Home > Forums > OpenFOAM Meshing & Mesh Conversion
how to call my .stl file in the terminal
Like Tree3Likes
Old   July 9, 2013, 16:11
chegdan's Avatar
Daniel P. Combest
chegdan will become famous soon enoughchegdan will become famous soon enough
First off, there is a snappyhexMeshDict file in the tar file from the wiki located here in case you wanted to go there and look further into replicating the case that was provided on the wiki. I went ahead and made a new one that works for the STL file you provided.
My snappyHexMeshDict file is
|       o          |                                                          |
|    o     o       | HelyxOS                                                  |
|   o   O   o      | Version: vnull.null.null                                           |
|    o     o       | Web:     http://www.engys.com                            |
|       o          |                                                          |
FoamFile
    version 2.0;
    format ascii;
    class dictionary;
    location system;
    object snappyHexMeshDict;
    castellatedMesh true;
    snap true;
    addLayers true;
    geometry
        AskerveinHill.stl
            type triSurfaceMesh;
            name AskerveinHill;
    castellatedMeshControls
        features
        refinementSurfaces
            AskerveinHill
                regions
                    vcg
                        level (2 3 );
                level (0 0 );
        refinementRegions
            AskerveinHill
                levels ();
                mode distance;
        locationInMesh (500.0 500.0 250.0 );
        maxLocalCells 1000000;
        maxGlobalCells 2000000;
        minRefinementCells 0;
        nCellsBetweenLevels 1;
        resolveFeatureAngle 30;
        allowFreeStandingZoneFaces false;
    snapControls
        nSolveIter 300;
        nSmoothPatch 3;
        tolerance 1.0;
        nRelaxIter 5;
        nFeatureSnapIter 10;
        implicitFeatureSnap false;
        explicitFeatureSnap true;
        multiRegionFeatureSnap false;
    addLayersControls
        layers
            AskerveinHill_vcg
                nSurfaceLayers 4;
        relativeSizes true;
        expansionRatio 1.0;
        finalLayerThickness 0.3;
        minThickness 0.2;
        nGrow 0;
        featureAngle 60;
        slipFeatureAngle 30;
        nRelaxIter 3;
        nSmoothSurfaceNormals 1;
        nSmoothNormals 3;
        nSmoothThickness 10;
        maxFaceThicknessRatio 0.5;
        maxThicknessToMedialRatio 0.3;
        minMedianAxisAngle 90;
        nBufferCellsNoExtrude 0;
        nLayerIter 50;
        nRelaxedIter 20;
    meshQualityControls
        maxNonOrtho 65;
        maxBoundarySkewness 20;
        maxInternalSkewness 4;
        maxConcave 80;
        minFlatness 0.5;
        minVol 1.00E-13;
        minTetQuality -1e30;
        minArea -1;
        minTwist 0.02;
        minDeterminant 0.001;
        minFaceWeight 0.02;
        minVolRatio 0.01;
        minTriangleTwist -1;
        nSmoothScale 4;
        errorReduction 0.75;
    debug 0;
    mergeTolerance 1E-6;
My blockMeshDict file is
|       o          |                                                          |
|    o     o       | HelyxOS                                                  |
|       o          |                                                          |
FoamFile
    version 2.0;
    format ascii;
    class dictionary;
    location system;
    object blockMeshDict;
    convertToMeters 1;
    vertices
        ( 5.0 5.0 -10.0)
        ( 2640.0 5.0 -10.0)
        ( 2640.0 2480.0 -10.0)
        ( 5.0 2480.0 -10.0)
        ( 5.0 5.0 500.0)
        ( 2640.0 5.0 500.0)
        ( 2640.0 2480.0 500.0)
        ( 5.0 2480.0 500.0)
    blocks
    hex (0 1 2 3 4 5 6 7) (106 100 21 ) simpleGrading (1 1 1)
    edges ( );
    patches
 wall ffminx ( (0 4 7 3) )
 wall ffmaxx ( (1 2 6 5) )
 wall ffminy ( (0 1 5 4) )
 wall ffmaxy ( (3 7 6 2) )
 wall ffminz ( (0 3 2 1) )
 wall ffmaxz ( (4 5 6 7) )
    mergePatchPairs ( );
and this can all be meshed by executing
blockMesh
snappyHexMesh
When the blockMeshDict is placed in the constant/polyMesh folder and the snappyHexMeshDict file is in the system folder of the case. These files should produce a domain that has about 1.3 million cells with a boundary layer of cells over the domain. You may want to look through the snappyHexMeshDict in the tar file form the original Askervein case (above) and add refinement boxes and change the refinement levels to match the original case. I suggest you look at the following presentation to get a good idea about what each of these entries are in my dictionary files and also the overall method involved.
izna likes this.
Dan
Find me on twitter @dancombest and LinkedIn
chegdan is offline   Reply With Quote
Old   July 9, 2013, 16:17
izna O'connor
izna is on a distinguished road
thank you.
froom the onlie package i cannot open it.. this is why i used another askervin .stl which i sent to you.
HAving done the modifications, i am able to run the blockmesh and snappyhexmesh.
then i run simpleFoam.. and i obtain error..
| \\ / O peration | Version: 2.2.0 |
| \\ / A nd | Web: www.OpenFOAM.org |
| \\/ M anipulation | |
Build : 2.2.0-5be49240882f
Exec : simpleFoam
Date : Jul 10 2013
Time : 13:24:41
Host : "izna-MS-7592"
PID : 3545
Case : /home/izna/Desktop/Askervein
nProcs : 1
allowSystemOperations : Disallowing user-supplied system call operations
Create time
Create mesh for time = 6
Reading field p
--> FOAM FATAL IO ERROR:
cannot find file
file: /home/izna/Desktop/Askervein/6/p at line 0.
From function regIOobject::readStream()
in file db/regIOobject/regIOobjectRead.C at line 73.
FOAM exiting
izna is offline   Reply With Quote
Thread Tools
Trackbacks are On
swak4foam building problem GGerber OpenFOAM Installation 54 April 24, 2015 16:02
non-orthogonal faces and incorrect orientation? nennbs OpenFOAM Native Meshers: blockMesh 7 April 17, 2013 05:42
pisoFoam compiling error with OF 1.7.1 on MAC OSX Greg Givogue OpenFOAM Programming & Development 3 March 4, 2011 18:18
1.7.x Environment Variables on Linux 10.04 rasma OpenFOAM Installation 9 July 30, 2010 04:43
Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Native Meshers: blockMesh 10 April 2, 2007 14:00
