conversion from .stl to .msh
hello
how can i convert a .stl file to a .msh file?? Thanking you in advance for a reply' Izna |
Hi Izna
it is not possible. STL is a format for geometry files and msh a format for mesh files. However snappyHexMesh helps you generating an OpenFOAM mesh from a geometry. Maybe you can export this to msh format. Markus |
Hi markus
thank you for your quick reply.. .stl format is for the openfoam format right? now i have a .stl file and i have to get a .msh file for another project. .stl file is not a meshed file? can you please be kind and explain more about the snappyHexMesh and the openfoam mesh i am confused.. in this below list of conversion i can not see .stl format.. Izna |
i can not see the file.. the website is being updated..
how do i go from .stl to snappyHexMesh? can you please give me the command? thanks izna |
You will find lots of information here: http://openfoamwiki.net/index.php/SnappyHexMesh
hi
i stil has not found a way to convert my .stl mesh to .msh..:( can anyone give me a hand? |
does that ".msh" indicate that you are trying to produce a "fluent"-mesh, or is it a typing error? As previous posters describe there are tools like SnappyHexMesh or itīs GUI-cousin HELXY-OS http://sourceforge.net/projects/helyx-os/ (not to forget engrid) to produce a CFD-mesh for OpenFOAM Further you can convert a sucessfuly created OpenFOAM mesh into a "fluent"-mesh "*.msh" using "foamMeshToFluent" which writes out the OPENFOAMŪ mesh in Fluent mesh format take a look http://www.hpfem.jku.at/netgen/ |
hii problem resolved..
I simply had to call my file then type the command..foamMeshToFuent in terminal and it convert my .stl file which has already been meshed using snappyHexMesh.... Thanks everyone..;-) cheers Izna |
we have developed a free tool that creates meshes (SHM, not msh) and cases from STL files, please register to download here:
http://cfd.cadnexus.com/ If you are set on using .msh files, you can import your STL in GMSH and use the GUI to generate a mesh of that format. http://geuz.org/gmsh/ |
thanks for your info dear Mihai, it is indeed a useful tool....:)
