[snappyHexMesh] SNAPPY HEX MESH : help with case setup
Old   July 4, 2013, 15:56
Default SNAPPY HEX MESH : help with case setup
xxxxx
xxxx is on a distinguished road
Hello everybody.
I'm trying to understand how snappyHexMesh works in OF211.
I created my mesh and now I'm trying to define BCs.
The case is an internal flow. Let's consider, as an example, the case of a simple straight tube.
I created the tube walls as separated STL files.
The I used snappyHexMesh to create the mesh. I defined an external box witch contains all the tube. The mesh generation succeeded.
My problem is that OF asks me to define any BC for the external box walls.
What condition should I define? I don't need that patches, I only want to study the geometry contained in the box!
xxxx is offline   Reply With Quote
Old   July 9, 2013, 15:40
xxxxx
Hello..
Perhapes I did not specify my problem the right way.
I'm trying to use snappyHexMesh to create meshes for internal fluid dynamics.
I don't know what I am doing wrong but in the boundary file I found the wall of the "box" I used to create the mesh.
What do I have to do to correct?
Federico
pimpleDyMFoam - rho not found maasyraf3 OpenFOAM Running, Solving & CFD 10 June 5, 2017 13:05
This mesh contains patches of type empty but is not 1D or 2D oric OpenFOAM Running, Solving & CFD 36 November 28, 2016 07:12
[blockMesh] apparently the mesh doesn't want to be created in one direction Maxime Thomas OpenFOAM Meshing & Mesh Conversion 1 August 18, 2012 06:05
[snappyHexMesh] Interior Snappy Hex Mesh wWieWalter OpenFOAM Meshing & Mesh Conversion 2 August 11, 2011 07:11
Icemcfd 11: Loss of mesh from surface mesh option? Joe CFX 2 March 26, 2007 18:10
