[snappyHexMesh] snappyHexMesh and refineWallLayer |
June 20, 2013, 13:36 |
Claudio
Rep Power: 15 |
Hi All,
I'm trying to get a decent looking grid for the Wigley Hull tutorial, but have not been successful so far. First thing I tried was to use snappyHexMesh to create multiple layers near the hull surface, and through a lot of trial and error I got to the point where the layers looked very good in certain parts but still failed in others. I tried my best to explain what happens in this post. I then went on to try a different way, which was to create one single thick layer to be subsequently divided into multiple layer using the refineWallLayer routine. Even creating a single layer was not completely successful (as the attached pictures show), since there is a small patch near the bow where the layer does not grow. It's a bit of a mistery since the geometry is symmetric front to back and side to side, which means that except for orientation each "quarter" of the geometry is the same. Still for 3 of them it works beautifully, but not for one. If I run checkMesh after creating a single layer, I get that 35 faces have high skew (max is 8.78, see log.checkMesh_SL). I then run refineWallLayer a few times with a ratio of about 0.7, and run checkMesh again. Now the mesh fails 4 checks (2 open cells, 3479 non-orthogonal faces, 5 incorrectly oriented faces, 1741 highly skewed faces). Is there a way to prevent this? Maybe another application to run between each instance of refineWallLayer that would smooth the mesh out? I tried running sHM with only addLayer true, but nSurfaceLayers 0, to try to use the smoothing options, but it did not work. Any help for creating a good BL mesh will be greatly appreciated. Claudio |
[snappyHexMesh] refineWallLayer vs add layer | Astan | OpenFOAM Meshing & Mesh Conversion | 0 | March 18, 2019 12:03 |
[snappyHexMesh] Could not Add Boundary Layers near a Rectangular Channel Wall using SnappyHexMesh | Gary | OpenFOAM Meshing & Mesh Conversion | 3 | July 30, 2018 04:14 |
[snappyHexMesh] refineWallLayer | openfoam_user | OpenFOAM Meshing & Mesh Conversion | 10 | October 20, 2012 12:59 |
[snappyHexMesh] snappyHexMesh: create boundary layer in a bent tube | brahim | OpenFOAM Meshing & Mesh Conversion | 10 | September 5, 2011 09:43 |
