problem running potential foam
message shown is Create time Creating block mesh from "/home/subh/OpenFOAM/subh-2.2.0/run/cylinder/constant/polyMesh/blockMeshDict" Using #codeStream at line 19 in file "/home/subh/OpenFOAM/subh-2.2.0/run/cylinder/constant/polyMesh/blockMeshDict" --> FOAM FATAL IO ERROR: Loading a shared library using case-supplied code is not enabled by default because of security issues. If you trust the code you can enable this facility be adding to the InfoSwitches setting in the system controlDict: allowSystemOperations 1 The system controlDict is either ~/.OpenFOAM/$WM_PROJECT_VERSION/controlDict or $WM_PROJECT_DIR/etc/controlDict file: /home/subh/OpenFOAM/subh-2.2.0/run/cylinder/constant/polyMesh/blockMeshDict from line 17 to line 17. From function functionEntries::codeStream::execute(..) in file db/dynamicLibrary/dynamicCode/dynamicCode.C at line 81. FOAM exiting |
