[Commercial meshers] Import mesh with internal face from Fluent to openfoam 2.1.1 |
April 26, 2013, 02:46 |
OpenFoam
I have a closed loop flow problem. I want to model a pressure drop(to simulate forced convection) across a internal face using "fan" boundary condition in openfoam 2.1.1. I am using Gambit to generate mesh and then "FluentMeshToFoam" command to import it to OF. The steps given in openfoamwiki is not working with OF 2.1.1. How to import a mesh with internal face in OF 2.1.1? |
April 29, 2013, 03:54 |
Nima Samkhaniani
Rep Power: 24 |
its fluentMeshToFoam not FluentMeshToFoam (F is not capital :P)
however, your case is 2D or 3D? if it is 3D cases, you should use fluent3DMeshToFoam if there is an error, you should post your error here, then any one would help you
My Personal Website (http://nimasamkhaniani.ir/) Telegram channel (https://t.me/cfd_foam) |
fan type, fluentmeshtofoam, internal faces |
[snappyHexMesh] Help with Snappy: no layers growing | GianF | OpenFOAM Meshing & Mesh Conversion | 2 | September 23, 2020 08:26 |
The fluent stopped and errors with "Emergency: received SIGHUP signal" | yuyuxuan | FLUENT | 0 | December 3, 2013 22:56 |
[blockMesh] BlockMesh FOAM warning | gaottino | OpenFOAM Meshing & Mesh Conversion | 7 | July 19, 2010 14:11 |
