[snappyHexMesh] SnappyHexMesh -- Giving Up -- Reason
Old   July 19, 2013, 08:39
Unhappy SnappyHexMesh -- Giving Up -- Reason
Aditya
kingmaker is on a distinguished road
Hello
I am trying to mesh the geometry of a centrifugal blower. I am having trouble with snappy saying that it "cannot sap successfully .. Giving up". I could not figure out what is happening.
I read a lot of discussion about this problem in the thread ....
PHP Code:
http://www.cfd-online.com/Forums/openfoam-meshing-snappyhexmesh/104855-snappyhexmesh-doesnt-snap-2.html
But could not solve my problem. I tried with the resolveFeatureAngle and changing the underlying blockmesh grading and number of cells ... but could not get a good mesh.
Also in the snappy hex mesh log I found that the given point is found in cell number -1 of the region 0 of 4 ...
Is it a problem I meant ... -1 cell ...??
But this is not the case in the beginning ... !! this cell number was a positive number in the beginning .. !! later it is -1 ... !!
Thanks in advance.
kingmaker is offline   Reply With Quote
[CAD formats] Creating waterproof STL using snappyHexMesh or salome Tobi OpenFOAM Meshing & Mesh Conversion 58 May 13, 2020 06:01
[snappyHexMesh] Tutorial crashes: snappyHexMesh floating point exception. jasv OpenFOAM Meshing & Mesh Conversion 4 May 10, 2016 02:55
[snappyHexMesh] stitchMesh and snappyHexMesh gdbaldw OpenFOAM Meshing & Mesh Conversion 0 December 23, 2009 02:09
Discussion: Reason of Turbulence!! Wen Long Main CFD Forum 3 May 15, 2009 09:52
[snappyHexMesh] SnappyHexMesh not generate mesh first time mavimo OpenFOAM Meshing & Mesh Conversion 4 August 26, 2008 07:08
