Home > Forums > OpenFOAM Meshing & Mesh Conversion
file modification
Old   May 28, 2013, 07:45
Default file modification
belkadi
belkadi is on a distinguished road
Dear all,
I post this message in order to obtain a help.
I'm beginners with openfoam, I've just created a mesh for a basic structure (left image in the attached file).
I'm wondering if you can help to add some features to obtain the right image of the attached file .
Here my original code for the mesh
| \\ / O peration | Version: 2.2.0 |
| \\ / A nd | Web: www.OpenFOAM.org |
| \\/ M anipulation | |
FoamFile
version 2.0;
format ascii;
class dictionary;
object blockMeshDict;
convertToMeters 0.001;
vertices
(0 -25.4 -15)
(0 -5 -15)
(0 0 -15)
(0 3 -15)
(0 12.7 -15)
(0 25.4 -15)
(206 -25.4 -15)
(206 -8.5 -15)
(206 0 -15)
(206 6.5 -15)
(206 17 -15)
(206 25.4 -15)
(290 -16.6 -15)
(290 -6.3 -15)
(290 0 -15)
(290 4.5 -15)
(290 11 -15)
(290 16.6 -15)
(0 -25.4 15)
(0 -5 15)
(0 0 15)
(0 3 15)
(0 12.7 15)
(0 25.4 15)
(206 -25.4 15)
(206 -8.5 15)
(206 0 15)
(206 6.5 15)
(206 17 15)
(206 25.4 15)
(290 -16.6 15)
(290 -6.3 15)
(290 0 15)
(290 4.5 15)
(290 11 15)
(290 16.6 15)
blocks
// hex (0 6 7 1 22 28 29 23) (18 7 1) simpleGrading (0.5 1.8 1)
// hex (1 7 8 2 23 29 30 24) (18 10 1) simpleGrading (0.5 4 1)
// hex (2 8 9 3 24 30 31 25) (18 13 1) simpleGrading (0.5 0.25 1)
//hex (0 10 11 5 26 32 33 27) (180 18 1) simpleGrading (4 1 1)
hex (0 6 7 1 18 24 25 19 ) (1 1 1) simpleGrading (1 1 1)
hex (1 7 8 2 19 25 26 20) (1 1 1) simpleGrading (1 1 1)
hex (2 8 9 3 20 26 27 21) (1 1 1) simpleGrading (1 1 1)
hex (3 9 10 4 21 27 28 22) (1 1 1) simpleGrading (1 1 1)
hex (4 10 11 5 22 28 29 23) (1 1 1) simpleGrading (1 1 1)
hex (6 12 13 7 24 30 31 25) (1 1 1) simpleGrading (1 1 1)
hex (7 13 14 8 25 31 32 26) (1 1 1) simpleGrading (1 1 1)
hex (8 14 15 9 26 32 33 27) (1 1 1) simpleGrading (1 1 1)
hex (9 15 16 10 27 33 34 28) (1 1 1) simpleGrading (1 1 1)
hex (10 16 17 11 28 34 35 29) (1 1 1) simpleGrading (1 1 1)
edges
arc 0 1 (-1 3 0.0)
arc 1 2 (-1 3 0.0)
arc 2 3 (-1 3 0.0)
arc 3 4 (-1 3 0.0)
arc 4 5 (-1 3 0.0)
patches
If you have any suggestions please contact me !
Many thanks
Kind regards
Belkadi
belkadi is offline   Reply With Quote
Old   June 3, 2013, 14:03
Nima Samkhaniani
nimasam is on a distinguished road
you can create a base mesh (a slice of domain), then use extrudeMesh utility at OpenFOAM to create the whole domain
Telegram channel (https://telegram.me/openfoam4Iranian)
My Weblog (http://openfoam.blogfa.com/)
Training Course on OpenFOAM at (http://www.isme.ir/)
nimasam is offline   Reply With Quote
Thread Tools
Trackbacks are On
groovyBC in openFOAM-2.0 for parabolic velocity bc ofslcm OpenFOAM Pre-Processing 24 August 23, 2015 22:41
problem on installing swak4Foam navid2 OpenFOAM Installation 2 May 30, 2012 04:32
error message with modeling a cube with a hold at the center hsingtzu OpenFOAM Native Meshers: blockMesh 2 March 14, 2012 10:56
1.7.x Environment Variables on Linux 10.04 rasma OpenFOAM Installation 9 July 30, 2010 04:43
BlockMesh FOAM warning gaottino OpenFOAM Native Meshers: blockMesh 7 July 19, 2010 14:11
