : write volScalarField with cellLevel for postprocessing
// 4 : write current intersections as .obj files
debug 0;
// Merge tolerance. Is fraction of overall bounding box of initial mesh.
// Note: the write tolerance needs to be higher than this.
mergeTolerance 1e-6;
raj kumar saini likes this.
Elise is offline   Reply With Quote
Old   April 22, 2013, 02:32
Samo
Lojz is on a distinguished road
Since you are meshing with several .stl files, there is no patches added yet i think, and that's why snappy doesn't recognize the areas, where it should add layers. Try (also try splitting your mesh first) assigning patches to your mesh and adding layers. And if it still doesn't work, try changing relativeSizes entry in your snappyhexmeshdict.
Lojz is offline   Reply With Quote
[snappyHexMesh] Triangular elements in boundary layers generated by snappyHexMesh mike.franky OpenFOAM Meshing & Mesh Conversion 0 June 3, 2018 09:46
[snappyHexMesh] snappyHexMesh: How to add layers to part of an STL? Dreoasteh OpenFOAM Meshing & Mesh Conversion 0 May 14, 2018 10:59
[snappyHexMesh] Avoiding wedge cells and folded cells while adding layers - snappyHexMesh Saideep OpenFOAM Meshing & Mesh Conversion 2 March 22, 2018 08:10
[ICEM] Adding more layers to prism shereez234 ANSYS Meshing & Geometry 6 April 6, 2015 04:20
[snappyHexMesh] SnappyHexMesh no layers and no decent mesh for complex geometry pizzaspinate OpenFOAM Meshing & Mesh Conversion 1 February 25, 2015 07:05
